Scarebird rear brakes:has anyone used them? #1663253
08/24/14 08:55 PM
08/24/14 08:55 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I forgot about them for quite a while. They seem like a good choice because they use a shelf rotor and caliper. I just can't tie myself into a rear rotor that has to be a redrilled piece to fit.
My questions are:
Is the 11.75" rotor a solid or vented piece?
They refer to it as a full sized rotor, is that full sized car? Whay ford application would that be?
Are there good pads available for the ram caliper?
How balanced will the 11.75 rotors be with the same size up front with a viper caliper? Is it as simple as just running a way less aggressive pad in the rear?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Scarebird rear brakes:has anyone used them? [Re: AlexP] #1663254
08/24/14 09:04 PM
08/24/14 09:04 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I don't know about Scarebird's rear kit but people seem to like their front A-body kit for sbp. Dr Diff also uses off the shelf rotors for the rears.
Re: Scarebird rear brakes:has anyone used them? [Re: AlexP] #1663255
08/25/14 11:27 AM
08/25/14 11:27 AM
USA
Consulier Offline
Consulier  Offline
USA
I started with them on my Satellite with the Viper calipers up front.
I took them off because I could never get the bias where I liked it and that was with a couple different pads. Not sure if it's just not a good mix between piston sizes, but I didn't care for them at all and switched to the Dr Diff Cobra stuff.
Re: Scarebird rear brakes:has anyone used them? [Re: Consulier] #1663256
08/25/14 02:24 PM
08/25/14 02:24 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
I believe the rear kit uses an 11¼" Ford rotor. You can order these cross drilled and slotted. I run this bracket, but slightly modified it for it to fit a Wilwood aluminum metric caliper. Works good or me. No e-brake.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Scarebird rear brakes:has anyone used them? [Re: AlexP] #1663257
08/25/14 04:06 PM
08/25/14 04:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'd prefer Doc Diff's setup because he can provide the parking brake cables to fit your application, with the Scarebird you have to scare up (pun intended) your own and that's often not as easy as it sounds.
Re: Scarebird rear brakes:has anyone used them? [Re: John_Kunkel] #1663258
08/25/14 05:15 PM
08/25/14 05:15 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Does the dr diff 11 3/4' cobra setup fit under 15" wheels?
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Scarebird rear brakes:has anyone used them? [Re: Uhcoog1] #1663259
08/25/14 06:54 PM
08/25/14 06:54 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
If his 11.75" front rotors could, I don't see why his rears couldn't...
If someone has a 15" wheel near me, I could test fit one.
Re: Scarebird rear brakes:has anyone used them? [Re: MuuMuu101] #1663260
08/25/14 07:44 PM
08/25/14 07:44 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Psssst....next time put a rag on top of the jack stand so you don't scratch up the new diff paint.
Re: Scarebird rear brakes:has anyone used them? [Re: MuuMuu101] #1663261
08/26/14 12:57 AM
08/26/14 12:57 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
My 11.7" rear disc brakes fit a few 15" wheels.
I normally recommend my 10.7" version for use with 15" wheels.
Re: Scarebird rear brakes:has anyone used them? [Re: DoctorDiff] #1663262
08/26/14 01:27 AM
08/26/14 01:27 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Do they both use the same caliper?
Re: Scarebird rear brakes:has anyone used them? [Re: AlexP] #1663263
08/26/14 01:38 AM
08/26/14 01:38 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes.
Re: Scarebird rear brakes:has anyone used them? [Re: OzHemi] #1663264
08/26/14 03:47 AM
08/26/14 03:47 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
The guy who built my carrier painted it for me and already scratched it before I picked it up. But good tip. I just need to buy more rags. I was planning on sanding it down a little and spraying over it when I was ready to put it in.
Re: Scarebird rear brakes:has anyone used them? [Re: MuuMuu101] #1663265
08/26/14 11:31 AM
08/26/14 11:31 AM
upper So. CA
N
ntsqd Offline
ntsqd  Offline
N
upper So. CA
General Rule of Thumb is that the max rotor OD for any given wheel size is 3" smaller than the wheel. So 12" rotor in a 15" wheel, 13" rotor in a 16" wheel, etc. Can sometimes sneak a slightly larger rotor in, but it can get tricky.
Caliper to wheel clearance is a different critter and will depend on the specific wheel and the specific caliper.
I used to swerve around my hallucinations, now I drive right thru them.
Re: Scarebird rear brakes:has anyone used them? [Re: ntsqd] #1663266
08/26/14 11:50 AM
08/26/14 11:50 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes. My 11.7" rear brakes do not fit all 15" wheels because the rotor is fairly flat. This limits caliper clearance.
