Page 1 of 3 1 2 3
opinion on 340 R3/w8 (358ci) #1664437
08/27/14 06:26 PM
08/27/14 06:26 PM
CT
3
340KID Offline OP
340KID  Offline OP
CT
came across this engine that we are considering to put in a 73 Scamp drag car
motor was built somewhat to nascar specs.
340 R3 48 degree block - 358 cubic inch
Bryant crank 3.30 stroke
carillo rods 6.25"
diamond 4.155 flat tops -
crane solid roller - duration 266/270 @ .05, lift 726/610
Jesel pro series rockers 1.65 int 1.5 exh
12 to 1 compression
dry sump oil system
w8 heads 2.18 int, 1.625 exh, nextek springs, titanium retainers etc
w8 MP intake
crank trigger / MSD distributor
dyno sheets show max torque 523 at 5800 rpm,
max HP 685 at 7500 rpm
would this be ideal in the Scamp ?
8253267-dyno-1.pdf (356 downloads)
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664438
08/27/14 06:32 PM
08/27/14 06:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Depending on the weight of the car but sounds like
you would want more RPM out of it but the duration
is a bit short... if foot braking it should be fine..
has nice torque and HP for the cubes
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664439
08/27/14 07:42 PM
08/27/14 07:42 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Should be fun.
Anybody know what the specs were on a nastruck cam? Like an Arrington motor
Re: opinion on 340 R3/w8 (358ci) [Re: SpareParts] #1664440
08/27/14 09:01 PM
08/27/14 09:01 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Most had RX RZ lobes 105-108 LSA .440ish lobe 276-282 intake and 280-286 ex lobe. Was real popular. For the w8 truck engines.
Re: opinion on 340 R3/w8 (358ci) [Re: W5DART66] #1664441
08/28/14 12:19 AM
08/28/14 12:19 AM
CT
3
340KID Offline OP
340KID  Offline OP
CT
Cam is cut at 108, heads flow 348 intake and 247 exhaust
Intake port volume at 270 + , just wondering if it will be a nice bracket motor in a Scamp, motor is brand spankin new !!
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664442
08/28/14 12:22 AM
08/28/14 12:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Should be... those are not max ported heads by any means
but should work well with the combo
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664443
08/28/14 12:28 AM
08/28/14 12:28 AM
CT
3
340KID Offline OP
340KID  Offline OP
CT
My biggest concern would be headers and dry pump location, does anyone make W8 2" headers or bigger that will work with a stock K-frame, motor already has dry pump, pulleys etc just need reservoir, pump is located just under number 1 cylinder
Re: opinion on 340 R3/w8 (358ci) [Re: MR_P_BODY] #1664444
08/28/14 12:43 AM
08/28/14 12:43 AM
CT
3
340KID Offline OP
340KID  Offline OP
CT
Our goal is to be a low 10 second car, the project is a 73 scamp with a 71 full fiberglass front clip, hood, fenders, bumber, it has a 8 pt cage, interior seats front/rear removed. 727 tranny with 9" dynamic 4500+ converter, 8.75 rear with 742 case, 5.13 rear (I think) with spool and 29.5 x10.5 slicks , don't know weight but I'm thinking around 2900-3000 ?? Learning more about it every day, lol
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664445
08/28/14 12:47 AM
08/28/14 12:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Your on your own with headers... also 1 7/8 should be
large enough for that
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664446
08/28/14 01:02 AM
08/28/14 01:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You need more conv.. stall should be just above the
max torque rpm.. check the formula for the gear..
5.13 might be a bit much(4.88 would be more like it)
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664447
08/28/14 01:02 AM
08/28/14 01:02 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Yeah.
Here are your choices.
Get ready to shell out a couple thousand to have a quality set made......I doubt 2 " will work , but I'm certainly not the last word on this.
Or get an A body set either semi welded and add your own flanges or completed and cut their flanges off.
SPD has the flanges and there are a couple different W-8 versions that I am aware of so make sure you get the right ones to start with.
http://spdexhaust.com/
For my deal , I went through SPD for the flanges and got a set of un-welded later A body 1 7/8" headers from Stahl.
Then married the two up for my '65.
Stahl does not make headers anymore , but they may still have some inventory laying around , so I would call them and see.
It took some of the guess work out of it for me.
But I have an AlterKtion in there and it was still a fair bit of work.
Shelf stuff is very rare for these deals.
Re: opinion on 340 R3/w8 (358ci) [Re: tubtar] #1664448
08/28/14 01:24 AM
08/28/14 01:24 AM
CT
3
340KID Offline OP
340KID  Offline OP
CT
Someone mentioned cooper headers ?? Anyone know about them ?
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664449
08/28/14 04:15 AM
08/28/14 04:15 AM
Finland
mafo Offline
mafo  Offline
Finland
If you have the stock steering box, you probably run into trouble with the oil pump, but it will be worth the effort to get it in
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: opinion on 340 R3/w8 (358ci) [Re: mafo] #1664450
08/28/14 07:52 AM
08/28/14 07:52 AM
anywhere@ anytime
actionange Online content
actionange  Online Content
anywhere@ anytime
Using the KISS philosophy- "keep it simple stupid" (no disrespect towards you)- a bracket car should be just that.
With dry sump and custom headers it might not be.
That power plant will definitely get you to 10 flat with that car weight.
In fact you might have to slow it down...
Use non exotic parts that are readily available and can be found/ fixed/ tuned easily for success.
Just my
See ya at the track.
Re: opinion on 340 R3/w8 (358ci) [Re: actionange] #1664451
08/28/14 08:53 AM
08/28/14 08:53 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
The exhaust ports are higher and a different pattern than W2. You may be able to cut flanges and replace with W9. 1 7/8" is fine for 358.
If you are capable of doing the drysump,fine. If not it is possible to convert to internal pump. This depending on the rear cap you may have to swap and re line bore which is costly. Another option is a wet pan with a single stage external pump. With stock k member and steering box it will be very difficult to use the dry sump.
Re: opinion on 340 R3/w8 (358ci) [Re: 340KID] #1664452
08/28/14 11:55 PM
08/28/14 11:55 PM
Woodbury, CT.
mcduff Offline
mcduff  Offline
Woodbury, CT.
Good Info & advise above.........
Nice combo, plenty of HP & Torque to put you in the 10.0, upper 9s bracket range. Weight will be in the 3050 - 3100lb range + driver. Like Actionange said keep it simple. You want low maintenance and consistancy with any choice you make for a bracket motor...from what I have seen...W8s and their high RPM operating requirements tend to be on the more expensive side to maintain.
I would recommend that you give Ryan Johnson at Shady Dell a call...One of the best guys out there when it comes to SB Mopars.
Brett Miller 447 W9
Re: opinion on 340 R3/w8 (358ci) [Re: mcduff] #1664453
08/29/14 01:30 AM
08/29/14 01:30 AM
australia
charger410 Offline
charger410  Offline
australia
It will fit with the Dry sump pump but it'll be murder
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
Re: opinion on 340 R3/w8 (358ci) [Re: charger410] #1664454
08/29/14 01:36 AM
08/29/14 01:36 AM
australia
charger410 Offline
charger410  Offline
australia
sump
Re: opinion on 340 R3/w8 (358ci) [Re: charger410] #1664455
08/29/14 01:42 AM
08/29/14 01:42 AM
australia
charger410 Offline
charger410  Offline
australia
Your headers will be the hardest part with the Factory K member and torsion bars
Re: opinion on 340 R3/w8 (358ci) [Re: charger410] #1664456
08/29/14 11:31 AM
08/29/14 11:31 AM
CT
3
340KID Offline OP
340KID  Offline OP
CT
thanks for the info guys, I'm thinking it just wont be practical to try to fit it in the Scamp between headers and dry sump !
Page 1 of 3 1 2 3
