race shifter ? #1661642
08/20/14 07:20 PM
08/20/14 07:20 PM
ohio
all spooled up Offline OP
ohio
I have a 727 reverse pattern in a drag only car. what dos ever one like for shifters. ive only had two diferant ones in 30 years had a turbo action and a hurst 1/4 stick i did not like those shifters
Re: race shifter ? [Re: all spooled up] #1661643
08/20/14 07:30 PM
08/20/14 07:30 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
I have had my Dixie electric shifter for 20 years. has always worked flawless with my 727
Re: race shifter ? [Re: Plymouth340] #1661644
08/20/14 07:46 PM
08/20/14 07:46 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Winters Sidewinder or Turbo Action.
Re: race shifter ? [Re: rt66jim] #1661645
08/20/14 07:47 PM
08/20/14 07:47 PM
tboomer Offline
tboomer  Offline
I have had a Winters Sidewinder for about 15 years. Nice shifter.
Re: race shifter ? [Re: tboomer] #1661646
08/20/14 07:51 PM
08/20/14 07:51 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I use a B & M Pro Ratchet shifter in mine. Very good race shifter for a Rev Manual valve body. Can be a pain to get adjusted sometimes, but very reliable.
Brian
Re: race shifter ? [Re: '72CudaRacer] #1661647
08/20/14 08:15 PM
08/20/14 08:15 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Just bought another quarter stick for my new car after using one forever in the old ride.
They are bulletproof,
Don't know honestly how anything could work any better, they are foolproof
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: race shifter ? [Re: B3422W5] #1661648
08/20/14 08:18 PM
08/20/14 08:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
If you want the BEST shifter out there then PPP is #1 by far. Walk around the pits at a national or divisional event and look and see what the SS and Comp guys are using. They aint cheap but they are the best.
Re: race shifter ? [Re: Al_Alguire] #1661649
08/20/14 08:27 PM
08/20/14 08:27 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I have a PPP in my car, it's a very nice piece.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: race shifter ? [Re: DemonDust] #1661650
08/20/14 08:31 PM
08/20/14 08:31 PM
ohio
ohio
any one have a pic of the winters sidewinder
Re: race shifter ? [Re: all spooled up] #1661651
08/20/14 10:19 PM
08/20/14 10:19 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I've had my turbo action shifter since the mid 80's. No complaints. Taking it out of my cuda and putting it in my 67 Belvedere(I'll have it done before the cuda) and then when I start updating the cuda I'll be getting another one.
Ok
Re: race shifter ? [Re: all spooled up] #1661652
08/20/14 10:56 PM
08/20/14 10:56 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
It's the same as the Turbo Action best I can tell.
https://www.google.com/search?q=winters+...794&dpr=0.8
PPP shifter
https://www.google.com/search?q=PPP+shif...mp;ved=0CDMQsAQ
Buy a Lenco and be done with it
Re: race shifter ? [Re: roadhazard] #1661653
08/20/14 11:23 PM
08/20/14 11:23 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
i use a turbo action for years
Re: race shifter ? [Re: B3422W5] #1661654
08/21/14 12:42 AM
08/21/14 12:42 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Doesn't the Hurst 1/4 stick look alot like this B & M Pro Stick ?
I though the one my buddy had did. Myself I like this B & M Pro Stick alot. It does not cost a ton of money and its simple reliable and easy to use and works great when racing. Ron
Re: race shifter ? [Re: '72CudaRacer] #1661655
08/21/14 02:37 AM
08/21/14 02:37 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
PPP...
Re: race shifter ? [Re: 383man] #1661656
08/21/14 03:00 AM
08/21/14 03:00 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Ron, I thought you were still pushing buttons
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: race shifter ? [Re: all spooled up] #1661657
08/21/14 05:00 AM
08/21/14 05:00 AM
Cab_Burge Online work
Cab_Burge  Online Work
I like the old Fairbanks, Winters, Turbo Action H.D. garbage truck industrial type floor shifters I've had three of them in three different cars so far I have worn out both a B&M and Hurst ratchet shifters in two other bracket cars in not much time, maybe four years of racing twice a month each year a long time ago I like the ease of installation and the ease of shifting the Fairbanks and Winters reverse pattern shifters, there not as near as sensitive on the cable adjustments as all the other ones I have used Buy the best once and don't look back
Re: race shifter ? [Re: Cab_Burge] #1661658
08/21/14 07:32 AM
08/21/14 07:32 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
B&M Pro-ratchet is all I ever use in my car's.
Re: race shifter ? [Re: ProSport] #1661659
08/21/14 07:48 AM
08/21/14 07:48 AM
Hertford, England
Dartbloke Offline
Dartbloke  Offline
Hertford, England
Another vote for the Winters style shifter, solid, bombproof and will not jam ever. I've used most of the other shifters over the years and found them flimsy, easy to jam, fiddly to use and in a few cases, easy to hit the wrong gear. Been a Winters convert for years now.
Re: race shifter ? [Re: all spooled up] #1661660
08/21/14 06:38 PM
08/21/14 06:38 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
I really like my PPP. Great shifter and the best part is the rear entry cables. No more worrying about routing around headers and starters.
Re: race shifter ? [Re: shorthorse] #1661661
08/21/14 07:31 PM
08/21/14 07:31 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Go to Summit and try them out. They have most all of them on display.
I think you would like a ratchet type shifter the best
