Re: Ok lets talk starters
[Re: VernMotor]
#1661224
08/19/14 11:40 PM
08/19/14 11:40 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I'm very happy with my powermaster starter with no nose cone. I had no problems with at 15:1. I did however have a problem with a Chrysler mini starter with the nose cone. I had it rebuilt but it would not fit the KB block very well so that was when I went with the powermaster starter.
[Re: Thumperdart]
#1661235
08/20/14 11:29 AM
08/20/14 11:29 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I don't know of anything better than a Meziere. Spins a 13:1 572 hemi like the plugs are out of it. The powerglide adapter I had didn't have room for the nose of a stock starter and the Mezeire doesn't have one. I wouldn't go back to any other starter.
2011 Drag Pak Challenger
[Re: rickseeman]
#1661236
08/20/14 11:38 AM
08/20/14 11:38 AM
Posts: 8,165 Left Coast
BobR
Left Coast
Meziere is likely the best. RobbMc also very good. We use an MSD for contingency money. Also a quality starter.
[Re: BobR]
#1661237
08/20/14 12:35 PM
08/20/14 12:35 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I have been running the same starter since I started racing in early 2000. This starter is out of a 94 Ram with a 3.9 v6 and had over 200k miles on it when I took the truck apart. Now it starts my 12.5-1 500" for the last three years.
67' charger 499 RB
10.57 at 127
[Re: camastomcat]
#1661239
08/21/14 03:57 AM
08/21/14 03:57 AM
Posts: 373 sandwich IL
sublimehemi
sandwich IL
well i just bought this bad mother ts306 revised version newley released from meziere...and got it to fit world block...summit has for 560 and i used a 10% coupon..ty moparts...i dont any starter comes close....and way lighter than ts106...lightest starter i ever held.
[Re: galen]
#1661243
08/21/14 06:38 PM
08/21/14 06:38 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I prefer the Powermaster Ultra Torque or Meziere they are 2 of the best out there.Use a Rock 16 volt battery with either one for the Ultimate cranking system. When you get up in the 500+ cu in range and 15-1+CR ratio,a good 16 volt battery is just about a must!Sure a 12 volt battery will still crank the engine,but try a 16 volt and you will see the difference.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1661244
08/21/14 08:27 PM
08/21/14 08:27 PM
sublimehemi
sandwich IL
This is slimmer and more powerful than rob mc....Rob mc will not work with world block...
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
[Re: joelson6]
#1661247
08/22/14 12:44 PM
08/22/14 12:44 PM
BobR
Left Coast
i'm not running real high compression but i'm using the same mopar performance starter that i bought back in '94. pulled the motor out to freshen it up a couple years ago and found the nose broke off. welded it back on and put it back in. i probably just jinxed myself
If you race and are serious about winning I can't think of any worse way to lose than a starter malfunction. I see this a few times a year and it's become a phobia for me. I not only use a quality starter I change it every 2 seasons.
[Re: VernMotor]
#1661248
08/22/14 12:55 PM
08/22/14 12:55 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I'm definitely not one to recommend anything from Mopar Performance, but I have their mini starters on 2 cars and they work great. The one that's on my cuda has been on it for about 14 years. I also have a factory dodge starter (off a '90 something model truck) on my 14:1 440. Had it rebuilt before I put it on...works great.
