Re: 440 source sheet metal valve covers
[Re: 383man]
#1668241
09/07/14 11:25 PM
09/07/14 11:25 PM
Posts: 6,351 Aurora, Oh.
max_maniac
Aurora, Oh.
I have not used the 440Source covers but bought these from Mancini for about $120. These work nice for me as I really like them. Ron
Thats what I have on mine and fit nice and look good too!!
Russ
[Re: ProSport]
#1668243
09/08/14 06:03 PM
09/08/14 06:03 PM
Posts: 741 Carson City, NV
440sourcedotcom
Carson City, NV
I've used these, same thing only cheaper.
http://www.ebay.com/itm/Mopar-Chrysler-B...57c&vxp=mtr
They are not the same thing, not by a mile. Ours are 100% made in the USA, those ebay ones are from China. Ours use a super thick 3/8" billet rail, those use a 1/4". Our rail is CNC surfaced after welding (welding WILL distort the covers slightly), the Chinese ones are not.
Compare the pictures, you can see they are completely different products.
[Re: mopar65]
#1668246
09/09/14 01:56 PM
09/09/14 01:56 PM
Posts: 427 Sweden
Mopar Guy
Sweden
on your valve covers, can you move the drivers side breather hole to the front of the engine? I ask is because i have a big block Abody and the hole at the rear of the valve cover puts it close to the brake master cylinder.I would have lots more room if it was in the front. thanks Mopar65
You will have to drill the hole your self were ever you wish to have the pcv or breather in those covers and you will never look back cause they are the best and invest in the Morosso valve cover gaskets that have a steel core and real rubber in blue and you will have no leaks and can take them of as mutch as you whant !
[Re: Mopar Guy]
#1668247
09/27/14 11:07 PM
09/27/14 11:07 PM
Posts: 4,679 On the parachute mount
n20mstr
Well, I got them, they are very nice....but they don't fit. Going to need some grinding on the flange, prob need to take off .125 . Then prob have to taper it back.
....BAD A$$ STREET CAR.....
