replaced all relays and hall- 88 ram still won't start #1663371
08/25/14 11:03 AM
08/25/14 11:03 AM
Tennessee usa
8
88 ragin ram Offline OP
Tennessee usa
I have replaced the hall effect, starter relay, asd, and cut off relay along with coil. cranks great won't fire up. with key on no power to coil, but no short in the wire, is that normal? or could the ign switch be bad? I am at a loss on this one i have tried everything... HELP!
Re: replaced all relays and hall- 88 ram still won't start [Re: 88 ragin ram] #1663372
08/25/14 11:11 AM
08/25/14 11:11 AM
Andrewh Online content
Andrewh  Online Content
hotwire the coil and see if it fires.
then check at the bulkhead connector for power. it could be that or the switch.
Re: replaced all relays and hall- 88 ram still won't start [Re: 88 ragin ram] #1663373
08/25/14 11:12 AM
08/25/14 11:12 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Ignition switch could be bad. If I remember an '88 still has a spark control computer of some sort? Been a long time, last one I worked on, it got tossed and installed a Mopar electronic ignition conversion kit.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: replaced all relays and hall- 88 ram still won't start [Re: Andrewh] #1663374
08/25/14 01:49 PM
08/25/14 01:49 PM
Tennessee usa
8
Tennessee usa
won't fire... going to the switch next
Re: replaced all relays and hall- 88 ram still won't start [Re: 3hundred] #1663375
08/25/14 01:51 PM
08/25/14 01:51 PM
Tennessee usa
8
Tennessee usa
will the conversion work with the tbi system?
Re: replaced all relays and hall- 88 ram still won't start [Re: 88 ragin ram] #1663376
08/25/14 02:00 PM
08/25/14 02:00 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Sorry, don't think so. I was thinking of an '86 (carbureted) when I typed that.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: replaced all relays and hall- 88 ram still won't start [Re: 3hundred] #1663377
08/25/14 02:17 PM
08/25/14 02:17 PM
Tennessee usa
8
Tennessee usa
Thanks i am getting to the point of just changing everything, from tbi to carb and the ign. system at this point... :javascript:void(0)Twork:
Re: replaced all relays and hall- 88 ram still won't start [Re: 88 ragin ram] #1663378
08/25/14 02:25 PM
08/25/14 02:25 PM
wait.
you hot wired the coil and it still didn't fire?
then it might not be the switch.
is this a lean burn setup?
Re: replaced all relays and hall- 88 ram still won't start [Re: Andrewh] #1663379
08/25/14 02:45 PM
08/25/14 02:45 PM
Tennessee usa
8
Tennessee usa
tbi not lean burn
Re: replaced all relays and hall- 88 ram still won't start [Re: Andrewh] #1663380
08/25/14 04:49 PM
08/25/14 04:49 PM
Tennessee usa
8
Tennessee usa
rechecked and didn't have the coil wire hooked up! da, got it to start long enough to set the timing but all it will do is idle and when i give it gas it stalls out... what am i missing here?
Re: replaced all relays and hall- 88 ram still won't start [Re: 88 ragin ram] #1663381
08/25/14 04:54 PM
08/25/14 04:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you checked fuel pressure?
Re: replaced all relays and hall- 88 ram still won't start [Re: stumpy] #1663382
08/25/14 05:20 PM
08/25/14 05:20 PM
Castlegar, BC, Canada
That AMC Guy Offline
Check for codes. Throttling up and getting no response could be either TPS or fuel regulator.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: replaced all relays and hall- 88 ram still won't start [Re: stumpy] #1663383
08/25/14 05:28 PM
08/25/14 05:28 PM
Tennessee usa
8
Tennessee usa
got great pressure might be to much.
Re: replaced all relays and hall- 88 ram still won't start [Re: That AMC Guy] #1663384
08/25/14 05:30 PM
08/25/14 05:30 PM
Tennessee usa
8
Tennessee usa
codes are fine and tps is working good might be regulator have to check that one. the tbi was rebuilt.
[image]javascript:void(0)[/image]
Re: replaced all relays and hall- 88 ram still won't start [Re: 88 ragin ram] #1663385
08/25/14 06:31 PM
08/25/14 06:31 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If it's idling pretty well, then them holley lawn sprinklers are probably okay. Wouldn't hurt to plumb a pressure gauge in the hose to test the actual pressure though.
Re: replaced all relays and hall- 88 ram still won't start [Re: buildanother] #1663386
08/25/14 09:08 PM
08/25/14 09:08 PM
GoDartGo Offline
GoDartGo  Offline
check for lose ground wire. the local Dodge dealer replaced
two "brains" in my '88 D250 before I found a lose wire
that was killing the computer.
if you fine a lose wire, you might have a bad "brain".
Re: replaced all relays and hall- 88 ram still won't start [Re: GoDartGo] #1663387
08/25/14 09:25 PM
08/25/14 09:25 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
did you set base timing properly ( coolant sensor unplugged)? is the map sensor hooked up? vacuum and electrical ? throttle position sensor, oxygen sensor. you really need a scan tool to read what the sensors are doing, otherwise keep throwing parts at it. grounds are very important. you can try and tap lightly on the computer, sometimes if it is bad, the tapping will make something happen, it should not studder at all when hit,Light tap NO big hammers.
