Re: whats everyone running solid roller lifters on street?
[Re: hp340nos]
#1665187
08/29/14 03:38 PM
08/29/14 03:38 PM
Posts: 4,848 Memphis
HemiRick
Memphis
pressure fed rollers made by Morel. bought from Best Machine.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: hp340nos]
#1665188
08/29/14 03:59 PM
08/29/14 03:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
just curious what everyone is using on street.pump gas 340 stroker, are u using pressure fed rollers or non pressure fed rollers.crane solid roller .250/.254@.050 .600/.600 lift installed at 109.
I use the EDM lifters in my street/strip 416 but I also use PR oiling.. I also have bushed lifter bores... if you look at the rollers you have.. see if there is a hole in the side... my one set does and that hole oils the roller(blow through it just to check, if you have it).. I went with the EDM just so I can run lower RPM at the street lights.. its a .640/.640 260/270 105 lsa installed at 105 with 260# on seat
[Re: MR_P_BODY]
#1665189
08/29/14 04:49 PM
08/29/14 04:49 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
Mike who is the mgf of that cam? Sounds real close to one I would like to try. Jim
[Re: rt66jim]
#1665190
08/29/14 08:28 PM
08/29/14 08:28 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am running the Comp Cams 8043, I bought them from IMM engines.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: rt66jim]
#1665191
08/29/14 08:46 PM
08/29/14 08:46 PM
MR_P_BODY
Its a MP roundy round roller cam.. I cant find the MP part number anymore in my books
[Re: rickraw]
#1665194
08/30/14 11:57 AM
08/30/14 11:57 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Gsp products, pressure fed, 730 roller.
My stick is smaller , but I got these on the recommendation of Ryan J. They are the same as the Crane Ultra Pros. Not inexpensive.......but what is at this level ?
[Re: tubtar]
#1665195
08/30/14 12:24 PM
08/30/14 12:24 PM
Pressure feed if you can afford but...keep the darn spring pressures down on a street unit Most will run like crazy with 425 lb open Yes you would want 650 or more on the strip but on the street it is all about NOT killing the lifter When you are at idle, arm out the window, strutting around the cruise--that lifter wheel bearings can be red hot from lack of oil Most folks run WAY too much spring pressure on street rollers Morel pressure feed is the way to go for solids anytime and Never restrict oil in any way whatsoever --it kills lifters.
[Re: ]
#1665196
08/31/14 09:22 AM
08/31/14 09:22 AM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
Comp 828s here with a tubed block. I put about 5k on the last set before I changed them. They look and feel ok, I have not gotten around to sending the old ones to comp for a rebuild yet to see what they say.
68 Barracuda Formula S 340
[Re: ]
#1665197
08/31/14 09:45 AM
08/31/14 09:45 AM
Posts: 3,395 Pa
Hot 340
Pa
Agressive profiles and lack of spring pressure is harder on rollers than anything. And if you run a morel style lifter you usually have to restrict oil in most setups
[Re: D-50]
#1665203
09/02/14 02:08 PM
09/02/14 02:08 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
Me too. Running 276/284 @ .050" done a fair amount of street miles.
-Kenny
[Re: Hot 340]
#1665205
09/02/14 04:20 PM
09/02/14 04:20 PM
Making the real question WHY would anyone run an aggressive profile on a STREET engine--Comp has smartened up and now all the Street rollers are very easy on things, run tighter lash and need way less spring pressure --so do the right thing and keep that silly race profile on the track and not on the street--Problems Solved!!!!!
I bet I can take a stout engine and dyno six cams in a row right off the catalog page and there is not that much difference--Cam selection process is one of the most over advertised--over thought --Bull crud filled areas of car building--don't go too big--don't run crazy aggressive lobes that a computer says is better and listen to the professional cam grinders--it is that easy. Always pick smaller than you think and that will still be to big
Solid rollers on a street car will blow the axle bearings out sooner or later--NO oil at idle--way too much spring pressure( because I might get into a street race) and oil restricted-- Kills axle bearings-- Run a solid body lifter in a stock block Mopar Morel has over a hundred part numbers and will make whatever you need
