Re: Need help to remove stubborn screw in freeze plug.
[Re: galen]
#1665686
08/31/14 12:33 AM
08/31/14 12:33 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I am running a KP block in my drag boat. No block drains so I am pulling an aluminum 1 inch block plug from each bank and installing petcocks. One side came out easy. The other bank will not budge with a 24" breakover bar and 5/8 allen. plugs are going to round out. I have soaked it, tapped on it. Thought about drilling it. Am open for suggestions. I cool with lake water so I need to be able to drain and flush the block.
See if you can heat the area around it.. it might take some time with the water in it
[Re: pittsburghracer]
#1665687
08/31/14 12:34 AM
08/31/14 12:34 AM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
We dealt with rust, heat, and water a lot in the steel mill and sometimes we would have to tighten something before it would break loose.
#1665689
08/31/14 12:41 AM
08/31/14 12:41 AM
MR_P_BODY
If I remember right those plugs have a rubber o-ring around them as they are not pipe thread.
Still wouldnt matter if it is the O-ring style.. see if he can get the area to expand
[Re: MR_P_BODY]
#1665690
08/31/14 12:55 AM
08/31/14 12:55 AM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If all else fails and if you were planning on a 1/4 inch petcock you could probably center and peen and then drill it with a 27/64 drill bit and tap it for 1/4 inch pipe thread. See if the fitting or pipe nipple fits in the 5/8 allen slot. My preference would be a hex nipple to a pipe collar then the petcock. That would step it out some if you have the room.
#1665691
08/31/14 01:04 AM
08/31/14 01:04 AM
MR_P_BODY
If he cant get it out he might want to drill and tap it for a 1/2" pipe and put a bushing in it for 1/4".. that would clear the hex easy
#1665692
08/31/14 01:10 AM
08/31/14 01:10 AM
Posts: 831 Missouri
galen
Missouri
Thanks for the suggestions. It is a tapered 1" NPT. Drilling and tapping for 1/4 pipe will work if I can't get it out. If I can get it out I have 1" to 1/2" NPT aluminum bushings with 1/2 inch petcocks. Will try some heat and hit it with my impact.
[Re: BuckeyeBrawler]
#1665694
09/02/14 11:16 AM
09/02/14 11:16 AM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
Have you tried harsh language?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
