Re: Ok lets talk starters [Re: galen] #1661243
08/21/14 06:38 PM
08/21/14 06:38 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I prefer the Powermaster Ultra Torque or Meziere they are 2 of the best out there.Use a Rock 16 volt battery with either one for the Ultimate cranking system.
When you get up in the 500+ cu in range and 15-1+CR ratio,a good 16 volt battery is just about a must!Sure a 12 volt battery will still crank the engine,but try a 16 volt and you will see the difference.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Ok lets talk starters [Re: MRMOPAR622] #1661244
08/21/14 08:27 PM
08/21/14 08:27 PM
sandwich IL
sublimehemi Offline
sublimehemi  Offline
sandwich IL
This is slimmer and more powerful than rob mc....Rob mc will not work with world block...
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: Ok lets talk starters [Re: sublimehemi] #1661245
08/21/14 09:15 PM
08/21/14 09:15 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Jamie I have always run the Chrysler Mini Starters straight from the swap meets
Stay away from the cheap parts store remans though...
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Ok lets talk starters [Re: VernMotor] #1661246
08/21/14 11:45 PM
08/21/14 11:45 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
i'm not running real high compression but i'm using the same mopar performance starter that i bought back in '94. pulled the motor out to freshen it up a couple years ago and found the nose broke off. welded it back on and put it back in. i probably just jinxed myself
Re: Ok lets talk starters [Re: joelson6] #1661247
08/22/14 12:44 PM
08/22/14 12:44 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
If you race and are serious about winning I can't think of any worse way to lose than a starter malfunction. I see this a few times a year and it's become a phobia for me. I not only use a quality starter I change it every 2 seasons.
Re: Ok lets talk starters [Re: VernMotor] #1661248
08/22/14 12:55 PM
08/22/14 12:55 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
I'm definitely not one to recommend anything from Mopar Performance, but I have their mini starters on 2 cars and they work great. The one that's on my cuda has been on it for about 14 years.
I also have a factory dodge starter (off a '90 something model truck) on my 14:1 440. Had it rebuilt before I put it on...works great.
CHIP
'06 GMC 2500HD LBZ Duramax
