rally wheel center cap hole ? #1668336
09/07/14 03:27 AM
09/07/14 03:27 AM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
Hey guys so I picked up some center caps for a set of steelies I'm cooking up but these particular ones have a large hole in the very center ( these aren't the cone shape hub style but the ones that look more like a large nut ) I'm not knowledgeable in the years what style is what . I've been looking for caps that I'm sure go in the holes but I can't find them ! I've seen some but there not clear as to what style of rally cap they are for . Any one did this before ?
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
Re: rally wheel center cap hole ? [Re: gogo318] #1668337
09/07/14 12:07 PM
09/07/14 12:07 PM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
Research update ....so I'm assuming that the rallye caps I'm talking about are called acorn style and were on 72 and later mopars these particular ones are big bolt pattern and a large majority were one piece castings BUT some were made with a removable cap or plug that went in the centers and are frequently missing hopefully this helps give a better idea of what I'm referring to
Re: rally wheel center cap hole ? [Re: gogo318] #1668338
09/07/14 08:26 PM
09/07/14 08:26 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
The ones you are talking about I believe were used in 1975-up....72-4 were solid...
Re: rally wheel center cap hole ? [Re: QuickBpBp] #1668339
09/07/14 11:18 PM
09/07/14 11:18 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
What year car are you wanting to use these caps on?
Re: rally wheel center cap hole ? [Re: QuickBpBp] #1668340
09/08/14 12:41 AM
09/08/14 12:41 AM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
you may be right about that and I'm putting them on a 73 scamp I'm not very concerned with period correctness I just think the car would look good with rallyes
Re: rally wheel center cap hole ? [Re: gogo318] #1668341
09/11/14 12:45 PM
09/11/14 12:45 PM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
Any one ?
Re: rally wheel center cap hole ? [Re: gogo318] #1668342
09/11/14 01:39 PM
09/11/14 01:39 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
The caps with the center plug were at least after 74. Why they re-tooled them, after using the caps without the plug is beyond me. I doubt anyone is re-popping the center plug that you need. It would probably be cheaper and easier to find a different set of the acorn style caps without the center plug, as they seem to be a lot more plentiful.
