1967 superstock intake vanke mod #1662957
08/24/14 01:47 PM
08/24/14 01:47 PM
wisconsin united states
K
keith airgrabber Offline OP
Right in the Nutz!!!
K
Just bought this intake. The guy I bought it from stated it was from a superstock car 1966-67. According to the numbers it is an early manifold with CDPC instead of the pentastar. The walls are cut out that looks factory. The book I have states "wall cut" for superstock. So to me it appears real. There is a piece of aluminum welded in. I did some research and it is the Arlen Vanke mod I guess alot of people did for more power at the track. So this is the manifold that would have came on the WO and RO23 cars. Would the factory have welded that little damn of aluminum in? I took off the underside heat shield and found aluminum foil jammed in there. I unwrappped one of the pieces and found what I think is espestos. Not sure. But I am guessing it would have been to keep the heat away for a cooler airfuel mixture. Also what is that big plug for on the underside of the intake? I included some pictures.
Re: 1967 superstock intake vanke mod [Re: keith airgrabber] #1662958
08/24/14 01:48 PM
08/24/14 01:48 PM
K
K
another picture
Re: 1967 superstock intake vanke mod [Re: keith airgrabber] #1662959
08/24/14 01:49 PM
08/24/14 01:49 PM
K
K
another
Re: 1967 superstock intake vanke mod [Re: keith airgrabber] #1662960
08/24/14 01:51 PM
08/24/14 01:51 PM
K
K
more
Re: 1967 superstock intake vanke mod [Re: keith airgrabber] #1662961
08/24/14 01:52 PM
08/24/14 01:52 PM
K
K
one more
Re: 1967 superstock intake vanke mod [Re: keith airgrabber] #1662962
08/24/14 01:55 PM
08/24/14 01:55 PM
K
K
Also what does WBAC And M1 mean on the front of the manifold? And here is a picture of some numbers on the back. Any meaning for these also?
Re: 1967 superstock intake vanke mod [Re: keith airgrabber] #1662963
08/24/14 05:57 PM
08/24/14 05:57 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What you have there is a late '66, early '67 manifold. Did that version come on the RO/WO cars. I don't know. The manifold transition occurred sometime in '67 but I don't know when, maybe somebody else does. I do not know the significance of the number that is in the small block on the rear of the manifold and I have never heard of anyone that does.
Re: 1967 superstock intake vanke mod [Re: 6PakBee] #1662964
08/24/14 11:35 PM
08/24/14 11:35 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
That is as stated a late 66/early 67 piece. Parts were randomly taken from inventory, there was no set changeover date. That said I've owned 3 67 Hemi cars with their original intakes, two were late November 66 SPD cars, one was a late October 66 SPD, all 3 were St. Louis cars and had the later style Pentastar intake, and I'd bet that most other 67's after November 66 had them as well. That's not to say an older one wasn't used later, it's just less likely, especially as late as the spring of 67 when the R0/W0 cars were first built. I've never seen the foil insulation under a Hemi intake, just a similar style in street/production line big block valley pans. Interesting piece.
Re: 1967 superstock intake vanke mod [Re: keith airgrabber] #1662965
08/25/14 12:38 AM
08/25/14 12:38 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
This is an intake that I got when i bought a 67 RO/WO Hemi engine years ago. I sold the block to hemi joel on the board years ago, but still have the intake.
Re: 1967 superstock intake vanke mod [Re: fastmark] #1662966
08/25/14 12:40 AM
08/25/14 12:40 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The modification.
Re: 1967 superstock intake vanke mod [Re: fastmark] #1662967
08/25/14 12:41 AM
08/25/14 12:41 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
from the top.
Re: 1967 superstock intake vanke mod [Re: fastmark] #1662968
08/25/14 12:42 AM
08/25/14 12:42 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Bottom has the standard heat shield.
Re: 1967 superstock intake vanke mod [Re: fastmark] #1662969
08/25/14 02:03 AM
08/25/14 02:03 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Foundry marks. The same WBAC could be found on other similar vintage intakes and cast parts (1965 Hemi cross rams for instance). Some numbers are dates, shift information, and material type (metal type/grade, etc.). I haven't seen any data that will take you much further on those markings.
Re: 1967 superstock intake vanke mod [Re: ScottSmith_Harms] #1662970
08/25/14 03:07 AM
08/25/14 03:07 AM
K
K
It looks like aluminum. How could one tell if it would be Magnesium? I paid $400 for it. I will probably hold on to it and maybe build a Hemi one day.
Re: 1967 superstock intake vanke mod [Re: keith airgrabber] #1662971
08/25/14 11:40 AM
08/25/14 11:40 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I've never seen a magnesium Street Hemi intake, only cross rams and some NASCAR single 4 versions). If one were to exist it would be MUCH lighter in weight than an aluminum version. An aluminum intake weighs roughly 26lbs with the throttle return spring brackets, throttle cable bracket, intake bolts, and oil shield in place.
Re: 1967 superstock intake vanke mod [Re: keith airgrabber] #1662972
08/25/14 11:41 AM
08/25/14 11:41 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
I believe all in-lines were aluminum. Some Race Hemi cross rams came in Magneseum.
MLR426
Re: 1967 superstock intake vanke mod [Re: keith airgrabber] #1662973
08/26/14 12:19 AM
08/26/14 12:19 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
The dam is proper. I thought both of the ones I had were no pentstar.
2011 Drag Pak Challenger
