A100 Dodge pick up parts #1663550
08/25/14 05:40 PM
08/25/14 05:40 PM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
I just started to restore a 1964 A100.
Changed over to 360 with auto from 6 cyl. 3speed.
Is there any body else working on one.
Have questions and looking for part source for some pieces.
Thanks Jim
Re: A100 Dodge pick up parts [Re: dafixr] #1663551
08/25/14 08:41 PM
08/25/14 08:41 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
Hit up RodStRace here on Moparts, he might be able to help or point you in the right direction...
When you work on Spaceships for a living, how bad can a workday be?
Re: A100 Dodge pick up parts [Re: dafixr] #1663552
08/30/14 01:29 AM
08/30/14 01:29 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Ebay has the motor mounts you will need listed right now.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: A100 Dodge pick up parts [Re: BloFish] #1663553
08/30/14 09:10 PM
08/30/14 09:10 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
This is off the top of my head, some stuff may not be right...
Edited to add some links!
Seals - Restoration Specialties has almost everything except the vent windows. Yours will be the 'early' style that is different from the 'late' style that covers many more years. They have said they will bring out the late style for years...
http://www.restorationspecialties.com/Products.html
Avoid the place in LA CA, the seals from them have many poor reviews.
Gaskets - The moparts member from Detroit was going to gear up for these, I don't know how far along he got. He has some already.
http://www.detroitmuscletechnologies.com/dodge-truck-19/
Glass - all flat, try your local company.
Steering - the drag link and one tie rod end are tough, the rest can be sourced. You need to determine what axle/suspension you have to get the right stuff.
Brakes, try the usual sources. I got the 3 brake hoses from a guy on EBay from Brazil. Good seller.
67-up use dual master. A disc conversion is available, you need to determine which spindle you have (regular or HD).
https://scarebird.com/index.php?route=product/product&path=64&product_id=127
Shifter for auto - 3 different styles over the years. Again, yours will be the rarest 'early' style.
Radiator and gas tank - no repops and most require refrub/replacement. Gotta figure out what will work with your budget.
Door handles/locks - shared with early A bodys, not repopped.
Seat foam and covers - new available but expensive.
http://www.legendaryautointeriors.com/
Wiring - often in poor shape, no repop.
Repair panels - there is one of the old style (not very good) makers that does lower sections.
http://www.rustrepair.com/PANELS/DODGE-64-VAN-BODY-PANELS-REPAIR.HTM
This place had good reviews, but probably still not AMD quality.
http://www.surplussupplyco.com/
Manuals - available online either original paper or .pdfs on CD. Strongly suggest getting the correct one for your PU. They are simple beasts, but there are some strange areas that the manual really helps with. There is also the original dealer slideshow showing all the unique features of them on you tube which is fun and good info.
sites - vintage-vans, but the level of knowledge tends to be low. Yahoo Dodge A100 group, has many years of posts and some great info, but very slow and ya gotta weed through the posts to find the gold.
The sweptline site also has a section on A-100s.
http://www.sweptline.org/forums/
http://www.sweptline.com/lit/parts.html
Repop (unique A100 parts, not just mechanical stuff) - as said, the seats foam and covers, headlight bezels, seals and gaskets and some repair sheetmetal. The tail light lenses are shared with trailers (check NAPA). No other trim, handles, latches, interior parts are made that I know of. As far as mechanical/electrical stuff, keep searching local stores and online (rockauto) for availability.
Brake/clutch pedal pads
http://www.jegs.com/webapp/wcs/stores/se...rm=cb+196+pedal
Shifter cables
http://imperialservices.net/Truckpart.html
Backup lenses (67-up)
http://www.jobrated.com/11_electrical_parts.html
Re: A100 Dodge pick up parts [Re: RodStRace] #1663554
09/03/14 06:11 PM
09/03/14 06:11 PM
California City, CA
dart440 Offline
dart440  Offline
California City, CA
Great info John...I knew you would know...
Re: A100 Dodge pick up parts [Re: dafixr] #1663555
09/03/14 11:38 PM
09/03/14 11:38 PM
IL us
I
ink Online content
ink  Online Content
I
IL us
i have many many a100 parts
Re: A100 Dodge pick up parts [Re: dafixr] #2608219
01/17/19 07:08 PM
01/17/19 07:08 PM
SoCal
A100Gary Offline
A100Gary  Offline
SoCal
I saw your post about the 64 A100 you were starting. Still have it? My 65 A100 pickup still has the slant, but was upgraded with a super six package. I am looking for door lock cyls, and vent window seals. Any ideas?? Gary
Re: A100 Dodge pick up parts [Re: A100Gary] #2608227
01/17/19 07:22 PM
01/17/19 07:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The last post before yours was 5 years ago.
Don't be the exception.
Re: A100 Dodge pick up parts [Re: dafixr] #2608281
01/17/19 09:40 PM
01/17/19 09:40 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Steel Rubber Products has the best vent wing window gaskets on the market bar none.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: A100 Dodge pick up parts [Re: BloFish] #2608453
01/18/19 05:00 AM
01/18/19 05:00 AM
North America
2002bluert Offline
2002bluert  Offline
North America
Im rebuilding a 67 A100 truck and I have found quite a few parts available such as gas tanks the straps gas pedal most seals headlight trim and lots more plus I have parts myself. I myself am looking for a battery box.
Re: A100 Dodge pick up parts [Re: dafixr] #2608510
01/18/19 11:58 AM
01/18/19 11:58 AM
E
earlymopar Offline
earlymopar  Offline
E
Vans has several parts available:
https://vansauto.com/
- EM
Re: A100 Dodge pick up parts [Re: dafixr] #2608586
01/18/19 02:31 PM
01/18/19 02:31 PM
SoCal
A100Gary Offline
A100Gary  Offline
SoCal
Thanks BloFish. I will check Steel out
Re: A100 Dodge pick up parts [Re: 2002bluert] #2608607
01/18/19 03:02 PM
01/18/19 03:02 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I have one for sale.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
