Looking For a Good book On Gen 3 #1665159
08/29/14 01:49 PM
08/29/14 01:49 PM
MR_P_BODY Offline OP
I'm looking for a good book or 2 on the gen 3 engines
with all the specs and performance info and what parts
inter change on what and good info on the oiling
thanks
Re: Looking For a Good book On Gen 3 [Re: MR_P_BODY] #1665160
08/29/14 02:04 PM
08/29/14 02:04 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Re: Looking For a Good book On Gen 3 [Re: MR_P_BODY] #1665161
08/29/14 02:47 PM
08/29/14 02:47 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
This is handy. No real performance info though.
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Looking For a Good book On Gen 3 [Re: Dave_S] #1665162
08/29/14 08:12 PM
08/29/14 08:12 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Great for the basic however, Thanks!
Bill
Re: Looking For a Good book On Gen 3 [Re: 340Cuda] #1665163
08/29/14 08:36 PM
08/29/14 08:36 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
There really isn't one Mike, torque specs are readily available and my ARP main studs and head bolts came with their own. 08 and earlier 5.7 and 6.1 stuff interchanges except the bolt pattern on the reluctor wheels. If you use Eagle or Apache heads you have to use their rockers, pushrods and valve covers because I THINK the stands are taller. I'm using a 4.05" crank in a 6.1 block and found out I had to grind for rod bolt clearance under #8 only AFTER I had the block prepped and cam bearings installed, so now I get to tank it, paint it and get cam bearings installed AGAIN. I'll take a pic when I get a chance.
Mopar to the bone!!!
Re: Looking For a Good book On Gen 3 [Re: 72Swinger] #1665164
08/29/14 09:03 PM
08/29/14 09:03 PM
Yeah, been trying to google books on the gen 3 with
nothing popping up.. you would think there would be
based on the years its been out there... are you using
the piston oiliers... if I were to use a 6.1 crank
in a 05 5.7 I assume I have to use the 6.1 ring..
and yes I'm thinking about the Apache heads.. thanks
for the info
Re: Looking For a Good book On Gen 3 [Re: MR_P_BODY] #1665165
08/29/14 09:17 PM
08/29/14 09:17 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Yes I am retaining the oil jets after some mods to them and the pistons.
Re: Looking For a Good book On Gen 3 [Re: 72Swinger] #1665166
08/29/14 09:19 PM
08/29/14 09:19 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Small notch in skirts.
Re: Looking For a Good book On Gen 3 [Re: 72Swinger] #1665167
08/29/14 09:33 PM
08/29/14 09:33 PM
What do you figure you can bore these engines out and
still be strong... I'm gonna turbo this with either
a single or a twin.. gotta look at what I can package..
plus are the cams ground by most companies
Re: Looking For a Good book On Gen 3 [Re: MR_P_BODY] #1665168
08/29/14 11:51 PM
08/29/14 11:51 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I'm kinda from the train of thought "bore only as needed" although I have not seen a split cylinder wall. You can get good pistons in .010 over increments and my block got clean with a .010 over at 4.065. I havent seen anyone go past .030-.035 over without sleeves though either.
Re: Looking For a Good book On Gen 3 [Re: 72Swinger] #1665169
08/30/14 12:15 AM
08/30/14 12:15 AM
I'm looking at a 05 5.7 thats a running engine so I
would think .010 will clean it up... so there isnt
any problem with running a 6.1 crank in a 5.7 and
using the 6.1 wheel... how about rods.. I will want
something better than a powered rod.. what length
would that end up being
thanks for the help
Re: Looking For a Good book On Gen 3 [Re: MR_P_BODY] #1665170
08/30/14 12:23 AM
08/30/14 12:23 AM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
Challengertalk.com drag forum is pretty good for info, as is LXforums.com in their racing sections. The "book" is how good you can use Google to search for whatever info it is that you need, but those are two good places to start.
http://www.challengertalk.com/forums/f18/
http://www.lxforums.com/board/forumdisplay.php/50-The-Garage
Re: Looking For a Good book On Gen 3 [Re: MR_P_BODY] #1665171
08/30/14 12:26 AM
08/30/14 12:26 AM
Dave_S Offline
Dave_S  Offline
I have a 6.1 crank in a 5.7 block. You must use the tone wheel that came with the crank. A 6.1 tone wheel wont fit a 5.7 crank.
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: Looking For a Good book On Gen 3 [Re: Dave_S] #1665172
08/30/14 12:36 AM
08/30/14 12:36 AM
That part I read... being that they dont fit one
another.. but it all clears everything .. correct..
what rods did you use
Re: Looking For a Good book On Gen 3 [Re: MR_P_BODY] #1665173
08/30/14 12:42 AM
08/30/14 12:42 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
5.7 and 6.1 are same stroke, so you would gain a forged crank using the 6.1 and its wheel. The rod lengths are the same as well. You can get rods in stock length, 6.242 IIRC, from a few different vendors like Molnar,K1 and Callies. Pay close attention because 99% of them use a .927 SBC pin instead of the stock .984. You can also get them in Chevy journal sizes like 2.0" which is what is going in mine,im not 100% sure but I think stock is 2.10 or 2.125. You can price a few things from these guys http://www.flatlanderracing.com/
Re: Looking For a Good book On Gen 3 [Re: 72Swinger] #1665174
08/30/14 01:04 AM
08/30/14 01:04 AM
Thanks... wasnt sure if they were the same stroke
Re: Looking For a Good book On Gen 3 [Re: MR_P_BODY] #1665175
08/30/14 10:28 AM
08/30/14 10:28 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Best sources out there:
http://www.lxforums.com/board/showthread.php/24486-New-Service-Manual-Download-Link
http://www.enginebuildermag.com/wp-content/uploads/46568ChryslerHe_00000019776.pdf
If I need a Hemi specific engine question answered, I search on google including the text:
site:lxforums.com
Whether it is pushrod length, lifter travel, which tone wheel for aftermarket cranks, etc, I'm able to find the answer.
Also- useful swap info can be found on the FABO 3G Hemi swap forum. You have to dig a little though.
I had a 6.1 crank in a 5.7. Use the 6.1 tone wheel. It fits plenty fine.
I'm a fan of K1 rods and Wiseco pistons for the new gen Hemi's. That's what I run.
IMO, you should copy Matt's turbo build for the long block. 6.1 crank, k1 rods, Wiseco pistons, eagle heads, and upgraded spring. Use main studs (get block honed for them), and you'll be GTG for ~1,000 hp or so.
FYI- stock head gaskets and stock head bolts have held up to ~20 psi on Hemi-C's YSI Magnum (a few build revisions ago). Much beyond 18-20 psi things can get expensive.
5.7 cylinder walls are thicker than 6.1's. You need to measure wall thickness if you want to go more than .020 on a 6.1, and I would suggest it for more than .030 (or so) on a 5.7. I've read somewhere a 5.7 bore can be bored like .080 before reaching the same cylinder wall thickness that comes on a 6.1. Some 6.1's can't take a bore , but I also know of a couple running a 4.100 (.045 over) bore.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Looking For a Good book On Gen 3 [Re: Uhcoog1] #1665176
08/30/14 10:36 AM
08/30/14 10:36 AM
Thanks for the info
Re: Looking For a Good book On Gen 3 [Re: MR_P_BODY] #1665177
08/30/14 11:14 AM
08/30/14 11:14 AM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
The 5.7 (non-VVT) blocks are a good choice. Just be sure to sonic test the bores. It took me 3 blocks to find one I felt was acceptable. There was obviously quite a bit core shift when these were made.
As far as boost limits on stock head bolts and gaskets - we've taken a completely stock 6.1 engine to 28psi with no sign of head lifting. This doesn't mean I'd build a purpose built engine with this configuration - just relaying the strength of the stock setup. Go with head studs and Cometics.
Modern Mopar Forum is a good place for full tilt Gen III Hemi info if you don't mind the drama.
Here's a link to a thread on pushing a stock 6.1 to the limits:
http://modernmoparforum.com/topic/12184-...e-photos-added/
Re: Looking For a Good book On Gen 3 [Re: MR_P_BODY] #1665178
08/30/14 11:14 AM
08/30/14 11:14 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Not a book but you might want to consider getting the pushrod alignment tool since you can't really assemble the valvetrain correctly without it. We had them at the dealer, it was a Miller tool.
'71 Duster
'72 Challenger
'17 Ram 1500
