Re: replaced all relays and hall- 88 ram still won't start
[Re: 88 ragin ram]
#1663373
08/25/14 11:12 AM
08/25/14 11:12 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
Ignition switch could be bad. If I remember an '88 still has a spark control computer of some sort? Been a long time, last one I worked on, it got tossed and installed a Mopar electronic ignition conversion kit.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 88 ragin ram]
#1663378
08/25/14 02:25 PM
08/25/14 02:25 PM
Andrewh
won't fire... going to the switch next
wait. you hot wired the coil and it still didn't fire? then it might not be the switch.
is this a lean burn setup?
[Re: stumpy]
#1663382
08/25/14 05:20 PM
08/25/14 05:20 PM
Posts: 4,802 Castlegar, BC, Canada
That AMC Guy
Check for codes. Throttling up and getting no response could be either TPS or fuel regulator.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: buildanother]
#1663386
08/25/14 09:08 PM
08/25/14 09:08 PM
Posts: 1,527 Michigan
GoDartGo
check for lose ground wire. the local Dodge dealer replaced two "brains" in my '88 D250 before I found a lose wire that was killing the computer. if you fine a lose wire, you might have a bad "brain".
