Speedo Sending Unit
#1662666
08/23/14 03:51 PM
08/23/14 03:51 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I have aftermarket gauges in the Dart and am trying to figure out what I need for the speedo input. It is a single wire/signal input.
Is there something I can use with an A833 to produce this signal? I don't have the install instructions for the speedometer in front of me (need to find them).
Thanks.
383, Hemi 4-Speed, AlterKtion, D60
Re: Speedo Sending Unit
[Re: Crazy68Dart]
#1662667
08/23/14 05:58 PM
08/23/14 05:58 PM
Posts: 25,836 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The speed sensor for most aftermarket speedos will thread onto the same place on the trans that the mechanical speedo cable does. Some have a sensor that installs closer to the speedo (needs a cable with a threaded end up top).
[Re: Sport440]
#1662671
08/23/14 11:56 PM
08/23/14 11:56 PM
Crazy68Dart
Canton, Ohio
Thanks. I looked at those today. What is the size for the a833? Is it 7/8s?
Also saw the GPS units which are kinda cool too.
