Page 1 of 3 1 2 3
Best smallblock head w/stock exaust pattern #1661122
08/19/14 06:54 PM
08/19/14 06:54 PM
ont,canada
mopartuner Offline OP
ont,canada
I have a 410 ci smallblock and I would like to upgrade the Eddy heads I am using but I can only go with a stock/standard exaust pattern,any ideas?
410 pump gas solis flat tappet cam 10.95 so far
Re: Best smallblock head w/stock exaust pattern [Re: mopartuner] #1661123
08/19/14 07:22 PM
08/19/14 07:22 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
What about getting yours ported, I'm running CNC'd Eddys. Best ET in my sig.
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Best smallblock head w/stock exaust pattern [Re: Stroker Scamp] #1661124
08/19/14 07:45 PM
08/19/14 07:45 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Not many choices. The indybrock they now call the ta head is a good choice. And I don't care what anyone says they will out perform a ported standard edelbrock.
But value per dollar still points to just porting your existing heads.
There is also the mopar super commando. But I don't know how easy you can find them.
Re: Best smallblock head w/stock exaust pattern [Re: mopartuner] #1661125
08/19/14 11:04 PM
08/19/14 11:04 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Someone did a set of Pro Comps that imo will blow the eddy head out the water.
Material ( aluminum ) was even better with more meat to take out.
Re: Best smallblock head w/stock exaust pattern [Re: fishy340] #1661126
08/19/14 11:11 PM
08/19/14 11:11 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I heard results from just a procomp cnc head that impressed me.... In other words, with just the procomp " factory" cnc job.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Best smallblock head w/stock exaust pattern [Re: B3422W5] #1661127
08/19/14 11:23 PM
08/19/14 11:23 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Uh on, now you're going to get the haters in here...DUCK!!
Back on point: Where would I find such data?? I'd really be interested to see #'s from flow testing that head.
Re: Best smallblock head w/stock exaust pattern [Re: cudadoug] #1661128
08/19/14 11:34 PM
08/19/14 11:34 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Can you post the CNC flow number from the ProComp CNC head?
Tony
70 AARCuda Vitamin C
Re: Best smallblock head w/stock exaust pattern [Re: 70AARcuda] #1661129
08/19/14 11:46 PM
08/19/14 11:46 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Re: Best smallblock head w/stock exaust pattern [Re: 70AARcuda] #1661130
08/20/14 12:25 AM
08/20/14 12:25 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
It's not a secret or anything.... Lol.
A member here in a full weight bench seat A body went 10.50's at Quaker( which would be 10.30's anywhere else) with a 9.5 to 1 compression 4 inch motor.
I found that extremely impressive for a first outing.
If I remember the heads peaked at 288 ish intake. Don't know any other numbers.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Best smallblock head w/stock exaust pattern [Re: B3422W5] #1661131
08/20/14 01:47 AM
08/20/14 01:47 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
This is what I found advertised a few months ago with the ProComp CnC heads....
Tony
Re: Best smallblock head w/stock exaust pattern [Re: mopartuner] #1661132
08/20/14 08:45 AM
08/20/14 08:45 AM
maryland
74yellowduster Offline
maryland
if i was spending the money, it would be W9's all the way
http://www.mopar.com/assets/pdf/performance/catalog/Small_Block.pdf
just call shady dell have them ported / prepped
yes you will have to change headers/intake but so what, your results will be way better than what you can do with standard ports.
i wonder how much large port heads would speed you up in the 1/4?
Re: Best smallblock head w/stock exaust pattern [Re: 74yellowduster] #1661133
08/20/14 10:00 AM
08/20/14 10:00 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Some Indy 360-2 oval ports, have both exhaust patterns on them. Brett Miller on here did the set of pro comps that went 10.50s. He has a cnc program for them now.
If you go w9 route he has a cnc program for them also. I have been 9.40s on motor and 8.57@162 on spray with his w9 heads.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Best smallblock head w/stock exaust pattern [Re: 1967dartgt] #1661134
08/20/14 10:08 AM
08/20/14 10:08 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
If you go w9 route he has a cnc program for them also. I have been 9.40s on motor and [Email]8.57@162[/Email] on spray with his w9 heads.
No the set I am talking about are only cnc'ed by pro comp. the set you are talking about Brett doing haven't been used yet. Those are going on a higher compression, more max effort motor.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Best smallblock head w/stock exaust pattern [Re: B3422W5] #1661135
08/20/14 10:26 AM
08/20/14 10:26 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Indy 360-1's have W-2 and stock exhaust pattern on the heads, mine do that how I know
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Best smallblock head w/stock exaust pattern [Re: 70AARcuda] #1661136
08/20/14 11:24 AM
08/20/14 11:24 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
And those numbers "blow the Eddy's out of the water"???
I know flow benches are different but my hand ported Eddy's flowed 265 at .550. My cam is only a .520 lift so I wasn't interested in higher lift numbes.
Re: Best smallblock head w/stock exaust pattern [Re: B3422W5] #1661137
08/20/14 11:49 AM
08/20/14 11:49 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
what was the build on that motor/car
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Best smallblock head w/stock exaust pattern [Re: mopartuner] #1661138
08/20/14 11:57 AM
08/20/14 11:57 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
W9 and Indy are NOT stock exhaust and tti 1 5/8 headers wont fit which are stock style.
A few professional cylinder head guys said pro comp is a better casting and in Maz effort form will get you a better all around head.Pro Comp head max effort or even middle grade will get you nice hp without leaks etc etc.
Re: Best smallblock head w/stock exaust pattern [Re: fishy340] #1661139
08/20/14 12:10 PM
08/20/14 12:10 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Hi Ian.....
My understanding is the motor is in a Dart that is all steel except the hood, with bench seat.
60 over 340 block 1/2 filled, small roller, 4 inch crank, and cnc pro comp heads. Compression is 9.5 to 1. Quaker is about 2 tents slower than other tracks, so , IMO, running 10.30's at a "normal" track with no compression and not having a light car is real impressive.
The heads used don't have the pushrods moved over, just a cnc on a "stock" pro comp head. Maybe someone did that cnc other than pro comp, I don't know/ forgot to ask....But I do know these aren't the " trick" head Brett is working his magic on. That set of heads hasn't been put on a motor yet.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Best smallblock head w/stock exaust pattern [Re: Stroker Scamp] #1661140
08/20/14 12:27 PM
08/20/14 12:27 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Just get your heads ported. My car has ported Edelbrocks, 10.8:1 compression and a small street roller....runs mid 10's (see times in sig)....oh and I forgot to add, and a little 750dp ...lol.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Best smallblock head w/stock exaust pattern [Re: B3422W5] #1661141
08/20/14 01:16 PM
08/20/14 01:16 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
Hi Ian.....
thanks don that is way more impressive than what i am getting from my cnc indys 11.5 static comp roller cam bucket
Page 1 of 3 1 2 3
