Page 3 of 3 1 2 3
Re: Best smallblock head w/stock exaust pattern [Re: andy3965] #1661162
08/22/14 10:22 AM
08/22/14 10:22 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Does anyone still make the W-2 to standard port adapter plates? It looks like there is still market for them.
Re: Best smallblock head w/stock exaust pattern [Re: justinp61] #1661163
08/22/14 10:37 AM
08/22/14 10:37 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have been really wondering where I will go next with my motor and this has been a good discussion thanks.
I have Shady Dell stage II Edelbrocks with 2.05 intakes. My car has run a best of 11.18@120.5 364CID 3525lbs full exhaust system.
I have a 4" crank and 340 block I have talked about putting together for years. Now my next project is EFI instead of that(hang on little 360 lol). I keep wondering if the next step should just be Gen III.
68 Barracuda Formula S 340
Re: Best smallblock head w/stock exaust pattern [Re: dagohman] #1661164
08/22/14 10:58 AM
08/22/14 10:58 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Stock header bolt location yes...But far from a stock exhaust port.
J,X or eddie, and pro comp is a stock exhaust port.I wish i could post pictures.
I'm agreeing with you. If he has to retain stock exh. Flange
I would not use the Indy heads
I don't know which would be best. I've seen several cars run great with the eddies
and people should not dismiss the Indybrocks I had a set with there cnc porting 2.05/1.60 valves on a 416 and it was pushing 650hp, car was right at 3100lbs and was running 9.7x's at 138.
and I believe it would have done a little better with a dominator but never got to try one.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Best smallblock head w/stock exaust pattern [Re: dusturbd340W5] #1661165
08/22/14 11:49 AM
08/22/14 11:49 AM
lino lakes,MN
onebaddakota Offline
lino lakes,MN
My eddies were ported by Dr J. They flow a tad over 300 @ 600. They took my 410 with 11.8 compression and E85 to 10.53@125.6 full exhaust and factory hydraulic roller set up with a race weight of 3500 lbs. Dynoed 583 on a 850/ 596 on a dominator.
I'd like to know if anyone is running hughes big mouth heads? They do have a offset intake, but factory exhaust ports. His website makes some pretty impressive claims.
10.56 at 125.6, with a 1.43 60 ft. E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
Re: Best smallblock head w/stock exaust pattern [Re: andy3965] #1661166
08/22/14 02:57 PM
08/22/14 02:57 PM
Willow Spring
dagohman Offline
dagohman  Offline
Willow Spring
Who makes those gaskets with the dual bolt pattern? That set looks like they will work for me. I have econo W2's on my 408 in my d100. So no one makes a W2 header for that combo and I have to use standard headers. Always have trouble with them leaking.
If you are talking about the ones I posted, they are tti, and I bought them from Hughes engines
Re: Best smallblock head w/stock exaust pattern [Re: dagohman] #1661167
08/23/14 12:29 AM
08/23/14 12:29 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Edelbrock claims a 58cc combustion chamber, not so...it's more like 63cc
My heads were cut .030 and ended up at 57.9
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Best smallblock head w/stock exaust pattern [Re: Adobedude] #1661168
08/23/14 02:47 AM
08/23/14 02:47 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Same here my Eddy's were cut to get them at 58cc combustion chambers.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Best smallblock head w/stock exaust pattern [Re: dagohman] #1661169
08/23/14 03:01 AM
08/23/14 03:01 AM
monticello,ms
andy3965 Offline
andy3965  Offline
monticello,ms
Thanks, I will look into getting a set.
MOPAR BORN,MOPAR BRED,AND WHEN I DIE I'LL BE MOPAR DEAD!!!
Re: Best smallblock head w/stock exaust pattern [Re: andy3965] #1661170
08/23/14 09:21 AM
08/23/14 09:21 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I thought the 58cc was for the magnum head and the standard was 63?
Re: Best smallblock head w/stock exaust pattern [Re: Bad340fish] #1661171
08/23/14 09:58 AM
08/23/14 09:58 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
They list them as 63 and 65, with the Victor at 58.
http://www.edelbrock.com/automotive/mc/cylinder-heads/chrysler/performer-rpm-sb.shtml
http://www.edelbrock.com/automotive/mc/cylinder-heads/chrysler/victor-sb.shtml
Re: Best smallblock head w/stock exaust pattern [Re: justinp61] #1661172
08/23/14 11:08 AM
08/23/14 11:08 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Has Edelbrock finaly found a deposit of unobtanium big enough to start casting those victor heads?
Re: Best smallblock head w/stock exaust pattern [Re: 1Fast340] #1661173
08/23/14 12:06 PM
08/23/14 12:06 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Last I heard( and hope I am wrong) was that Edelbrock was unhappy with the potential of the head, and we're going back to the drawing board. This was a couple of weeks ago. Buddy called them and this was what he was told
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Best smallblock head w/stock exaust pattern [Re: B3422W5] #1661174
08/23/14 12:22 PM
08/23/14 12:22 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
pro comp should have some bigger sb heads coming soon 340 cfm 240 cnc heads
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Best smallblock head w/stock exaust pattern [Re: Ian] #1661175
08/23/14 02:01 PM
08/23/14 02:01 PM
Az
Crizila Offline
Crizila  Offline
Az
These are some CNC ported Hughes magnum Edelbrocks w/ 2.08 / 1.60 valves. Per Hughes, intakes flow 304 @ .650 and exhausts flow 223 @ .650. I measured the chambers @ 63 CC's. Probably were around 60 before the CNC work.
Fastest 300
Re: Best smallblock head w/stock exaust pattern [Re: Crizila] #1661176
08/23/14 02:02 PM
08/23/14 02:02 PM
Az
Crizila Offline
Crizila  Offline
Az
exhaust
Fastest 300
Re: Best smallblock head w/stock exaust pattern [Re: Crizila] #1661177
08/23/14 02:03 PM
08/23/14 02:03 PM
Az
Crizila Offline
Crizila  Offline
Az
another
Fastest 300
Page 3 of 3 1 2 3
