ignition woes (up-date) A-1 Cardone
#166542
12/12/08 01:14 PM
12/12/08 01:14 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
well as some of remember i had been having problems with my electronic ignition upgrade on my 68 dart.
I went through 3 Dist 2 re-man and 1 new all from A-1 Cardone.
after the third one i found the mechanical advance wasnt moving ( to tight of springs) So instead of fixing the new dist I called the tech dept at A-1 Cardone. Seems they made over 1000 mopar distributors like the ones i recieved.
The tech guy said they have some of them back but not all, so if you get a new or reman dist from A-1 cardone beware it may act funny on the mechanical advance. Any way I feel i should not have to fix thier junk so I am sending it back for a refund and I purchaced a used OEM dist for my 68 318 dart..
Also earlier this yr i also needed a replacement MC for my 68 dart, so i got a rebuilt one from A-1 cardone, well it also sucked , seems my original MC had redisual valves in the MC and the re-man MC didnt, and with out them it caused excessive pedal travel. What is it with these guys, ..
Re: ignition woes (up-date) A-1 Cardone
[Re: CokeBottleKid]
#166544
12/12/08 02:09 PM
12/12/08 02:09 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Yup, mass rebuilders can be rough. A1 used to be decent... but like everyone else, the cheaper we have to have them, the worse the parts and labor.
[Re: CokeBottleKid]
#166546
12/12/08 02:58 PM
12/12/08 02:58 PM
Dakota_Don
Alton, IL
Lets see 3 bad distributors and 1 bad MC... You're a slow learner aren't you?
J/K
A P-Oed slow learner
[Re: Dakota_Don]
#166547
12/12/08 03:46 PM
12/12/08 03:46 PM
RapidRobert
Don did you have any luck freeing those weights up?
[Re: RapidRobert]
#166548
12/13/08 01:23 AM
12/13/08 01:23 AM
Dakota_Don
Alton, IL
well i kinda figured since this POS new(made in china) dist. doesn't work, why should I spend my time fixing it.(they made over 1000 of them with this problem) I will send it back, I could have changed the springs, ect. So I asked for a refund and I have a good used o.e.m. Mopar dist. on the way. Thanks Rapid for your help. I just want people to be aware, just because it's new doesn't mean it works.
[Re: 62maxwgn]
#166552
12/14/08 02:43 PM
12/14/08 02:43 PM
Posts: 2,250 ILLINOIS
volaredon
ILLINOIS
With the thousands of O.E.M. distributors out there dirt cheap,why would you even bother.Just re-do one and be done with it.Unless you don't want to get your hands dirty.
Cuz I got this new one for $50 from Ebay; $64.50 shipped with a module. That way I can redo my orig one and have something to plug in the motor while I order any parts that need to be so I can drive the thing.
