1969 2-door & 4-door trunks/rails the same? #1664832
08/28/14 04:10 PM
08/28/14 04:10 PM
Saline, MI
E
efisixpack Offline OP
E
Saline, MI
I have a 69 satellite I'm collecting a few parts for. I was just offered a rear chunk off another car but it's a 4-door. Would the trunk pan, rear frame rails and other assorted parts be the same as a 2-door? I should know this but I'm drawing a blank. Thanks for any input!
When I die I want to go like my Grandfather did, quietly in his sleep. Not screaming like the passengers in his car.
Re: 1969 2-door & 4-door trunks/rails the same? [Re: efisixpack] #1664833
08/28/14 05:35 PM
08/28/14 05:35 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes they are the parts you specifically asked about are , the dutchman panel between the 1/4's is not , the inner wheel houses are a little different .
Re: 1969 2-door & 4-door trunks/rails the same? [Re: JohnRR] #1664834
08/28/14 11:08 PM
08/28/14 11:08 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Like John says not all 1969 B Bodies are created equal. When my friend that is on this board was restoring his 1969 Super Bee he came up against these things. But any rust free pieces that you can save some place and its is free, do it. There are difference like John said between 4 doors and 2 doors and Plymouths and Dodges. One person like Furyman on this board could tell you all the diffences between all the B Bodies in 1969, his business to know the differences and this is were my friend got his used sheet metal for the car.
Re: 1969 2-door & 4-door trunks/rails the same? [Re: hemicar1971] #1664835
08/28/14 11:38 PM
08/28/14 11:38 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Frames and pans are the same.
Boxes that spring perch hangs from is different between Dodge and Plymouth.
Inner wheel houses are the same between Dodge and Plymouth and 4-dr and 2-dr. Outer wheel houses are the same between Plymouth 2-dr and 4-dr but are different than Dodge. Also Dodge outers are different between 2-dr and 4-dr un-like Plymouth.
Also rear cross member is probably different. 68 has a round hole for the fuel tank filler tube and 69 is probably oval.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 1969 2-door & 4-door trunks/rails the same? [Re: moparmarks] #1664836
08/29/14 12:46 AM
08/29/14 12:46 AM
Saline, MI
E
E
Saline, MI
That's what I needed to know. As always, thanks for the help guys!
