Re: D100 B van LCA swap what do I need?
[Re: 76dodgeboy]
#1661772
08/21/14 03:33 PM
08/21/14 03:33 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
mid 70s to at least 97
78-98 for sure that I know of I've not used any newer or older than that
[Re: 70Duster440]
#1661774
08/22/14 07:36 PM
08/22/14 07:36 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
For specifics on the lowers, here's what we used on our '75 D100 recently:
From RockAuto they were Dorman part nos: 520335 (520-335) and 520336 (520-336) - still available for about $78 each.
As mentioned in other threads you have to: remove the steering arm bump stop, drill for the strut rod, enlarge the bushing bolt hole in the frame, and remove some material around the bushing flange.
I had to do all of the above on our 84 except the removal of material around the bushing flange.
Last I knew, new upper control arms were still available......but not needed for this swap....if that's what your thinking...???
Rickster
