Ok lets talk starters #1661223
08/19/14 11:20 PM
08/19/14 11:20 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
I see a lot of aftermarket starters do not have a nose cone. To me that is for not only for alignment But support also . Powermaster makes them both ways. My stock starter does not like this 14-1 compression. so I need to buy something. I have had two stock mini starters. on this car in the past. with a lot less compression and they did't live very long.Anyone have or use one of these meziere ts106 starters ? lot of money but a maybe.
Re: Ok lets talk starters [Re: VernMotor] #1661224
08/19/14 11:40 PM
08/19/14 11:40 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I'm very happy with my powermaster starter with no nose cone. I had no problems with at 15:1. I did however have a problem with a Chrysler mini starter with the nose cone. I had it rebuilt but it would not fit the KB block very well so that was when I went with the powermaster starter.
Re: Ok lets talk starters [Re: VernMotor] #1661225
08/19/14 11:41 PM
08/19/14 11:41 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
I have had nothing but stock mini starters. On everything from 498 16 to 1 b-1 572 14 to 1 b-1 and on my 14 to 1 572 predator motor never an issue. I also use a oo battery cable with grounds to the frame, block and heads
Re: Ok lets talk starters [Re: VernMotor] #1661226
08/19/14 11:46 PM
08/19/14 11:46 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
You are right. A starter w/o a cone is not reliable for a Mopar. My friends went with the Tilton w/o the cone and regretted it. Powermaster and there is one made in PA and another on Colorado. They all work well. Always get a factory rebuilt stock starter as a back up.
Re: Ok lets talk starters [Re: A/MP] #1661227
08/20/14 12:01 AM
08/20/14 12:01 AM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
The RobbMc starter also has a nose cone and is fully clockable. Very pleased with ours. I believe the latest version is even better, at least it looks like some details are improved. It is called a Generation 2 or something like that, still the same price as a few years back.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Ok lets talk starters [Re: David_in_St_Croi] #1661228
08/20/14 12:29 AM
08/20/14 12:29 AM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
RobbMc starter= 300.00 that is about what one of them meziere are.
Re: Ok lets talk starters [Re: VernMotor] #1661229
08/20/14 12:31 AM
08/20/14 12:31 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Get the RobMc and don't look back.
Re: Ok lets talk starters [Re: W5DART66] #1661230
08/20/14 12:43 AM
08/20/14 12:43 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
http://www.robbmcperformance.com/products/mopar_starter.html
Re: Ok lets talk starters [Re: Jeepmon] #1661231
08/20/14 12:49 AM
08/20/14 12:49 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Vern I use the small factory Chrysler starter. 572,15-1,34 degrees crank trigger with no retard. No issues with the starter what so ever.
Doug
Re: Ok lets talk starters [Re: dvw] #1661232
08/20/14 01:38 AM
08/20/14 01:38 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I buy them at the junkyard and take them to my local starter alternater shop for a GOOD rebuild. The better factory ones are longer (higher HP)
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Ok lets talk starters [Re: VernMotor] #1661233
08/20/14 02:01 AM
08/20/14 02:01 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Stock mini-starter out of a magnum truck iirc and this is my second one in many years.............
Re: Ok lets talk starters [Re: Thumperdart] #1661234
08/20/14 11:26 AM
08/20/14 11:26 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Stock Magnum Dakota starter on my 13:1 498 for my Challenger and everything else I have own/owned.
Re: Ok lets talk starters [Re: Thumperdart] #1661235
08/20/14 11:29 AM
08/20/14 11:29 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I don't know of anything better than a Meziere. Spins a 13:1 572 hemi like the plugs are out of it. The powerglide adapter I had didn't have room for the nose of a stock starter and the Mezeire doesn't have one. I wouldn't go back to any other starter.
2011 Drag Pak Challenger
Re: Ok lets talk starters [Re: rickseeman] #1661236
08/20/14 11:38 AM
08/20/14 11:38 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Meziere is likely the best. RobbMc also very good. We use an MSD for contingency money. Also a quality starter.
Re: Ok lets talk starters [Re: BobR] #1661237
08/20/14 12:35 PM
08/20/14 12:35 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I have been running the same starter since I started racing in early 2000. This starter is out of a 94 Ram with a 3.9 v6 and had over 200k miles on it when I took the truck apart. Now it starts my 12.5-1 500" for the last three years.
67' charger 499 RB 10.57 at 127
Re: Ok lets talk starters [Re: dragram440] #1661238
08/20/14 01:06 PM
08/20/14 01:06 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I've had good luck with the Powermaster with the nose cone. I have one for sale without it.....if that tells you anything. My compression is over 16-1
Re: Ok lets talk starters [Re: camastomcat] #1661239
08/21/14 03:57 AM
08/21/14 03:57 AM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
well i just bought this bad mother ts306 revised version newley released from meziere...and got it to fit world block...summit has for 560 and i used a 10% coupon..ty moparts...i dont any starter comes close....and way lighter than ts106...lightest starter i ever held.
Re: Ok lets talk starters [Re: sublimehemi] #1661240
08/21/14 12:51 PM
08/21/14 12:51 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
wow That is nice ! super Trick
Re: Ok lets talk starters [Re: VernMotor] #1661241
08/21/14 01:45 PM
08/21/14 01:45 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
That's same starter as RobMc and his is less money
Re: Ok lets talk starters [Re: W5DART66] #1661242
08/21/14 02:27 PM
08/21/14 02:27 PM
Missouri
galen Offline
galen  Offline
Missouri
Anyone using the Meziere or RobbMc with a 130 tooth flywheel? I have a Koleno block. Things are real tight.
