03 Ram questions #1668835
09/08/14 11:39 AM
09/08/14 11:39 AM
Downtown Roebuck Ont
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
I posted this in Q&A but probably should have posted here. Anyway some cut and paste and...
I have an electronic issue going on. Truck has 4.7.
The radio quit and when you shut off the engine, the hot light stays on and nothing that would normally work with the key off works. No dome light no locks nada. No OBD2 port either.
Codes from flashing the key are 0456, 0440, 0301 and 0137. 301 has been fixed but not cleared.(coil). 0137 seems to be the only one remotely involved.
I checked all the fuses with a test light with them installed in the fuse box. The only one with no power key on or off was the O2 and it powered up when I started the engine.
Left signal has now left the building. Flasher runs real fast. Right front flashes but no rear. 4 ways flash a little slower but no left side. No brake lights except the 3rd one on the cab. Only one low beam on one side and one hi beam on the opposite side.
I have since changed the fusebox and the FCM out as a unit (used) and nothing changed. Same stuff that was FUBAR still is.
Kevin
Re: 03 Ram questions [Re: Twostick] #1668836
09/10/14 01:12 AM
09/10/14 01:12 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
Try checking these fuses,
1. Check the Ignition Off Draw (IOD) fuse in the Integrated Power Module (IPM). The IOD fuse is fuse 51 in the plastic holder.
2. Replace the fuse if blown or missing. Sometimes the plastic holders need to be removed for the fuse to keep good contact in the IPM.
3. Check the power through the IPM. Fuse 51 feeds the Pink wire in connector C1 pin 9 at the bottom of the IPM. Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
