Small Block W-2 Rockers #1666966
09/02/14 07:00 PM
09/02/14 07:00 PM
Muncie
Racebuddy Offline OP
Muncie
Ok, sad to say but I just busted one of my Norris rockers. An intake "left offset".
Can a guy get a replacement rocker or two to match them??
got a crane gold replacement, hate to go aluminum with a new set. Anything good out there for 600-700 bucks??
I know all about Harland -Sharp and ICH stuff, trying to keep things well below 1200 bucks.
What are my options and what else is there to look at??
Re: Small Block W-2 Rockers [Re: Racebuddy] #1666967
09/02/14 08:17 PM
09/02/14 08:17 PM
In a house near you
Street Monkies Offline
In a house near you
Well thanks to the intake offset on the W2 the price has just now doubled. The cheapest way to go would to actually pick up a set of bushed iron rockers and run them. There are members on here that have been running them for lots of years and no issue. If you have to have a roller rocker if it's a bigger more agressive camshaft your options are kind of limited and really nothing is cheap. Sometimes guys can come across some Erson rockers. There is the Mopar blue rockers which is like a crane gold but I think the blues are better. Pretty much the rest of them are 1,000 and on up. I've wondered about converting a W2 to like a stud mount rocker setup and use chevy rockers like on the eddy magnum heads. The setup might not be as nice but certainly alot more cost friendly. Just my
Re: Small Block W-2 Rockers [Re: Racebuddy] #1666968
09/02/14 08:48 PM
09/02/14 08:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry.. I cant help with any cheaper rockers... I switched
to T&D on all my stuff... and no they arent cheap
but they may be the best... I do have some of the MP
blue ones that I have been holding on to for a cheaper
build project
Re: Small Block W-2 Rockers [Re: Racebuddy] #1666969
09/02/14 09:54 PM
09/02/14 09:54 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
I got a few used Norris 1.5 rockers around , some left some right and some exhaust..pm me if interested and I will see what I got,,
Re: Small Block W-2 Rockers [Re: Plymouth340] #1666970
09/03/14 09:49 PM
09/03/14 09:49 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
I have a full set of what I believe are Crower. One broken rocker. I sent them to T&D to have then ratio checked to match new rockers and they said they were 1.65's. Had the whole set listed for about $500
Re: Small Block W-2 Rockers [Re: MR_P_BODY] #1666971
09/04/14 08:53 PM
09/04/14 08:53 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Mr.P Any chance you have 4 spare right offset 1.5 mopar
blue rockers? thanks Mike
sorry for hijack
Re: Small Block W-2 Rockers [Re: mkdart] #1666972
09/04/14 09:08 PM
09/04/14 09:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
sorry for hijack
Let me take a look tomorrow
Re: Small Block W-2 Rockers [Re: MR_P_BODY] #1666973
09/15/14 12:14 PM
09/15/14 12:14 PM
Muncie
Muncie
replaced the broken Norris rocker with a Crane gold rocker.
the motor sounds like crap. It has a miss for sure. wondering if I could have bent a valve when the rocker broke or if the Gold rocker is different ratio and the one "off" rocker is upsettting the motor?
Re: Small Block W-2 Rockers [Re: Racebuddy] #1666974
09/15/14 12:16 PM
09/15/14 12:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do a compression check
Re: Small Block W-2 Rockers [Re: Street Monkies] #1666975
09/15/14 04:08 PM
09/15/14 04:08 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
I have checked this on Largeport commando heads, and there will be the issue with side loads. To avoid the sideload the valve needs to be angled (canted) parallell to the pushrod. Or, you must fabricate something for the rocker to guide against sideways. You also need a stud boss that is offset; maybe a steelplate can be made to hold it. I guess there is so much work to this that making some offset rockers could be simpler. Ask a local hobby blacksmith if he can forge something that can be machined to a rocker. My
