Shake down Duster w/Indy 440-1 heads #1668600
09/07/14 07:10 PM
09/07/14 07:10 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline OP
Want to send another “Good Guy” out to Bob George!! Took the Duster to Quaker today to make some shake down runs. Just getting broke in, only had a few pulls on it.
1st pass it went 10.46 @ 123 60’ 1.41. Not bad for all new stuff, no bangs or misses whatsoever. Track wasn’t that good today, prep wasn’t up to par.
2nd pass it went 10.44 @ 124 60’ 1.38. Picking up, but still a bit off.
Both passes it was black out of the pipes, seems a bit rich. Timing was still at 37 degrees as well. Motor is still a bit tight, but sounded great going thru the passes.
Still want to remind everyone to remember Bob George for you engine parts & work. Was so patient w/me as I changed things a 100 times. Sorry to have to miss Norwalk, but all funds went into getting the car back together. Any input from others w/Indy 440-1 parts would be great.
Thanks, Ken Michalik
Re: Shake down Duster w/Indy 440-1 heads [Re: 1974 474 Duster] #1668601
09/07/14 07:21 PM
09/07/14 07:21 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Congrats man!
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Shake down Duster w/Indy 440-1 heads [Re: 1974 474 Duster] #1668602
09/07/14 07:27 PM
09/07/14 07:27 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
whats your the combo /weigth
511 ci
13.1 comp 440-1 277/800 comp cam 1050.... 9.91
with tunnelram two 750s ....... 9.85
3400 duster
1.39 9.85 - 137 mph
Re: Shake down Duster w/Indy 440-1 heads [Re: 1974 474 Duster] #1668603
09/07/14 07:28 PM
09/07/14 07:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If its putting out black from the pipes start jetting
it down till the MPH falls off... start out at 2 jet
sizes all around
Re: Shake down Duster w/Indy 440-1 heads [Re: MR_P_BODY] #1668604
09/07/14 08:40 PM
09/07/14 08:40 PM
474 short block. Ultra-Dyne .613 flat tappet. 1050 Dominator. TTI 2" to 2 1/8" headers. did not cc for compression, rough # is 12.5
car is 3100#
Re: Shake down Duster w/Indy 440-1 heads [Re: 1974 474 Duster] #1668605
09/07/14 11:23 PM
09/07/14 11:23 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Ken it was nice to finally meet you today. The car was running good for first time out and can do nothing but get better. Too bad you can't make Norwalk but thats understandable. See you at a track somewhere
Russ
Re: Shake down Duster w/Indy 440-1 heads [Re: 1974 474 Duster] #1668606
09/08/14 06:12 AM
09/08/14 06:12 AM
gregsdart Offline
gregsdart  Offline
Looks like your top end mph is off a couple. Could be a lot of things, as the 60 fts don't look bad for the ET. How high is the trap rpm and cam duration #s?
Re: Shake down Duster w/Indy 440-1 heads [Re: gregsdart] #1668607
09/08/14 12:43 PM
09/08/14 12:43 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Try pulling the timing back to 35 degrees.Also if you do not already have them try a set of Champion C57CX or Autolite AR3932 plugs.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Shake down Duster w/Indy 440-1 heads [Re: MRMOPAR622] #1668608
09/08/14 01:21 PM
09/08/14 01:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
are the heads ported?
Re: Shake down Duster w/Indy 440-1 heads [Re: Quicktree] #1668609
09/08/14 04:43 PM
09/08/14 04:43 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Should be a 9.?? sec, car when you get it dialed in. Right now your MPH is off compared to your ET. But, you ran at Quaker where the track has a noticeable incline at the finish, so that might be where the MPH was lost. Nice first outing though.
Re: Shake down Duster w/Indy 440-1 heads [Re: Sport440] #1668610
09/08/14 04:56 PM
09/08/14 04:56 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Shoelaces are too tight.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Shake down Duster w/Indy 440-1 heads [Re: DusterDave] #1668611
09/09/14 02:53 AM
09/09/14 02:53 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Dave, what are your thoughts, besides shoelaces?
Re: Shake down Duster w/Indy 440-1 heads [Re: Sport440] #1668612
09/09/14 07:01 AM
09/09/14 07:01 AM
Q
Quicktree Offline
Quicktree  Offline
Q
he will say it needs mire polish
Re: Shake down Duster w/Indy 440-1 heads [Re: 1974 474 Duster] #1668613
09/09/14 09:56 AM
09/09/14 09:56 AM
ill
dennismopar73 Offline
ill
Several tunning issues i see
The blowing out black smoke can be jets but bet my money on high floats and way
to much fuel pressure .
7.5-8# of fuel pressure to the bowls is enough! Any more and the needle n seats blow
over down track
Plugs have very little to do with this unless the amount of voltage is very low going
to the coil thus low fire to plug doubtfull
Shift points i could see in the area of 65-6800
Timing at 37 maybe ok
I would be in the 34-36 range
More worried about his converter tho
MPH way off but if its blowing out black mph will be way off
Be helpfull to know gears and what rpm he is going thru traps at
3100# car 474 should be 9.80-9.90 car 130 plus
When he is done
Re: Shake down Duster w/Indy 440-1 heads [Re: Sport440] #1668614
09/09/14 10:45 AM
09/09/14 10:45 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Sorry, I was in a silly mood!
Re: Shake down Duster w/Indy 440-1 heads [Re: DusterDave] #1668615
09/09/14 12:35 PM
09/09/14 12:35 PM
gregsdart Offline
gregsdart  Offline
I have fully ported 440-1 heads, 528 cubes, 7100 best shift point with a TF. I am betting you will need to buzz yours a bit more to get the most out of it, that is if the cam/springs will cooperate.
Re: Shake down Duster w/Indy 440-1 heads [Re: DusterDave] #1668616
09/09/14 12:38 PM
09/09/14 12:38 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
The plugs make more different than you would think in these type Indy headed engines.But more than likely won't cure the to rich problem,but best to get the right plugs in it before making changes that you may not need.Pulling the timing down will help the mph.I'm sure you already have a good dist.,coil & MSD box they are a must for engines like these.I have run Indy headed engines since a teenager when they 1st come out in the early 80's.
Make sure you have a good scoop or cowl hood where the carb. can pull enough air.When you have all these base's covered then jet the carb. like Mr_P suggested!Take your time & make 1 change at a time till you get it perfect and you won't regret it.
PS you can go on a T&T night and make several changes 1 at a time in one night!Good Luck
Re: Shake down Duster w/Indy 440-1 heads [Re: Quicktree] #1668617
09/09/14 01:04 PM
09/09/14 01:04 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I would guess no.
Mopar Performance
Re: Shake down Duster w/Indy 440-1 heads [Re: moparniac] #1668618
09/09/14 05:56 PM
09/09/14 05:56 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Your car would be 2 tenths quicker at Thompson IMHO...Quaker is very slow.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Shake down Duster w/Indy 440-1 heads [Re: Eric] #1668619
09/09/14 06:15 PM
09/09/14 06:15 PM
Akron, Ohio
ProSport Online content
ProSport  Online Content
Akron, Ohio
Ken, what heads did you run before and what ET did they run?
If your 440-1 heads are not ported they may not live up to your expectations until you get them ported. My Dart ran 9.80's with -1's but I had 500 inches and a roller cam, but the cam was for pump gas so it bled off alot of compression. They only flowed 320 at 700 also, so I was leaving alot on the table there as the newer ported -1's flow much better.
