Oil Pump Driveshaft Wear #1660697
08/18/14 06:13 PM
08/18/14 06:13 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Does this look funny to you? This is just a heavy duty Milodon pinned shaft running with a solid flat tappet cam.
Re: Oil Pump Driveshaft Wear [Re: GTX MATT] #1660698
08/18/14 06:14 PM
08/18/14 06:14 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Another
Re: Oil Pump Driveshaft Wear [Re: GTX MATT] #1660699
08/18/14 06:18 PM
08/18/14 06:18 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
are there raised burrs on the edge of those teeth , it appears like there is , if there is that is NOT good . The teeth are too soft if that is the case , why did you choose a Milodon shaft ??
Re: Oil Pump Driveshaft Wear [Re: JohnRR] #1660700
08/18/14 06:53 PM
08/18/14 06:53 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Hmmm, I'm not certain I'll have to pull it back out and double check. I want to say no because I thought I'd notice that, but I was paying more attention to how the teeth themselves had worn on the inside.
I chose Milodon because Mancini had Mopar and Milodon, and by default I figured Milodon would be the better choice. I'm running an HV pump so I wanted a pinned driveshaft.
The cam doesn't look like the driveshaft does.
Re: Oil Pump Driveshaft Wear [Re: GTX MATT] #1660701
08/18/14 08:11 PM
08/18/14 08:11 PM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
Running to much oil pressure puts lots of extra load on that gear.
68 Barracuda Formula S 340
Re: Oil Pump Driveshaft Wear [Re: Bad340fish] #1660702
08/19/14 05:04 PM
08/19/14 05:04 PM
JohnRR Offline
JohnRR  Offline
I put a Mopar HD drive in my latest build but chose to run a std. volume pump that I ported , pressure is not too high so I think I'm ok ??? Haven't looked at the gear yet , but I will when I swap out the distributor .
Re: Oil Pump Driveshaft Wear [Re: JohnRR] #1660703
08/19/14 05:07 PM
08/19/14 05:07 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
I haven't gotten the DS out yet, oil pressure is 25 hot idle, 65 hot cruise, and 70 PSI at high RPMs, so nothing crazy.
If those edges aren't raised does the wear look normal/ok otherwise? I've never seen one look quite like that but I'm used to original used stock drives.
Re: Oil Pump Driveshaft Wear [Re: GTX MATT] #1660704
08/19/14 05:09 PM
08/19/14 05:09 PM
JohnRR Offline
JohnRR  Offline
I don't know if it's wera without seeing it , and what it looked like new. if the teeth were black when new then it's obvious that the coating will wear off with use. If no burrs then it should be fine ?
Re: Oil Pump Driveshaft Wear [Re: JohnRR] #1660705
08/19/14 05:12 PM
08/19/14 05:12 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Yeah I supposed whats throwing me for a loop is that they were black, and I don't remember the stock shafts wearing/changing colors.
Re: Oil Pump Driveshaft Wear [Re: GTX MATT] #1660706
08/19/14 07:49 PM
08/19/14 07:49 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Do you run some sort of clamp collar to stop it from bouncing? I had a bronze drive gear show marks like that but not after I put the collar on the shaft and replaced the gear.
Re: Oil Pump Driveshaft Wear [Re: Bigcube] #1660707
08/19/14 08:11 PM
08/19/14 08:11 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
This is what I was thinking
Re: Oil Pump Driveshaft Wear [Re: VernMotor] #1660708
08/20/14 02:03 PM
08/20/14 02:03 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
I'm not sure I follow, but no nothing outside of the stock setup. Should I be?
Re: Oil Pump Driveshaft Wear [Re: Bigcube] #1660709
08/20/14 02:16 PM
08/20/14 02:16 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Thanks for the reminder (I needed to install one 10 years ago... forgot)
Rich H.
Esse Quam Videri
Re: Oil Pump Driveshaft Wear [Re: ZIPPY] #1660710
08/20/14 03:17 PM
08/20/14 03:17 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
This is the shaft in question, by the way: http://chucker54.stores.yahoo.net/stoilpudras1.html
What is this collar everyone is talking about? I've never heard of this.
Re: Oil Pump Driveshaft Wear [Re: GTX MATT] #1660711
08/20/14 04:36 PM
08/20/14 04:36 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
My gues would be that something dosent line up corekly ! Remember that the oil presiure is not indication of what the load is in the gear but is your oilpump a hv ? almost al i read on oil presiure seams to end up whit speculations but i will never put a hv pump in a bb ever again whit half grove main bearings ! I run a 500+ stroker on a rb block and use a stv mellings pump on 10W40 mineral oil and presiure is never under 35psi at idel and it regulates on about 1300rpm on a REALY hot day at about 55psi ! Its not the presiure that protect the bearings and im of the belefe that whit a hv pump you will harm the internal parts even more before you see any change in presiure and why use up hp to pull a to large pump when you dont need one !? Pleas i dont whant to argue this and im no experts but this works fine on my engine and it shore saves the bronze gear i have to use whit the roller cam i have in the engine
Re: Oil Pump Driveshaft Wear [Re: GTX MATT] #1660712
08/20/14 05:26 PM
08/20/14 05:26 PM
JohnRR Offline
JohnRR  Offline
Do a search , the collar goes on the distributor shaft itself to keep the drive from walking up and down as you go on and off the throttle .
Re: Oil Pump Driveshaft Wear [Re: JohnRR] #1660713
08/20/14 05:49 PM
08/20/14 05:49 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
I shorely doubt that thas wear pattern on the gear have to do whit it moveing up and down but the collar is used for keeping the gear in place to avoid ignition walks so that will be steady at al rpmīs ! I would ask a guy that works on rear ends what that would cause this pattern. Some thing must be cut wrong or out of line !!! Is there any wear in the bushing hole that is in the block ? Many just drive that bushing in the block and forget to see to that there is the corekt zice for the shaft and if its to tight it will wear hard on the shaft.
Could the camshaft for some resone be to far in to the block ? Just a gues but mabe a good one for that kind of pattern `!?
Re: Oil Pump Driveshaft Wear [Re: Mopar Guy] #1660714
08/20/14 07:16 PM
08/20/14 07:16 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
If the slot is too deep in the drive gear there is nothing to stop it from floating up and down. Not only will your timing bounce around it will cause unusual wear to the gear. Here's a few pic to show how much it will move.
Gear seated...
With the distributor seated I pushed up on the hex where it engages in the oil pump with the pump off.
Here's a pic of the clamp collar.
I have a pic of the wear on my gear when it was bouncing but it's so out of focus you can't tell from the pic.
Hope that helps.
Re: Oil Pump Driveshaft Wear [Re: Bigcube] #1660715
08/20/14 07:21 PM
08/20/14 07:21 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Gotcha! I will be buying one now. Who sells them?
Any chance this is common with the MSD Pro Billets?
Re: Oil Pump Driveshaft Wear [Re: GTX MATT] #1660716
08/20/14 07:35 PM
08/20/14 07:35 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
It's not the distributor, it's the depth of the slot in the pump drive. Same issue with my NRC offset distributor.
