trouble installing TTI exhaust on E Body #1663090
08/24/14 04:55 PM
08/24/14 04:55 PM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
Installing 2 and a half inch TTI system on a 70 Cuda. Its a 426 hemi crate motor with stock exhaust monifolds. Its the H-pipe system. Got right side on but when Iput left muffler into H pipe its 2 or 3 inches inside the exhaust hanger. Any one else have issues with this system. Any ideas?
Re: trouble installing TTI exhaust on E Body [Re: 70cudaMD] #1663091
09/02/14 03:24 PM
09/02/14 03:24 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
My son put a 3" system on his Challenger and the fit using the TTi headers was horrible. Right side was way too close to the driveshaft and both sides were too low. Ended up pie cutting the H-pipe in multiple places to make it fit the way it should. Will never buy another. Just have one made.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: trouble installing TTI exhaust on E Body [Re: 70cudaMD] #1663092
09/02/14 06:52 PM
09/02/14 06:52 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Call TTI and make sure you have the correct pipes in the right spots?
Re: trouble installing TTI exhaust on E Body [Re: 70cudaMD] #1663093
09/02/14 06:58 PM
09/02/14 06:58 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
What mufflers are you using?
First system I installed didn't fit right, then I noticed small small numbers on the end of each pipe. Once I matched all those numbers up it fit like a glove.
Then the second one fit great also, match the numbers up, there on each pipe I believe. It's easy to get them mixed up.
Re: trouble installing TTI exhaust on E Body [Re: Challenger 1] #1663094
09/02/14 07:33 PM
09/02/14 07:33 PM
BDW Offline
BDW  Offline
My system didn't fit either (70 Challenger SB), finally figured out they had shipped a wrong part.
Double check everything as mentioned.
Re: trouble installing TTI exhaust on E Body [Re: 70cudaMD] #1663095
09/02/14 11:59 PM
09/02/14 11:59 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Was it a complete TTI system? I put one on a B body and could not believe how well it fit. First hour or so I was trying to put the left side exhaust on the right side, but once I figured that out....
Re: trouble installing TTI exhaust on E Body [Re: 70cudaMD] #1663096
09/03/14 03:12 AM
09/03/14 03:12 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Is your engine sitting in the proper location? They usually make that a big point in their header fitment.
Re: trouble installing TTI exhaust on E Body [Re: 70cudaMD] #1663097
09/03/14 03:14 AM
09/03/14 03:14 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
TTI customer service SUCKS......well it did 12 years Ago.
Good luck
Re: trouble installing TTI exhaust on E Body [Re: 70blackfish] #1663098
09/03/14 11:22 AM
09/03/14 11:22 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I put on the TTI 2" headers with the 3 1/2" collectors and the complete 3" TTI exhaust on my 70 Challenger and they fit great. It is tight but with the 3" pipes you should expect that.
