Best smallblock head w/stock exaust pattern
#1661122
08/19/14 06:54 PM
08/19/14 06:54 PM
Posts: 614 ont,canada
mopartuner
ont,canada
I have a 410 ci smallblock and I would like to upgrade the Eddy heads I am using but I can only go with a stock/standard exaust pattern,any ideas?
410 pump gas solis flat tappet cam 10.95 so far
Re: Best smallblock head w/stock exaust pattern
[Re: mopartuner]
#1661123
08/19/14 07:22 PM
08/19/14 07:22 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
What about getting yours ported, I'm running CNC'd Eddys. Best ET in my sig.
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: B3422W5]
#1661127
08/19/14 11:23 PM
08/19/14 11:23 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Someone did a set of Pro Comps that imo will blow the eddy head out the water. Material ( aluminum ) was even better with more meat to take out.
I heard results from just a procomp cnc head that impressed me.... In other words, with just the procomp " factory" cnc job.
Uh on, now you're going to get the haters in here...DUCK!!
Back on point: Where would I find such data?? I'd really be interested to see #'s from flow testing that head.
[Re: cudadoug]
#1661128
08/19/14 11:34 PM
08/19/14 11:34 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Can you post the CNC flow number from the ProComp CNC head?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1661130
08/20/14 12:25 AM
08/20/14 12:25 AM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
It's not a secret or anything.... Lol. A member here in a full weight bench seat A body went 10.50's at Quaker( which would be 10.30's anywhere else) with a 9.5 to 1 compression 4 inch motor. I found that extremely impressive for a first outing. If I remember the heads peaked at 288 ish intake. Don't know any other numbers.
[Re: B3422W5]
#1661131
08/20/14 01:47 AM
08/20/14 01:47 AM
70AARcuda
las vegas
This is what I found advertised a few months ago with the ProComp CnC heads....
Tony
[Re: 74yellowduster]
#1661133
08/20/14 10:00 AM
08/20/14 10:00 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Some Indy 360-2 oval ports, have both exhaust patterns on them. Brett Miller on here did the set of pro comps that went 10.50s. He has a cnc program for them now. If you go w9 route he has a cnc program for them also. I have been 9.40s on motor and 8.57@162 on spray with his w9 heads.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1661134
08/20/14 10:08 AM
08/20/14 10:08 AM
B3422W5
Portage,michigan
Some Indy 360-2 oval ports, have both exhaust patterns on them. Brett Miller on here did the set of pro comps that went 10.50s. He has a cnc program for them now. If you go w9 route he has a cnc program for them also. I have been 9.40s on motor and [Email]8.57@162[/Email] on spray with his w9 heads.
No the set I am talking about are only cnc'ed by pro comp. the set you are talking about Brett doing haven't been used yet. Those are going on a higher compression, more max effort motor.
[Re: B3422W5]
#1661135
08/20/14 10:26 AM
08/20/14 10:26 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Indy 360-1's have W-2 and stock exhaust pattern on the heads, mine do that how I know
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: 70AARcuda]
#1661136
08/20/14 11:24 AM
08/20/14 11:24 AM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
And those numbers "blow the Eddy's out of the water"???
I know flow benches are different but my hand ported Eddy's flowed 265 at .550. My cam is only a .520 lift so I wasn't interested in higher lift numbes.
[Re: B3422W5]
#1661137
08/20/14 11:49 AM
08/20/14 11:49 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
what was the build on that motor/car
[Re: fishy340]
#1661139
08/20/14 12:10 PM
08/20/14 12:10 PM
B3422W5
Portage,michigan
Hi Ian.....
My understanding is the motor is in a Dart that is all steel except the hood, with bench seat. 60 over 340 block 1/2 filled, small roller, 4 inch crank, and cnc pro comp heads. Compression is 9.5 to 1. Quaker is about 2 tents slower than other tracks, so , IMO, running 10.30's at a "normal" track with no compression and not having a light car is real impressive. The heads used don't have the pushrods moved over, just a cnc on a "stock" pro comp head. Maybe someone did that cnc other than pro comp, I don't know/ forgot to ask....But I do know these aren't the " trick" head Brett is working his magic on. That set of heads hasn't been put on a motor yet.
[Re: Stroker Scamp]
#1661140
08/20/14 12:27 PM
08/20/14 12:27 PM
Posts: 1,178 Indy
FlyFish
Indy
Just get your heads ported. My car has ported Edelbrocks, 10.8:1 compression and a small street roller....runs mid 10's (see times in sig)....oh and I forgot to add, and a little 750dp ...lol.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: B3422W5]
#1661141
08/20/14 01:16 PM
08/20/14 01:16 PM
Ian
Victoria, Australia
Hi Ian.....
thanks don that is way more impressive than what i am getting from my cnc indys 11.5 static comp roller cam bucket
