Need help to remove stubborn screw in freeze plug. #1665684
08/31/14 12:29 AM
08/31/14 12:29 AM
Missouri
galen Offline OP
galen  Offline OP
Missouri
I am running a KP block in my drag boat. No block drains so I am pulling an aluminum 1 inch block plug from each bank and installing petcocks. One side came out easy. The other bank will not budge with a 24" breakover bar and 5/8 allen. plugs are going to round out. I have soaked it, tapped on it. Thought about drilling it. Am open for suggestions. I cool with lake water so I need to be able to drain and flush the block.
Re: Need help to remove stubborn screw in freeze plug. [Re: galen] #1665685
08/31/14 12:32 AM
08/31/14 12:32 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Can you get an allen head socket on it and try an impact gun. A couple of hits may break it loose.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Need help to remove stubborn screw in freeze plug. [Re: galen] #1665686
08/31/14 12:33 AM
08/31/14 12:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
See if you can heat the area around it.. it might take
some time with the water in it
Re: Need help to remove stubborn screw in freeze plug. [Re: pittsburghracer] #1665687
08/31/14 12:34 AM
08/31/14 12:34 AM
PA.
"Little"John
"Little"John
PA.
We dealt with rust, heat, and water a lot in the steel mill and sometimes we would have to tighten something before it would break loose.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Need help to remove stubborn screw in freeze plug. [Re: MR_P_BODY] #1665688
08/31/14 12:37 AM
08/31/14 12:37 AM
PA.
"Little"John
"Little"John
PA.
If I remember right those plugs have a rubber o-ring around them as they are not pipe thread.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Need help to remove stubborn screw in freeze plug. [Re: pittsburghracer] #1665689
08/31/14 12:41 AM
08/31/14 12:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Still wouldnt matter if it is the O-ring style.. see
if he can get the area to expand
Re: Need help to remove stubborn screw in freeze plug. [Re: MR_P_BODY] #1665690
08/31/14 12:55 AM
08/31/14 12:55 AM
PA.
"Little"John
"Little"John
PA.
If all else fails and if you were planning on a 1/4 inch petcock you could probably center and peen and then drill it with a 27/64 drill bit and tap it for 1/4 inch pipe thread. See if the fitting or pipe nipple fits in the 5/8 allen slot. My preference would be a hex nipple to a pipe collar then the petcock. That would step it out some if you have the room.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Need help to remove stubborn screw in freeze plug. [Re: pittsburghracer] #1665691
08/31/14 01:04 AM
08/31/14 01:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If he cant get it out he might want to drill and tap
it for a 1/2" pipe and put a bushing in it for 1/4"..
that would clear the hex easy
Re: Need help to remove stubborn screw in freeze plug. [Re: pittsburghracer] #1665692
08/31/14 01:10 AM
08/31/14 01:10 AM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Thanks for the suggestions. It is a tapered 1" NPT. Drilling and tapping for 1/4 pipe will work if I can't get it out. If I can get it out I have 1" to 1/2" NPT aluminum bushings with 1/2 inch petcocks. Will try some heat and hit it with my impact.
Re: Need help to remove stubborn screw in freeze plug. [Re: galen] #1665693
09/02/14 10:56 AM
09/02/14 10:56 AM
Ohio, United States
BuckeyeBrawler Offline
Ohio, United States
Try heating it al little bit with a torch then run a candle around the threads. The heat draws the candle wax down into the threads like solder in sweat joint on plumbing. I have had really good luck removing stuck and broken fasteners this way.
Re: Need help to remove stubborn screw in freeze plug. [Re: BuckeyeBrawler] #1665694
09/02/14 11:16 AM
09/02/14 11:16 AM
Guitar Jones Offline
Have you tried harsh language?
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Need help to remove stubborn screw in freeze plug. [Re: galen] #1665695
09/02/14 11:18 AM
09/02/14 11:18 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Shocking the plug with a hammer can help.
Re: Need help to remove stubborn screw in freeze plug. [Re: Clanton] #1665696
09/02/14 12:45 PM
09/02/14 12:45 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Tried everything suggested including harsh language, (Which I tried first). Got it out. Ended up drilling with a one inch bit then took my time doing 4 cuts out to the threads. Had to break it out.
Re: Need help to remove stubborn screw in freeze plug. [Re: galen] #1665697
09/02/14 12:54 PM
09/02/14 12:54 PM
maryland
74yellowduster Offline
maryland
was it corrosion that caused it to seize or did someone put loctite on it?
Re: Need help to remove stubborn screw in freeze plug. [Re: 74yellowduster] #1665698
09/02/14 02:13 PM
09/02/14 02:13 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
It had some type of brown sealer on it. The other side came out easy. Has anti seize on it now.
Re: Need help to remove stubborn screw in freeze plug. [Re: galen] #1665699
09/02/14 02:33 PM
09/02/14 02:33 PM
Good choice, especially on aluminum
