Re: Best smallblock head w/stock exaust pattern
[Re: justinp61]
#1661163
08/22/14 10:37 AM
08/22/14 10:37 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I have been really wondering where I will go next with my motor and this has been a good discussion thanks. I have Shady Dell stage II Edelbrocks with 2.05 intakes. My car has run a best of 11.18@120.5 364CID 3525lbs full exhaust system. I have a 4" crank and 340 block I have talked about putting together for years. Now my next project is EFI instead of that(hang on little 360 lol). I keep wondering if the next step should just be Gen III.
68 Barracuda Formula S 340
[Re: dusturbd340W5]
#1661165
08/22/14 11:49 AM
08/22/14 11:49 AM
Posts: 226 lino lakes,MN
onebaddakota
lino lakes,MN
My eddies were ported by Dr J. They flow a tad over 300 @ 600. They took my 410 with 11.8 compression and E85 to 10.53@125.6 full exhaust and factory hydraulic roller set up with a race weight of 3500 lbs. Dynoed 583 on a 850/ 596 on a dominator. I'd like to know if anyone is running hughes big mouth heads? They do have a offset intake, but factory exhaust ports. His website makes some pretty impressive claims.
10.56 at 125.6, with a 1.43 60 ft.
E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
[Re: andy3965]
#1661166
08/22/14 02:57 PM
08/22/14 02:57 PM
Posts: 300 Willow Spring
dagohman
Willow Spring
Who makes those gaskets with the dual bolt pattern? That set looks like they will work for me. I have econo W2's on my 408 in my d100. So no one makes a W2 header for that combo and I have to use standard headers. Always have trouble with them leaking.
If you are talking about the ones I posted, they are tti, and I bought them from Hughes engines
[Re: dagohman]
#1661167
08/23/14 12:29 AM
08/23/14 12:29 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Edelbrock claims a 58cc combustion chamber, not so...it's more like 63cc My heads were cut .030 and ended up at 57.9
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#1661168
08/23/14 02:47 AM
08/23/14 02:47 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Same here my Eddy's were cut to get them at 58cc combustion chambers.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: andy3965]
#1661170
08/23/14 09:21 AM
08/23/14 09:21 AM
Bad340fish
Tulsa OK
I thought the 58cc was for the magnum head and the standard was 63?
[Re: Ian]
#1661175
08/23/14 02:01 PM
08/23/14 02:01 PM
Posts: 7,506 Az
Crizila
Az
These are some CNC ported Hughes magnum Edelbrocks w/ 2.08 / 1.60 valves. Per Hughes, intakes flow 304 @ .650 and exhausts flow 223 @ .650. I measured the chambers @ 63 CC's. Probably were around 60 before the CNC work.
Fastest 300
