Trying to strip off one layer of paint Update.... #1664816
08/28/14 03:14 PM
08/28/14 03:14 PM
Far Northeast.
mymcodebee Offline OP
Far Northeast.
My brother just bought this little truck which is essentially like new minus the black spray bomb over what appears to be great original paint. Any ideas on how to get the spray bomb off without hurting the original. He tried a small area with some paint thinner and it did not really touch the spray bomb paint which kind of surprised me. I am guessing it is not possible but thought I would check for any ideas for him.
Re: Trying to strip off one layer of paint and expose org. [Re: mymcodebee] #1664817
08/28/14 03:44 PM
08/28/14 03:44 PM
KY
Telvis Offline
Telvis  Offline
KY
Not easy.... Might try wet sanding then buff once the old paint is exposed. Basically like you would cut and buff new clearcoat. I have never tried anything like that but I would think it would work. Same principle, taking off the top layer. Very labor intensive though. There must be a reason hey painted it. My guess is the paint has bad areas under the black.
That's King Weenie to you!
Re: Trying to strip off one layer of paint and expose org. [Re: mymcodebee] #1664818
08/28/14 03:52 PM
08/28/14 03:52 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'd start with steam pressure washer, probably could get 100% off if you have the time and patience. It would not hurt the original paint at all if your careful. I've done this before.
Re: Trying to strip off one layer of paint and expose org. [Re: Challenger 1] #1664819
08/28/14 04:29 PM
08/28/14 04:29 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
try laquer thinner.it wont hurt the original paint and should cut through the spay bomb if its uncatalized enamal.
Re: Trying to strip off one layer of paint and expose org. [Re: bonefish] #1664820
08/28/14 11:27 PM
08/28/14 11:27 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Ricks restoration said to use a chemical stripper, it only removes one layer at a time
Re: Trying to strip off one layer of paint and expose org. [Re: cudaman1969] #1664821
08/29/14 09:38 AM
08/29/14 09:38 AM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
It will only remove one layer as long as there is not a scratch or other imperfection that will allow the stripper to get down into/below the original finish. Then you will start to lift the original finish and defeat your purpose.
I'm with the other guys, that there has to be a reason that it was spray bombed in the first place. Check the front clip and make sure it is the same color as the rest of the truck. There might be a swapped out 1/4 panel or hood?
Re: Trying to strip off one layer of paint and expose org. [Re: mymcodebee] #1664822
08/29/14 09:40 AM
08/29/14 09:40 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
probably peeling clear
other than that, the local high pressure car wash. Took my brothers black 68 camaro into one when we were kids, came out kinda burnt orange color
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: Trying to strip off one layer of paint and expose org. [Re: 70Coronet500Vert] #1664823
08/29/14 10:00 AM
08/29/14 10:00 AM
Far Northeast.
Far Northeast.
Thanks for the ideas!
He is giving a couple of them a shot this weekend.
Re: Trying to strip off one layer of paint and expose org. [Re: mymcodebee] #1664824
08/29/14 10:55 AM
08/29/14 10:55 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Its funny, if he spray bombed it he probably wouldn't be able to keep it on there
Re: Trying to strip off one layer of paint and expose org. [Re: GTX MATT] #1664825
08/29/14 04:12 PM
08/29/14 04:12 PM
Far Northeast.
Far Northeast.
So this is pretty funny. My brother messed around with the paint a little bit today and finally decided to bite the bullet and just repaint it back to the factory Burnt Orange. While he was at the paint shop the employee said "hey I know that truck. The kid that use to own that painted it black so that it would make it harder to find it to repo it!!!" Apparently didn't work.
Re: Trying to strip off one layer of paint Update.... [Re: mymcodebee] #1664826
08/29/14 07:35 PM
08/29/14 07:35 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I had a lot of success with old oven cleaner, I'd spray on let sit a few minutes then power wash.
90% of the time the paint would wash off leaving factory finish.
Never did that large of a project, and not sure what oven cleaner is like in your area, it has changed here do to environmental laws.
Re: Trying to strip off one layer of paint Update.... [Re: boydsdodge] #1664827
08/29/14 10:06 PM
08/29/14 10:06 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
This post is cracking me up. Talk about timing. I just bought a Dakota R/T that was originally Solar Yellow. It LOOKS like he shot one coat of a metallic black, maybe a two stage paint, with no clear coat. It scratches if you sneeze. The small bare spots around the trim look like no sanding was performed. I'm contemplating giving it the power washing treatment but I'll wait till I can afford to have it repainted. Otherwise I'll be driving a Dalmatian for a while.
My truck has a salvage title, so who knows what I will find under the paint...
I’m listening.
Re: Trying to strip off one layer of paint and expose org. [Re: cudaman1969] #1664828
08/30/14 10:00 AM
08/30/14 10:00 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Just do a small area and keep an eye on it, don't go off and watch some ball game.
Re: Trying to strip off one layer of paint Update (2) [Re: mymcodebee] #1664829
10/27/14 12:34 PM
10/27/14 12:34 PM
Far Northeast.
Far Northeast.
Well just to complete the post. We had to strip every inch of the black off the truck and repaint the whole truck. Custom fit a challenger hood skin on the truck and shot it out this weekend. Still some assembly needed.
Re: Trying to strip off one layer of paint Update (2) [Re: mymcodebee] #1664830
10/27/14 12:35 PM
10/27/14 12:35 PM
Far Northeast.
Far Northeast.
2
Re: Trying to strip off one layer of paint Update (2) [Re: mymcodebee] #1664831
10/27/14 12:36 PM
10/27/14 12:36 PM
Far Northeast.
Far Northeast.
Hood
