Z,Z,Z,Z,Z .. local Sleeper #1667350
09/03/14 07:35 PM
09/03/14 07:35 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: bigdad] #1667351
09/03/14 07:36 PM
09/03/14 07:36 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: bigdad] #1667352
09/03/14 09:37 PM
09/03/14 09:37 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
It is begging for some tubing and four more cylinders.
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: bigdad] #1667353
09/03/14 09:44 PM
09/03/14 09:44 PM
Alberta, Canada
300rag Offline
300rag  Offline
Alberta, Canada
Here's one of our local sleepers
Peter
'65 300 'vert 413/4spd
'18 Challenger R/T Shaker
'19 Durango R/T
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: tubtar] #1667354
09/03/14 10:41 PM
09/03/14 10:41 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
365rwhp and 2300lbs with driver. 904 and 8in rear with 3.80 gears
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: bigdad] #1667355
09/04/14 12:56 AM
09/04/14 12:56 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
That power is nothing for a 4G63! stock crank, block and head are capable of 1000whp
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: SpareParts] #1667356
09/04/14 10:35 AM
09/04/14 10:35 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I had this one with a 6 bolt 4g63, ran high sevens in the 1/8th, about 340 AWD hp to the wheels @ 26psi.
Had a 2 step stutter box that would let me clutch dump it at 4800 RPM and about 7psi with my foot on the floor.
WIZE
In Car:
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: Streetwize] #1667357
09/04/14 10:36 AM
09/04/14 10:36 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
motor
WIZE
In Car:
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: bigdad] #1667358
09/04/14 06:27 PM
09/04/14 06:27 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Love it, is that a for sale sign or a license plate in the front window?
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: bigdad] #1667359
09/04/14 07:26 PM
09/04/14 07:26 PM
I'm assuming that is a early Colt and a later model [Edited by Moparts - Family Friendly Site - Keep it clean] motor, Yes? If so what motor is that? I put a imported from Japan twin overhead cam twin carb. Toyota 1600 CC TG motor(that looked like that motor in that car) in my Daughters 1976 Toyota Corrolla, it was rated at 125 HP. It was still slow
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: Cab_Burge] #1667360
09/04/14 07:34 PM
09/04/14 07:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
BUT Cab ... you werent using BOOST... thats with a
turbo
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: Streetwize] #1667361
09/04/14 07:53 PM
09/04/14 07:53 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
They are fun. One of my friends holds the DSM record for an HX35 in a daily driver that he built and tuned, drives it to the track and has been 10.07, then .09, then .07 again (for those who say they aren't consistent)
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: MR_P_BODY] #1667362
09/05/14 01:22 AM
09/05/14 01:22 AM
turbo
I realised that there was no boost, my main question is what type and size motor is that, Mitisbushi, Toyota, Honda, BMW or what? I see the turbo pipes,blow off valves, intercooler and so on. There was a Mitsisbushi 4 door sedan front wheel drive 4 cylinder that was turboed and caged that ran high fives in the 1/8 mile here several years back, way faster than my 700 HP pump gas Duster was back then Big is best(power, HP and traction) and lightweight is right when it comes to racing anything
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: Cab_Burge] #1667363
09/05/14 01:25 AM
09/05/14 01:25 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Cab it is a 4 cylinder Mitsubishi 4G63 motor. They were NA and turbo and used in just about every DSM vehicle in the 90's
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: Cab_Burge] #1667364
09/05/14 01:29 AM
09/05/14 01:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I believe that is just the Mitsi engine just turned
north south
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: MR_P_BODY] #1667365
09/06/14 04:30 AM
09/06/14 04:30 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'd guess with the intercooler and blow off valve it's hiding a turbo. 365RWHP @2300lbs is low 10's if it hooks and the tune,converter are right. Not a badass but still cool.
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: goldmember] #1667366
09/06/14 11:14 AM
09/06/14 11:14 AM
I'd guess with the intercooler and blow off Not a badass but still cool.
DUDE, that 4 cylinder street car is definetily BAD AZZ in my book
Re: Z,Z,Z,Z,Z .. local Sleeper [Re: Cab_Burge] #1667367
09/06/14 02:14 PM
09/06/14 02:14 PM
Central NC
gch Offline
gch  Offline
Central NC
I bet that thing wipes azz on the street.
