muriatic acid bath!
#1668707
09/07/14 11:15 PM
09/07/14 11:15 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
After watching Breaking Bad I got an idea. For years I've been cleaning parts like control arms, frames, brackets etc etc with brake cleaner and lacquer thinner, then using a wire brush and wire wheel on an angle grinder to get the remaining rust off. Today, I experimented and put a couple gallons of muriatic acid (from local hardware store) in a plastic 55 gallon drum. I pulled the control arms off my girlfriends nova earlier, and they were caked in grime, oil, dirt and rust. I put them in the drum. They started sizzlin. The fumes were intense so I got a respirator. After 10 minutes, I pulled them out and they were bare bright metal were they had been dipped. Im going to get more and completely submerse them. I cant believe how great it worked.
Is this common knowledge? Does anyone else do this or a similar technique? I had never heard of doing this before. I know that you can get your car acid dipped, but I didnt know there was similar chemical available for over the counter purchase.
It's saved me a lot of time cleaning and grinding.
Re: muriatic acid bath!
[Re: Adam71Charger]
#1668708
09/07/14 11:22 PM
09/07/14 11:22 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A bit of advice, do not put a nut and bolt threaded together in the bath and let it sit over night. You will have no threads left, BTDT. Happened to a set of shock plates I had.
[Re: burdar]
#1668711
09/08/14 12:25 AM
09/08/14 12:25 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
Don't buy the stronger 31.45% solution of Muratic Acid (31.45% Hydrochloric Acid) and mess with it straight. I just went through that ordeal. It's nasty and chokes you out just pouring it out of the bottle. Get the 15% "low odor" stuff. It does flash rust uber fast. I dunked it in straight water immediately and directly to neutralize it. While gagging from momentarily opening and closing the ice chest with 3 gallons of 30% Muratic Acid. After dunking it while still wet I sprayed rust Justice Brother Chain Lube oil (thicker consistency with rust preventative). Kept spraying it to displace the water. Day later I rubbed off the excess oil. The manifold on top I just brushed on straight 30% muratic acid with a steel brush and washed with water. IMHO, I have seen NOS manifolds look like both of them. One on top if the packing oil has evaporated/worn off of it. BTW these were very nice So Cal manifolds that were recently on a car. No pitting to start with. The heat riser weight was not submerged in the solution as it was just above the Muriatic Acid level.
[Re: cudaman1969]
#1668713
09/08/14 01:00 AM
09/08/14 01:00 AM
Adam71Charger
I just put my e-body frame rail in my bath, i make forms to fit, been doing this for many years. I mix one gallon acid with 4 gal. vinegar and 4 gal. water. Cheaper this way but takes a little longer. Make sure you use a neutralizer to keep fron rusting back fast.
Do you mean your bathroom Bath-tub?
[Re: Adam71Charger]
#1668714
09/08/14 01:06 AM
09/08/14 01:06 AM
Supercuda
About to go away
About to go away
up yours
Vinegar is acetic acid, I don't think it'll neutralize muriatic. Baking soda will.
[Re: Adam71Charger]
#1668717
09/08/14 10:22 AM
09/08/14 10:22 AM
Challenger 1
Cincinnati, Ohio
Say no to acid, there are better ways but takes more costly equipment but is more environmentally friendly to do it.imo. Acid makes it too hard to refinish before rust reappears and can harm some parts if not all of them, your forced to rinse with water and hope you get it all neutralized and your trying to get rust off in some cases and your using water to get rust off during the rinse?? Not for me...
[Re: Commando1]
#1668720
09/08/14 11:50 AM
09/08/14 11:50 AM
Challenger 1
Cincinnati, Ohio
the real issue is, how do you get rid of the stuff when you are done?
What came from the Earth, returns to the Earth...
We used to get some kind of acid in a 55 gallon drum and soak aluminum bbq grill half's in them to restore the grill. It was a freaken mess and we spent some big bucks to get rid of the half full drum of acid and slug when we gave up on the acid.
A steam pressure washer is the best tool for restorations of anything. The most environmentally friendly, safest solution for the operator and the part.
[Re: Commando1]
#1668721
09/08/14 12:01 PM
09/08/14 12:01 PM
Challenger 1
Cincinnati, Ohio
Acid does not come from the earth, it is a chemical and man made, unlike petroleum is what your thinking.
[Re: ahy]
#1668726
09/08/14 01:15 PM
09/08/14 01:15 PM
Adam71Charger
One thing to watch out for (in addition to safety!) is "hydrogen embitttlement". The acid leaves hydrogen in the metal which reduces strength, especially with repeated cyclic loading. Baking the part afterwards can get the hydrogen out... which is what a good plating house will do.
Slower methods like de-greaser, pressure wash, wire wheel do not introduce hydrogen. Hot tank is good for suspension parts also. Hot tank followed by abrasive blast is really nice.
Good point.. I will bake the parts too
[Re: dogdays]
#1668727
09/08/14 01:17 PM
09/08/14 01:17 PM
Adam71Charger
Elton John. Seriously.
Muriatic acid is another name for hydrochloric acid, and it is the acid that's in your stomach. It's one of the reasons that we need salt. The chloride ion that occurs when NaCl is dissolved in water is what the body uses to make the acid.
R.
Does that mean we can swallow small parts and bolts and clean them?
[Re: BigBlockMopar]
#1668729
09/08/14 01:28 PM
09/08/14 01:28 PM
Adam71Charger
I've been playing around with diluted Citric acid recently which works very nicely aswell to derust metals. If you're not in a hurry it will derust rusty metal in a couple of days.
Does the citric acid dissolve all the oils, grease, and heavy rust?
[Re: Supercuda]
#1668730
09/08/14 01:31 PM
09/08/14 01:31 PM
Adam71Charger
Im still confused about the neutralize part.. How do you neutralize? Do I mix the baking soda with the Muriatic Acide? or do I mix baking soda with water to dip the part in right after the acid bath?
[Re: Adam71Charger]
#1668731
09/08/14 01:35 PM
09/08/14 01:35 PM
dogdays
Have the baking soda bath ready for the parts, the minute you take the parts out of the acid.
If you try to neutralize the acid directly you will require a lot more soda and have to buy new acid for the next batch. But it could be done, just not cost effective and messy when the soda started to foam.
R.
But the real problem, as alluded to above, is that this is not a harmless way to remove rust. Acid does not stop with the rust, it keeps on going. Acid-dipping body parts was not done to derust them, but to thin them. It was a way to make a lightweight part, by "chemical milling" much of the metal off the part.
[Re: Andrewh]
#1668732
09/08/14 01:38 PM
09/08/14 01:38 PM
autoxcuda
So Cal
That was my issue that I realized right after pouring it out.
[Re: burdar]
#1668734
09/08/14 01:50 PM
09/08/14 01:50 PM
Andrewh
When the acid gets really dirty and you want to dispose of it, just add backing soda to it until it stops fizzing. Then you can just dump it.
lol. while it is no longer acidic. it is still not safe to just dump. you should still have your local garbage hazmat take it away. like paint and batteries.
[Re: burdar]
#1668736
09/08/14 02:24 PM
09/08/14 02:24 PM
Andrewh
Muriatic acid is marketed as a pool cleaner. When it's used for that purpose it's jut left to evaporate or rinsed with water.
sure, just pure, or mixed with water.
but what kind of goop came off in it when it was used for stripping parts?
you can't call that safe.
[Re: Adam71Charger]
#1668738
09/08/14 06:35 PM
09/08/14 06:35 PM
Posts: 8,273 fredericksburg,va
cudaman1969
fredericksburg,va
What ever container i make or use for my bath(mixture) Yes neutrlize in seperate tank to get in all the cracks, i use washing soda. USE outside!
[Re: cudaman1969]
#1668739
09/08/14 08:59 PM
09/08/14 08:59 PM
Supercuda
About to go away
About to go away
up yours
Oh, another hit against muriatic acid. Years ago I heard a loud bang in the garage. Went out to see what happened and nothing was obvious, till I later tried to open the door. The helper spring on one side broke. Turns out m wife had stored the remains of a gallon of muriatic acid she was sing to maintain the pool and the plastic container allowed it to leak/fume. The vapors rusted the spring out till it broke. Rusted out the freezer next to it too.
[Re: jcc]
#1668743
09/08/14 10:30 PM
09/08/14 10:30 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Need to be wary of what it is doing to the metal, and how much it is eating "the good stuff" away. I researched its use years ago when I was cleaning stuff for the Dart.
Guy over on BBD threw a set of rods in EvapORust (not sure what it is made of), but they had matching wrist pins (press in), he removed the rods, and the pins fell straight through the small end...
Disposal seems like it would be a PITA too. But to someones point above, once neutralized, is it really any different than the contents from a parts washer?
383, Hemi 4-Speed, AlterKtion, D60
[Re: jcc]
#1668744
09/08/14 11:17 PM
09/08/14 11:17 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
Iron, and the stuff you were going to scrape off anyways. Once neutralized, no big deal.
Maybe, although the neutralizing itself does little to remove potential heavy metal toxicity, and technically, its far from legal to dump or dispose of haphazardly of any of the waste product.
Virtually everything you stated is incorrect.
[Re: ademon]
#1668748
09/09/14 02:18 AM
09/09/14 02:18 AM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
Vinegar, an acid, will do the same thing as miratic. Albeit slower but light years safer for you and the environment. I had some tools that were left by my late father that had suffered flood waters following a hurricane. Some were badly rusted, some (the newer ones with chrome plating) not so bad. After soaking overnight, most cleaned up pretty good. The ones that were really bad, I left for an additional overnight soak. the rust was eaten away leaving them with a dark charcoal patina similar to the manifold pictured earlier in this thread. I even had a cresent wrench that was froze up before soaking. After with a shot of wd40, It worked like new. Yeah Miratic acid will take rust off fast but as has been suggested, its a hazardous waste. I don't have any worries pouring vinegar down the drain. Actually helps keep them clear too Disclaimer: I pour it through a funnel lined with cheese cloth to collect the solids. YMMV
[Re: BSB67]
#1668750
09/09/14 10:51 AM
09/09/14 10:51 AM
Posts: 22,696 Bitopia
jcc
Bitopia
We are talking about the location being in the US, in 2014, correct?
Care to stick around and back up that blanket statement?
So do you care to explain to us less informed how a heavy metal is rendered non toxic by a "neutralization"?
Or explain how any involved regulatory agency will turn a blind eye to haphazard disposal of the remnants/byproducts of a unregistered personal metal acid cleaning operation?
And explain how anybody here can tell with certainty what materials, surface or base metal alloys they are removing from a dirty item without any testing?
[Re: dogdays]
#1668754
09/09/14 04:16 PM
09/09/14 04:16 PM
jcc
Bitopia
Better put your tinfoil hat back on and look under the bed for the boogeyman!
There is a heck of a lot of difference between iron and "heavy metals".
Neutralized acid is just that, NEUTRALIZED. It's not acid any more. Where I live the soil is basic, adding acid to the soil can actually make things grow better. In other parts of the US, the soil is acidic. What do you thing forms when dead leaves soak in a puddle of water? Tannic acid. What do you think when pure rainwater falls through the air that has some carbon dioxide in it, as Al Gore is so fond of reminding us? Carbonic acid. Acids and bases occur everywhere in nature.
On the other hand, anyone who dumps the contents of a lead/acid battery is putting more lead into the environment and needs to have a .45 caliber lead injection to make him stop. That's real.
Moparts is the place where everything can be made much more difficult and cost-prohibitive if one listens to all the advice.
R.
Your answer did not disappoint me in more ways then you likely would understand, thank you.
And AndrewH, I believe heavy metals are a concern, what the part was plated with and likely removed by the acid, or what alloys were used in the base metal, could become a part of the waste stream, ie cadmium in the plating , chrome in stainless, lead residue inside the exhaust manifold, etc
[Re: jcc]
#1668755
09/09/14 09:29 PM
09/09/14 09:29 PM
cudaman1969
fredericksburg,va
All you safety nuts are a hoot. I'm in the wood industry and every day something new comes up that i say "Do What". The last one was safety data sheets on sandpaper. Man is such a terrible animal I guess we just should take the dead pill and be done with us all, or just go live in a cave and pick berries and nuts. We are talking 5 gallons at the most, worst stuff comes out of the air and runs off my roof. Heavy metals, what does it do when it just sets there and rusts? Its all about proportions,parts per million,take that 5 gallons and pour in the ocean,can you measure it? They put muriatic acid and chlorine in pools and your kids drink it, how they doing?
[Re: cudaman1969]
#1668756
09/09/14 09:59 PM
09/09/14 09:59 PM
Andrewh
again, this is not the same thing as using it to eat metal and rust away.
PURE HCL in a pool is just going to up the ph a bit. when it disassociates in water, you get H + and CL - which is not a harmful (in small enough amounts) item causing polution.
Where as the oil and gunk you are taking off these parts, mixing in with the HCL and converting to some sort of salt, CAN be harmful.
And yes, we aren't talking about thousands of pound YOU are generating by your self. but if every person did it, how much then?
your argument is the same thing that people used in the past to justify poising the environment. it doesn't hold water.
Now don't take me for an environmental wack job. I don't care if we burn the planet down. I don't conserve fuel, water or air. but I sure don't want to poison myself either if I could help it.
being the guy that baths in irradiated water after a nuke blast because you don't know it is bad for you is one thing.
being the guy that eats rat poison because red dye number 5 doesn't cause cancer anymore is just dumb.
[Re: cudaman1969]
#1668757
09/09/14 10:04 PM
09/09/14 10:04 PM
jcc
Bitopia
Name calling, and you just don't get it.
Next.
[Re: jcc]
#1668758
09/09/14 11:22 PM
09/09/14 11:22 PM
cudaman1969
fredericksburg,va
Sounds like you havn't used this before, i have to remove oil,grease, undercoating,"crud" before i dip the part in. I put that stuff on the highway with every other cars " crud". When done i put the acid solution back in plastic containers to use again for the next rusty part, to expensive to throw away. You guys can save the planet, i'll get the rust off my way.
[Re: jcc]
#1668759
09/09/14 11:45 PM
09/09/14 11:45 PM
BSB67
Prospect, PA
Sure.
First, you need to be clear what heavy metals are you talking about. Carbon steel and cast iron have very very little heavy metals of concern. Do you know what they are and common concentrations in acid baths? Do you know the valences? If you don't, saying things like it's toxic, or hazardous are meaningless statements.
Next, do you know the route of entry? For the very low concentrations of of these metals, in this form, ingestion is the only realistic route of entry. So, I would recommend not eating the stuff, and maybe washing your hands when you are done.
Finally, neutralization IS the treatment technology for the heavy metals that we are talking about. They precipitate and become insoluble hydroxides. To maximize the treatment, raising the pH to about 9.0 with your neutralizing agent will bring these heavey metals near the drinking water standards in the water phase.
If you are talking about acid cleaning long terne coated items (such as fuel tanks) or cadmium plated items, that would certainly be a different story. The concentration in the acid would be higher of a couple heavy metals, but the neutralization would still be effective.
I would not be an advocate of dumping the stuff on the ground, but bagging it up and disposing of it in your trash would be both legal and safe. If there are remaining neutralized liquids, the local POTW can easily manage that as well. If you are a business, you should probably conduct the appropriate leach test for liability reasons as your responsibilities are different than residential/homeowners.
[Re: autoxcuda]
#1668760
09/10/14 01:19 AM
09/10/14 01:19 AM
Scott Carl
Omaha, Nebraska
. . While gagging from momentarily opening and closing the ice chest with 3 gallons of 30% Muratic Acid.
I'm no save-the-earth-peta-global-warming's-gonna-be-the-end-of-human-exitance kinda guy myself, but it was this comment above that caused me to respond initially. If you don't care about the environment, at least care about your own body. Those fumes gag you for a reason. They are just as caustic as the liquid. AXC is lucky the outer layer of his eyeballs didn't shrivel up or his sinus linings didn't derust (burn and scar) Hard to drive our Mopars when we can't breathe or see.
Just say'n
Scott
[Re: Scott Carl]
#1668761
09/10/14 02:14 PM
09/10/14 02:14 PM
Supercuda
About to go away
About to go away
up yours
One wonders were some of you dispose of your oil filters?
Those definitely do contain heavy metals.
I am not worried about derusting iron/steel being a hazmat issue, it's not as long as you neutralize the acid. If you are seriously concerned about the non-liquid residual, rig a filtration system to filter it out of the neutralized fluid.
[Re: BSB67]
#1668762
09/10/14 02:56 PM
09/10/14 02:56 PM
jcc
Bitopia
Sure.
So what percentage, if any here, comprehend your statement: "Finally, neutralization IS the treatment technology for the heavy metals that we are talking about. They precipitate and become insoluble hydroxides. To maximize the treatment, raising the pH to about 9.0 with your neutralizing agent will bring these heavey metals near the drinking water standards in the water phase."
And if there is ANY stainless involved, with the OP's process, chromium is likely present in the process, and the the current federal water limits I believe for toxicity is, wait for it, 0.00ppb. You and I are the only ones who have even mentioned the complications of cadmium, the rest?
The arrogance of ignorance maybe comforting to some, but trying to understand a process beyond the immediate concerns of rust removal, I guess for many requires too much responsibility.
[Re: jcc]
#1668763
09/10/14 04:51 PM
09/10/14 04:51 PM
Supercuda
About to go away
About to go away
up yours
The arrogance of ignorance, lol. Mirror, perhaps?
STAINLESS STEEL. If you have enough rust on STAINLESS STEEL to need muriatic acid to clean it, well then it's not STAINLESS STEEL. Point is moot, if not a strawman.
Cadmium plating? That's there to do what? Prevent rust. Rust means it's not there, if it ever was. Another moot point, if not again a strawman.
Explain to us how this would be any different than sand blasting the crud off? How to you dispose of that?
[Re: Adam71Charger]
#1668764
09/10/14 05:23 PM
09/10/14 05:23 PM
Nuclear1
Good lord! Where, oh where should I begin on this one?.... As already mentioned, dilute Muriatic acid (HCl) will remove oxidized metal from iron parts (acetic acid is safer, but slower). It can also strip out certain metals in alloys, so that is one thing that needs to be mentioned. The hydrogen brittling effect is most prevelent in nickel containing materials, as you can form nickel hydrides, which are flammable. If the acid solution only contains the acid, it can be neutralized by the appropriate amount of a base to give a salt solution and water. This process can generate a lot of heat (exothermic). If the salt is non-toxic, then the dilute salt solution can be released into the environment if the laws allow for that type of disposal. If any toxic material is possibly present in the solution, then it must be handled as containing a toxic material. Oil and grease can cause enviornmental problems, so they must be disposed of properly and not just dumped into the ground. Used motor oil is different chemically than crude oil from the ground. There are carcinogens in used motor oil from heated hydrocarbon contact with metal surfaces inside of engines. One must always follow proper procedures when working with corrosive chemicals, including goggles, gloves, protective apron or suit to name a few. Acid baths must always have a spill zone around them to contain spills should they leak out. Never, ever put water into a concentrated acid container! The resulting exothermic reaction can spray out of the container and hit you (not to mention the vapors). This is just for starters. The list can go on and on for several more pages... My thanks to those who responded prevously on this topic with appropriate chemical answers.... Don't get me started on cadmium, mercury or lead in the above discussion. My PhD was in developing sensors to environmentally detect those metals....
[Re: jcc]
#1668765
09/10/14 11:49 PM
09/10/14 11:49 PM
BSB67
Prospect, PA
Sure.
The federal limits are certainly not 0.00 ppb for chromium. I think it is 50 ppb. If you really care, I'll look it up. Also, of all of the heavy metals, the valence of chromium is critical in determining its toxicity. Hexavalent chrome is considered toxic, trivalent is not. And guess what, ONLY trivalent chrome will exist in an acid solution in the presence of iron.
Finally, hydrochloric acid will not effectively remove an oxide from stainless. A combination of hydrofluoric, sulfuric and usually a very strong oxidizer, typically nitric acid (peroxide can be used but you'll need a higher concentration of the other acids) is needed. Normally done at 160 F along with mechanical scrubbing. Again, as stated earlier, neutralizing waste acid from acid cleaning stainless will result in meeting the standard.
Now HF will kill you. It is both a strong acid and very very toxic, and will absorb into the body on contact through your skin. H2SO4 can also be considerably more dangerous than HCl, depending on concentration.
I'm all for doing the right thing, but today's hysteria over everything being toxic is simply mis-information. In our 5 second sound bit society, we don't even bother with the details of science.
[Re: BSB67]
#1668766
09/11/14 02:39 AM
09/11/14 02:39 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Stay safe and be sane.
Number 1. Using acid to remove dirt, oil, and gunk is poor workmanship and a bad choice of methods. Better to use your wife's dishwasher with hot water and strong ammonia-containing soap or some other effective cleaning method.
Number 2. Insert only clean objects free of dirt, oil, and rust scale in a de-rusting chemical to preserve the strength and effectiveness of the chemical. It's a waste of the chemical to dissolve rust scale and cut oils that could have been easily removed.
Number 3. If you are trying to restore a piece of metal, generally speaking HCl is overkill and way too corrosive and unsafe. If the piece being restored has spot welds, HCl left in the cracks can keep on corroding and pop the welds. Something a lot less potent, such as vinegar or Evapo-Rust will get the job done effectively and safely. Yes, one of these is not cheap, but if you use good workmanship and follow Number 2 above, you won't waste it.
Number 4. Remove any object from any rust removing chemical immediately as soon as de-rusting is accomplished.
[Re: 62maxwgn]
#1668767
09/11/14 02:56 AM
09/11/14 02:56 AM
Posts: 10,693 Surface of the Sun, AZ
Hotwheelsjr
And another for what it's worth,don't let any sit in an open container,it will give a surface coat of rust to anything within six feet or more and thats a fact !!
Six feet? LOL! I wish it was only six feet. I left a plastic watering can with a smidgen left in the bottom in my garage over night (I had cleaned my driveway with it). The fumes flash rusted EVERY bare piece of metal in my garage, including the entire stripped front clip of my '72 Satty. I had already blasted the trunk floor and front floor pans too...yup, flashed. Pissed me off so bad I haven't touched the Satty in months and I'm now selling it. All that work sand blasting with a Harbor Freight blaster with about an inch wide spread, just to have it all flashed in a single night.
[Re: kentj340]
#1668768
09/11/14 07:14 AM
09/11/14 07:14 AM
Adam71Charger
1. It's not a bad method. It's just a method. 2. The whole point of the acid bath was to remove dirt oil and rust. 3. Driving a car is unsafe. Having sex is unsafe. Flying in a plane is unsafe. playing football is unsafe. All one can do is to be as safe as possible doing any of these things, and it's no different when using chemicals to clean metal, wood, or anything else. Also, the parts Im dipping have no welds. 4. Agreed.
From now on I will be neutralizing my acid when finished. I dont mind disposing of it at the dump's hazardous chemical hut. But there is also a free oil dump at one of the local parts stores. In this oil dump, you can dispose used motor oil that is full of carcinogens, metals, dirt and water.
If I neutralize the acid bath after use, it too should contain dirt, oil, water and bits of metal right? So shouldn't this qualify as acceptable to dump in the used oil dump at the parts store?
[Re: Adam71Charger]
#1668769
09/11/14 12:15 PM
09/11/14 12:15 PM
Nuclear1
No. The metals/metal oxides and dirt is not the problem. (It would also contain salts, but again they would not be a problem either.) The reason why is because it only contains a small amount of oil (hydrocarbons) and a lot of water in the solution. As we all learned in grade school science classes, oil and water will not mix, they separate into layers given enough time (unless acted upon by detergents, which interacts with both layers). Where the layers sit depends upon the densities of the materials. Recycling companies do not want to mess with used oil that has been contaminated with large quantities of water and not properly separated. If you separated (ie. decanted off) the oil layers from the cleaning process and disposed of them in the used oil recycling container, that is fine. But, you cannot just dump all of the aqueous solution in there as well. You will become liable for the disposal costs if you do so. Open your wallet wide if that happens....
[Re: BSB67]
#1668770
09/11/14 12:43 PM
09/11/14 12:43 PM
Nuclear1
HF (hydrofluoric acid) is actually a weak acid (pKa = 6.8X10^-4), but it can etch (ie. digest) glass. [The larger the pKa value, the more it will ionize in water which leads to its acid strength via the formation of the hydronium ion, H3O+(aq).] Hydrofluoric acid is used as such in glass/mirror shops, although they tend to favor the active paste salts in usage. H2SO4 (sulfuric acid) is stronger than HF because it can ionize in solution to approximately 100% ions. So, each molecule of H2SO4 generates 2 molecules of hydronium ions in water. HNO3 (nitric acid) can also ionize 100%, as well as the dreaded HClO4 (perchloric acid). I do not handle perchloric acid unless I absolutely have to, as it can eat flesh to the bone (even after flushing with copious amounts of water) unless neutralized with the right base. It also forms explosive metal perchlorate salts upon contact with nearby metal surfaces. Only those who are properly trained in safely handling such materials should be using said materials in the first place....
Yes, chemicals tend to get a bad reputation in the media. One thing I teach in my chemistry classes is that there are no "bad" chemicals. It all depends on how they are being used and why. The key to the message is to not fear chemicals (as the media would like), but to respect what they can do by learning about them....
If you do not know how to handle a certain chemical, it is better to leave it to the professionals who do....
[Re: Adam71Charger]
#1668771
09/11/14 02:40 PM
09/11/14 02:40 PM
Scott Carl
Omaha, Nebraska
Bold text: Your not doing it right
[Re: Adam71Charger]
#1668772
09/12/14 02:37 AM
09/12/14 02:37 AM
kentj340
Cut and Shoot, TX
Like Grandma's lye soap, heavy duty soaps tend to be alkaline, the opposite of an acid. Never heard of any acid soap.
Maybe there's a reason for that, but I'm not a chemist.
[Re: Nuclear1]
#1668773
09/12/14 07:05 AM
09/12/14 07:05 AM
Posts: 9,654 Southern by Choice
Shoozy
I have a foot fetish
Southern by Choice
Nuke 1, I'm certainly not a chemistry teacher but I have worked with these things daily for 38 years. To say that HF acid is weak may be misleading to those reading this. It is the most dangerous to humans of any listed here so far (nitric is close), such that even our drivers have to carry calcium gluconate to transport factory sealed drums of it. Exposure without treatment can lead to death within 24 hours or so. So perhaps "weak" as in ability to eat things but "lethal" as in human contact might be a better description? Again, not trying to split hairs here, just trying as always to keep members from getting hurt or worse.
Old, tired, and sometimes broke down. Me, not my car...
[Re: Shoozy]
#1668774
09/12/14 09:04 AM
09/12/14 09:04 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
HF is one of those fascinating albeit terrifying chemicals. You spill it on you, treat it immediately by flushing, think OK, it's not burning. Yet, up to 8 hrs later, you may start burning, blistering, getting your lungs full of water, muscle spasms, even death when untreated. It does not stop reacting. And you brush your teeth with Fluoride!
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
[Re: Shoozy]
#1668775
09/12/14 11:55 PM
09/12/14 11:55 PM
Nuclear1
Sorry for the late reply, I have been tied up all day with a outcomes meeting for chemistry coursework. You are absolutely correct that HF is dangerous to handle and I thank you for pointing that out on here. I do not want someone thinking that they can substitute HF for HCl in an acid bath without serious consequences.... What I was implying in my above post was that HF is a weakly ionizing acid in water compared to other acids, not that it is not dangerous to humans upon contact. I should have worded it better in the above post. (Chemists measure acid strength by how much the acid can form ions in solution: pKa disassociation values listed in tables from measurements. HCl is stronger in acid strength than HF in this manner. That does not mean that HF is less harmful than HCl though, even in diluted forms.) HF can remove the calcium from bones over time upon contact with flesh if not treated quickly enough. In comparison with perchloric acid, HF and HClO4 are both deadly if used wrong, but HClO4 can also explode when it comes into contact with many other commonly found chemicals. It can form explosive vapors if the bottle is not sealed properly in storage if not sequestered in a separate acid cabinet made only for HClO4 (can not be made of wood). On the old diamond scale found on many MSDS, HClO4 had a reactivity rating of a 3 (severe), while HF only had a 1 (minor) because of this issue. Both had a rating of 3 or higher on health, depending upon the purity of the solution tested, meaning that they need to be respected for what they can do. Either one of those acids is better left to trained professionals....
[Re: Nuclear1]
#1668776
09/13/14 11:54 AM
09/13/14 11:54 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
It's so much easier to use electrolysis.
Have a battery charger? Have a piece of scrap metal?
Grab a tub and some washing soda. Plug it in and make it work.
Just don't use stainless steel as an anode.
[Re: feets]
#1668777
09/13/14 01:21 PM
09/13/14 01:21 PM
cudaman1969
fredericksburg,va
I was thinking about using that process but not sure it would work on the inside of my frame rail being that its closed except on the ends with bulkheads in the middle.
