Best Headers F Body #166632
12/12/08 07:19 PM
12/12/08 07:19 PM
Toronto Ontario
Butt Ugly Offline OP
Toronto Ontario
Think the wagon needs some headers
Looking for some info on the best, ease of install, best performance.
360 volare 4 gear with power stearing and breaks.
Faster Horses, Younger Women, Older Wiskey, More Money --- Tom T
Re: Best Headers F Body [Re: Butt Ugly] #166633
12/13/08 12:33 AM
12/13/08 12:33 AM
I've got a 77 Volare with a 340. I used the E-body TTI headers. Great fit you don't have to unhook the steering at all. Expensive but they work
Re: Best Headers F Body #166634
12/13/08 07:06 AM
12/13/08 07:06 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I use TTI E-body headers also, had to take an inch off the lower part of the z bar and use the longer rod kit, but have also used B body ones also..
Re: Best Headers F Body [Re: quick77rt ] #166635
12/13/08 02:56 PM
12/13/08 02:56 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
The $120 Hedmans fit very well my '77 360/4-speed. The paint will burn off as soon as you fire the engine, but the fit was great.
Re: Best Headers F Body [Re: In_The_Pink] #166636
12/13/08 05:27 PM
12/13/08 05:27 PM
Toronto Ontario
Toronto Ontario
Thanks for the heads up. Headers are made to be rusty.
Do you run power stearing?
Re: Best Headers F Body [Re: Butt Ugly] #166637
12/14/08 12:44 AM
12/14/08 12:44 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Yes, the car had P/S and P/B.
I do remember one fit issue now- the #7(?) tube rubbed against the inner fenderwell, but that may have been due to using Schumacher conversion mounts. Never was sure as the car was originally a /6 car...and now is again.
Re: Best Headers F Body [Re: In_The_Pink] #166638
12/14/08 01:00 AM
12/14/08 01:00 AM
md
mopars4ever Offline
mopars4ever  Offline
md
TTI for the best fit and ease of changing spark plugs.
Re: Best Headers F Body [Re: mopars4ever] #166639
12/14/08 10:37 AM
12/14/08 10:37 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I've never seen a small block header where plug access was an issue. Big block maybe but we're not talking big blocks here.
Don't be the exception.
Re: Best Headers F Body [Re: Supercuda] #166640
12/14/08 11:25 AM
12/14/08 11:25 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Not talking big block, the access to the spark plugs are much easier with TTI headers, sorry if you disagree.
Re: Best Headers F Body [Re: mopars4ever] #166641
12/14/08 07:01 PM
12/14/08 07:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
How much access do you need?
I got a set of cheapo Summit house brands that offer all the access I need to change plugs.
It's not like it's a problem on a small block.
Re: Best Headers F Body [Re: Supercuda] #166642
12/14/08 10:17 PM
12/14/08 10:17 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I have hedman cheapies on my M, fit great, no dinging needed, never drug on the ground with the front lowered 1", can change the starter without pulling the headers, the only issue is the #7 plug wire is a little bit of a PITA (it needs about a 45 degree boot, the rest need straight boots)
2017 Grand Cherokee Overland
Re: Best Headers F Body [Re: patrick] #166643
12/14/08 11:18 PM
12/14/08 11:18 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
A 3/8" flange will cure header leaks.
Re: Best Headers F Body [Re: Magnum] #166644
12/16/08 06:17 PM
12/16/08 06:17 PM
Toronto Ontario
Toronto Ontario
Some helpful onfo guys, thanks. Summiit as cheap as anyone to buy headers?
Thanks again.
Jeff
Re: Best Headers F Body [Re: Butt Ugly] #166645
12/17/08 08:25 AM
12/17/08 08:25 AM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
Jeff - A body headers are closest in style to F-Body ones.
Re: Best Headers F Body [Re: 76Beeper] #166646
12/17/08 12:17 PM
12/17/08 12:17 PM
stratford,ontario,canada
JD340 Offline
JD340  Offline
Jeff, just plunk down a tub of toonies, and get some TTI's! Then us poorer F-body guys can be jealous of you!
Nothing to see here. Carry on.
