Dana 60 fit #1670154
09/11/14 07:01 PM
09/11/14 07:01 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Hi all
Would a Dana 60 from a 69 charger fit under a 72 road runner with out much issue? Would their be much modification needed?
Mikey
1969 Dodge Dart Swinger
Re: Dana 60 fit [Re: MikeyT] #1670155
09/11/14 07:09 PM
09/11/14 07:09 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
3" narrower than a 71-74 rear
Perches are also ~3" narrower.
It's not a drop in. Could the perches be moved out 1.5" on each side? Don't know if they can move that far without getting into the housing ends.
Wheels would need less offset.
Re: Dana 60 fit [Re: RobX4406] #1670156
09/11/14 08:23 PM
09/11/14 08:23 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
DoctorDiff ‘71-’74 B-body 1 1/4" offset spring hanger/shackle kit for standard springs $185
This kit may help give him a call. It moves your stock springs in
Re: Dana 60 fit [Re: RobX4406] #1670157
09/12/14 01:13 AM
09/12/14 01:13 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
So you are saying I am three inches to long? What else is new... pfft Girls say that to me all the time!
Mikey
Re: Dana 60 fit [Re: MikeyT] #1670158
09/12/14 09:47 PM
09/12/14 09:47 PM
Mikey
I know them girls, they lie to you all the time To me too Op, as far as the longer 1971/72 B body Dana 60 there the same width as all The E body Dana 60. So that means it will work if your willing to make it work
Re: Dana 60 fit [Re: MikeyT] #1670159
09/12/14 10:10 PM
09/12/14 10:10 PM
JAX FLA
Curt Offline
Curt  Offline
JAX FLA
Been years so... Put a dana 60 from a 69 body under my challenger (73) i used offset front hangers for A-bodies. I made rear rails and used straight hangers for the back. My understanding is the offset front hangers and offset rear hangers is all that is needed...that and perhaps slight grinding of the locating hole in the perches. I made sure my rear leafs were parallel for reduced rear roll steer, used the stock perches in stock location.....really cant remember if I did anything to the perches at all.... Allowed 15x10's with 295's with no clearance issues
Curt
Oh yeah...THAT'S gonna leave a mark!
