Re: Valve Body Questions
[Re: ChargerKnight66]
#1660813
08/19/14 03:59 PM
08/19/14 03:59 PM
Posts: 25,783 Rio Linda, CA
John_Kunkel
Rio Linda, CA
First, do you know if the governor was removed when the MVB was installed? If so, it'll need to be replaced before installing an auto VB.
The '74 isn't an ideal swap into a '67, lots of fluid circuit changes were made starting in '74.
The stop tabs have definitely been removed, they're needed.
On the pressure regulator, measure from the VB side of the steel spring retainer to the casting...should be in the 1 1/4" to 1 1/8" range.
#1660815
08/21/14 03:28 PM
08/21/14 03:28 PM
John_Kunkel
Rio Linda, CA
The stop tab on the cam sets the forward limit of the external TP lever and its linkage.
