Page 2 of 4 1 2 3 4
Re: muriatic acid bath! [Re: dogdays] #1668727
09/08/14 01:17 PM
09/08/14 01:17 PM
Tacoma, Washington USA
Adam71Charger Offline OP
Elton John. Seriously.
Muriatic acid is another name for hydrochloric acid, and it is the acid that's in your stomach. It's one of the reasons that we need salt. The chloride ion that occurs when NaCl is dissolved in water is what the body uses to make the acid.
R.
Does that mean we can swallow small parts and bolts and clean them?
Re: muriatic acid bath! [Re: Adam71Charger] #1668728
09/08/14 01:21 PM
09/08/14 01:21 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Oh the jokes and puns that are to follow...
"I think its got a hemi"
Re: muriatic acid bath! [Re: BigBlockMopar] #1668729
09/08/14 01:28 PM
09/08/14 01:28 PM
I've been playing around with diluted Citric acid recently which works very nicely aswell to derust metals.
If you're not in a hurry it will derust rusty metal in a couple of days.
Does the citric acid dissolve all the oils, grease, and heavy rust?
Re: muriatic acid bath! [Re: Supercuda] #1668730
09/08/14 01:31 PM
09/08/14 01:31 PM
Vinegar is acetic acid, I don't think it'll neutralize muriatic. Baking soda will.
Im still confused about the neutralize part.. How do you neutralize? Do I mix the baking soda with the Muriatic Acide? or do I mix baking soda with water to dip the part in right after the acid bath?
Re: muriatic acid bath! [Re: Adam71Charger] #1668731
09/08/14 01:35 PM
09/08/14 01:35 PM
dogdays Offline
dogdays  Offline
Have the baking soda bath ready for the parts, the minute you take the parts out of the acid.
If you try to neutralize the acid directly you will require a lot more soda and have to buy new acid for the next batch. But it could be done, just not cost effective and messy when the soda started to foam.
R.
But the real problem, as alluded to above, is that this is not a harmless way to remove rust. Acid does not stop with the rust, it keeps on going. Acid-dipping body parts was not done to derust them, but to thin them. It was a way to make a lightweight part, by "chemical milling" much of the metal off the part.
Re: muriatic acid bath! [Re: Andrewh] #1668732
09/08/14 01:38 PM
09/08/14 01:38 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
the real issue is, how do you get rid of the stuff when you are done?
That was my issue that I realized right after pouring it out.
Re: muriatic acid bath! [Re: Adam71Charger] #1668733
09/08/14 01:39 PM
09/08/14 01:39 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Mix up some baking soda in water so there is soda in the bottom of the container. Once the parts come out of the acid, dip them in the backing soda water to neutralize the acid. If you then dunk them in evaporust for a short time, the parts won't flash rust and your evaporust will last a long time.
When the acid gets really dirty and you want to dispose of it, just add backing soda to it until it stops fizzing. Then you can just dump it.
Re: muriatic acid bath! [Re: burdar] #1668734
09/08/14 01:50 PM
09/08/14 01:50 PM
Andrewh Online content
Andrewh  Online Content
lol.
while it is no longer acidic. it is still not safe to just dump.
you should still have your local garbage hazmat take it away. like paint and batteries.
Re: muriatic acid bath! [Re: Andrewh] #1668735
09/08/14 01:53 PM
09/08/14 01:53 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Muriatic acid is marketed as a pool cleaner. When it's used for that purpose it's jut left to evaporate or rinsed with water.
Re: muriatic acid bath! [Re: burdar] #1668736
09/08/14 02:24 PM
09/08/14 02:24 PM
sure, just pure, or mixed with water.
but what kind of goop came off in it when it was used for stripping parts?
you can't call that safe.
Re: muriatic acid bath! [Re: Adam71Charger] #1668737
09/08/14 02:31 PM
09/08/14 02:31 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Electrolytic is the way to go ....safe and works great http://www.instructables.com/id/Electrolytic-Rust-Removal-aka-Magic/
Re: muriatic acid bath! [Re: Adam71Charger] #1668738
09/08/14 06:35 PM
09/08/14 06:35 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I just put my e-body frame rail in my bath, i make forms to fit, been doing this for many years. I mix one gallon acid with 4 gal. vinegar and 4 gal. water. Cheaper this way but takes a little longer. Make sure you use a neutralizer to keep fron rusting back fast.
Do you mean your bathroom Bath-tub?
What ever container i make or use for my bath(mixture)
Yes neutrlize in seperate tank to get in all the cracks, i use washing soda.
USE outside!
Re: muriatic acid bath! [Re: cudaman1969] #1668739
09/08/14 08:59 PM
09/08/14 08:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Oh, another hit against muriatic acid. Years ago I heard a loud bang in the garage. Went out to see what happened and nothing was obvious, till I later tried to open the door. The helper spring on one side broke. Turns out m wife had stored the remains of a gallon of muriatic acid she was sing to maintain the pool and the plastic container allowed it to leak/fume. The vapors rusted the spring out till it broke. Rusted out the freezer next to it too.
Don't be the exception.
Re: muriatic acid bath! [Re: Supercuda] #1668740
09/08/14 09:28 PM
09/08/14 09:28 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And another for what it's worth,don't let any sit in an open container,it will give a surface coat of rust to anything within six feet or more and thats a fact !!
Re: muriatic acid bath! [Re: Andrewh] #1668741
09/08/14 09:46 PM
09/08/14 09:46 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Iron, and the stuff you were going to scrape off anyways. Once neutralized, no big deal.
Re: muriatic acid bath! [Re: BSB67] #1668742
09/08/14 10:16 PM
09/08/14 10:16 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Maybe, although the neutralizing itself does little to remove potential heavy metal toxicity, and technically, its far from legal to dump or dispose of haphazardly of any of the waste product.
Re: muriatic acid bath! [Re: jcc] #1668743
09/08/14 10:30 PM
09/08/14 10:30 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Need to be wary of what it is doing to the metal, and how much it is eating "the good stuff" away. I researched its use years ago when I was cleaning stuff for the Dart.
Guy over on BBD threw a set of rods in EvapORust (not sure what it is made of), but they had matching wrist pins (press in), he removed the rods, and the pins fell straight through the small end...
Disposal seems like it would be a PITA too. But to someones point above, once neutralized, is it really any different than the contents from a parts washer?
383, Hemi 4-Speed, AlterKtion, D60
Re: muriatic acid bath! [Re: jcc] #1668744
09/08/14 11:17 PM
09/08/14 11:17 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Virtually everything you stated is incorrect.
Re: muriatic acid bath! [Re: BSB67] #1668745
09/09/14 12:26 AM
09/09/14 12:26 AM
I dump it on the side of my house that I'm turning into a gravel parking area. There is no Water or electrical piping in that area. Considering the fact I was already buying Casoron crystals to prevent any plant growth under the gravel, Im not worried about the neutralized acid seeping into the area. I'm not a biologist, but I'm pretty sure that the area is flat enough, and far enough away from any water/drain sources that it wont be a problem.
Re: muriatic acid bath! [Re: Adam71Charger] #1668746
09/09/14 12:59 AM
09/09/14 12:59 AM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Your dissolving your house for more parking?
Page 2 of 4 1 2 3 4
