Re: Scarebird rear brakes:has anyone used them?
[Re: AlexP]
#1663257
08/25/14 04:06 PM
08/25/14 04:06 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I'd prefer Doc Diff's setup because he can provide the parking brake cables to fit your application, with the Scarebird you have to scare up (pun intended) your own and that's often not as easy as it sounds.
[Re: Uhcoog1]
#1663259
08/25/14 06:54 PM
08/25/14 06:54 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Does the dr diff 11 3/4' cobra setup fit under 15" wheels?
If his 11.75" front rotors could, I don't see why his rears couldn't...
If someone has a 15" wheel near me, I could test fit one.
[Re: MuuMuu101]
#1663260
08/25/14 07:44 PM
08/25/14 07:44 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I don't know about Scarebird's rear kit but people seem to like their front A-body kit for sbp. Dr Diff also uses off the shelf rotors for the rears.
Psssst....next time put a rag on top of the jack stand so you don't scratch up the new diff paint.
[Re: OzHemi]
#1663264
08/26/14 03:47 AM
08/26/14 03:47 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
[Re: MuuMuu101]
#1663265
08/26/14 11:31 AM
08/26/14 11:31 AM
Posts: 40 upper So. CA
ntsqd
upper So. CA
General Rule of Thumb is that the max rotor OD for any given wheel size is 3" smaller than the wheel. So 12" rotor in a 15" wheel, 13" rotor in a 16" wheel, etc. Can sometimes sneak a slightly larger rotor in, but it can get tricky. Caliper to wheel clearance is a different critter and will depend on the specific wheel and the specific caliper.
I used to swerve around my hallucinations, now I drive right thru them.
