Valve body with clean neutral #1669606
09/10/14 03:50 AM
09/10/14 03:50 AM
in a chair
mopartony Offline OP
in a chair
Guys,
Need to know where to get a valve body with a clean neutral. This is for a 727, I know they make them but can not find them searching the net.
Thanks,
Re: Valve body with clean neutral [Re: mopartony] #1669607
09/10/14 10:05 AM
09/10/14 10:05 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Call Dave at Protrans http://www.protransracing.com PPP also makes shifters set up for a safety neutral http://www.precisionperformance.com/home.htm
"Just a Bracket car dressed up like a streetcar"
Re: Valve body with clean neutral [Re: Just-a-dart] #1669608
09/10/14 10:08 AM
09/10/14 10:08 AM
s e mich
ro23car Offline
ro23car  Offline
s e mich
griner.
Re: Valve body with clean neutral [Re: mopartony] #1669609
09/10/14 11:26 AM
09/10/14 11:26 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Be sure you know what you are getting and it matches your needs -
Clean Neutral - Neutral position after 3rd that exhausts ALL bands and clutches
http://www.gotranzact.com/valvebodies_page1.html
There is a clean neutral on moparts for sale right now -
72chrgrally - Mopar Transmissions for sale Sept section. "Trazact trans-brake valve body with clean neutral (PN123N pattern). Works perfectly."
Safe Neutral - Neutral position after 3rd that exhausts ALL bands and clutches.. EXCEPT the direct drum. Keeps rotating components at same rpm as engine and prevents over speed of direct drum. More complex to build but SAFER.
Griner only sells a "SAFE" neutral, P/N 1222G25B. TranzAct sells a "CLEAN" neutral as well as some other companies.
http://www.727specialist.com/ , Hutch on Yellowbullet.com -
http://hutchtrans.com/index.php?option=c...&Itemid=147
John
Re: Valve body with clean neutral [Re: mopartony] #1669611
09/10/14 02:30 PM
09/10/14 02:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO call the Smith clan at ProTrans..
Re: Valve body with clean neutral [Re: Al_Alguire] #1669612
09/12/14 01:05 AM
09/12/14 01:05 AM
in a chair
in a chair
Thanks guys!!
I will check the one on for sale side and call PPP.
Re: Valve body with clean neutral [Re: mopartony] #1669613
09/12/14 10:46 AM
09/12/14 10:46 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Turbo action has a new line of VBs:
"Turbo Action all new CHEETAH XtremeAction Valve Bodies will set a new standard of performance for race and the street. CHEETAH XtremeAction Valve Body, 17875XA has a safe clean neutral and no need to use a button to backup. A clean rear band apply and release making it a great race or street valve body and No roller clutch failure. Valve Bodies 17880XA CHEETAH XtremeAction Race Only and 17855EXA CHEETAH E-SHIFT have Clean Neutral and No Engine Braking Low Gear. New 17899XA TranzBrake Valve Body also available."
http://www.turboaction.com/vbxa.htm#CHEETAH%20VALVE%20BODIES
Re: Valve body with clean neutral [Re: Exit1965] #1669614
09/12/14 11:37 AM
09/12/14 11:37 AM
Guitar Jones Offline
It looks like the tranzbrake valvebody does not incorporate a clean/safe neutral.
Re: Valve body with clean neutral [Re: Guitar Jones] #1669615
09/12/14 12:06 PM
09/12/14 12:06 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
trans brake is on my list of santa presents thinking about that tranzact clean neutral reverse pattern valve body. Does it have low band apply would be my only question. I also like that PPP shifter, think it will be going on my santa list also
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Valve body with clean neutral [Re: Al_Alguire] #1669616
09/13/14 03:50 AM
09/13/14 03:50 AM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
100%
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
