whats everyone running solid roller lifters on street? #1665186
08/29/14 02:31 PM
08/29/14 02:31 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
just curious what everyone is using on street.pump gas 340 stroker, are u using pressure fed rollers or non pressure fed rollers.crane solid roller .250/.254@.050 .600/.600 lift installed at 109.
Re: whats everyone running solid roller lifters on street? [Re: hp340nos] #1665187
08/29/14 03:38 PM
08/29/14 03:38 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
pressure fed rollers made by Morel. bought from Best Machine.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: whats everyone running solid roller lifters on street? [Re: hp340nos] #1665188
08/29/14 03:59 PM
08/29/14 03:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the EDM lifters in my street/strip 416 but
I also use PR oiling.. I also have bushed lifter
bores... if you look at the rollers you have.. see
if there is a hole in the side... my one set does
and that hole oils the roller(blow through it just
to check, if you have it).. I went with the EDM just
so I can run lower RPM at the street lights.. its
a .640/.640 260/270 105 lsa installed at 105 with 260#
on seat
Re: whats everyone running solid roller lifters on street? [Re: MR_P_BODY] #1665189
08/29/14 04:49 PM
08/29/14 04:49 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
on seat
Mike who is the mgf of that cam? Sounds real close to one I would like to try. Jim
Re: whats everyone running solid roller lifters on street? [Re: rt66jim] #1665190
08/29/14 08:28 PM
08/29/14 08:28 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am running the Comp Cams 8043, I bought them from IMM engines.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: whats everyone running solid roller lifters on street? [Re: rt66jim] #1665191
08/29/14 08:46 PM
08/29/14 08:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
on seat
Its a MP roundy round roller cam.. I cant find the
MP part number anymore in my books
Re: whats everyone running solid roller lifters on street? [Re: hp340nos] #1665192
08/29/14 09:24 PM
08/29/14 09:24 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Gsp products, pressure fed, 730 roller.
Re: whats everyone running solid roller lifters on street? [Re: rickraw] #1665193
08/29/14 10:29 PM
08/29/14 10:29 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Comp Cams 829's.Bullet solid roller .767/.676, 288/292@.050 113 center installed at 111.Dave
Re: whats everyone running solid roller lifters on street? [Re: rickraw] #1665194
08/30/14 11:57 AM
08/30/14 11:57 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
My stick is smaller , but I got these on the recommendation of Ryan J.
They are the same as the Crane Ultra Pros.
Not inexpensive.......but what is at this level ?
Re: whats everyone running solid roller lifters on street? [Re: tubtar] #1665195
08/30/14 12:24 PM
08/30/14 12:24 PM
Pressure feed if you can afford but...keep the darn spring pressures down on a street unit
Most will run like crazy with 425 lb open Yes you would want 650 or more on the strip but on the street it is all about NOT killing the lifter
When you are at idle, arm out the window, strutting around the cruise--that lifter wheel bearings can be red hot from lack of oil
Most folks run WAY too much spring pressure on street rollers
Morel pressure feed is the way to go for solids anytime and Never restrict oil in any way whatsoever --it kills lifters.
Re: whats everyone running solid roller lifters on street? [Re: ] #1665196
08/31/14 09:22 AM
08/31/14 09:22 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Comp 828s here with a tubed block. I put about 5k on the last set before I changed them. They look and feel ok, I have not gotten around to sending the old ones to comp for a rebuild yet to see what they say.
68 Barracuda Formula S 340
Re: whats everyone running solid roller lifters on street? [Re: ] #1665197
08/31/14 09:45 AM
08/31/14 09:45 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Agressive profiles and lack of spring pressure is harder on rollers than anything. And if you run a morel style lifter you usually have to restrict oil in most setups
Re: whats everyone running solid roller lifters on street? [Re: Hot 340] #1665198
09/02/14 12:49 AM
09/02/14 12:49 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
66550-16 crane rollers..
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: whats everyone running solid roller lifters on street? [Re: hp340nos] #1665199
09/02/14 12:50 AM
09/02/14 12:50 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Isky solid body lifters here..................
Re: whats everyone running solid roller lifters on street? [Re: Thumperdart] #1665200
09/02/14 09:49 AM
09/02/14 09:49 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
GSP, pressure fed.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: whats everyone running solid roller lifters on street? [Re: 1967dartgt] #1665201
09/02/14 10:05 AM
09/02/14 10:05 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
Just over 9500 hundred miles and around 65 passes at the track on the Comps in a SB.
I have a BB that has Crowers in it,they where rebuilt used when installed. They have 5000 miles on them.
Seat pressure on both is 200 on the seat, 500 over the nose.
Re: whats everyone running solid roller lifters on street? [Re: Darryls-Demon] #1665202
09/02/14 01:37 PM
09/02/14 01:37 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
I'd like to hear some feedback on the MRL (BAM) lifters mentioned in this older thread: https://board.moparts.org/ubbthreads/show...amp;Search=true
Re: whats everyone running solid roller lifters on street? [Re: D-50] #1665203
09/02/14 02:08 PM
09/02/14 02:08 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Me too. Running 276/284 @ .050" done a fair amount of street miles.
-Kenny
Re: whats everyone running solid roller lifters on street? [Re: StrokerAspen] #1665204
09/02/14 03:19 PM
09/02/14 03:19 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i bought a set of morel race lifters through competition wedge.
Re: whats everyone running solid roller lifters on street? [Re: Hot 340] #1665205
09/02/14 04:20 PM
09/02/14 04:20 PM
Making the real question WHY would anyone run an aggressive profile on a STREET engine--Comp has smartened up and now all the Street rollers are very easy on things, run tighter lash and need way less spring pressure --so do the right thing and keep that silly race profile on the track and not on the street--Problems Solved!!!!!
I bet I can take a stout engine and dyno six cams in a row right off the catalog page and there is not that much difference--Cam selection process is one of the most over advertised--over thought --Bull crud filled areas of car building--don't go too big--don't run crazy aggressive lobes that a computer says is better and listen to the professional cam grinders--it is that easy.
Always pick smaller than you think and that will still be to big
Solid rollers on a street car will blow the axle bearings out sooner or later--NO oil at idle--way too much spring pressure( because I might get into a street race) and oil restricted-- Kills axle bearings--
Run a solid body lifter in a stock block Mopar
Morel has over a hundred part numbers and will make whatever you need
