Novice 68 Fury Question #1660378
08/17/14 08:44 PM
08/17/14 08:44 PM
Northern Indiana
Focal7 Offline OP
Focal7  Offline OP
Northern Indiana
I am looking to purchase a 68 Plymouth Fury. The car is a roller with NO engine. Can anyone tell me what engines would have originally come standard..........and then also what engines will actually fit without modifications? Thanks!
Re: Novice 68 Fury Question [Re: Focal7] #1660379
08/17/14 09:15 PM
08/17/14 09:15 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
Anything from a 225 slant 6 to a 383 v8.
More than likely a 318 v8 if I were to guess
Re: Novice 68 Fury Question [Re: Focal7] #1660380
08/18/14 12:22 AM
08/18/14 12:22 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Post the 5th digit of the vin and we can tell you which one it came with. F, G, H are most likely or L if you're lucky.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Novice 68 Fury Question [Re: 3hundred] #1660381
08/18/14 09:24 PM
08/18/14 09:24 PM
Northern Indiana
Focal7 Offline OP
Focal7  Offline OP
Northern Indiana
The VIN is PE21B8D300839 The car is a Plymouth Fury II It is an original 37,000 mile car that took a front end hit in 1972 and has been stored inside since. The owner bought a front end clip form a junk car same model & year. The car had a slant six originally but know comes with a 318 core and the owner wants $900. Thanks for the help.
Re: Novice 68 Fury Question [Re: Focal7] #1660382
08/18/14 10:54 PM
08/18/14 10:54 PM
Andrewh Offline
Andrewh  Offline
no way.
no how is that a 900 dollar car from what you describe.
a front end hit on a /6 car you have to replace all the parts on is a parts car at best.
as a whole car it isn't worth 500.
parts might make it worth that if the doors are still good and the trunk is solid.
there are plenty of other fury's out there as a better starting point.
I suppose there are exceptoin reasons to consider it, but you would have to explain why you think it is a good idea.
Re: Novice 68 Fury Question [Re: Focal7] #1660383
08/19/14 10:39 AM
08/19/14 10:39 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Depending what stub frame you currently have (/6, SB, BB) you can get engine mounts from Schumacher to go from /6 to SB or SB to BB for your C-body.
Many guys over here have dealt with this and can greatly help you:
http://www.forcbodiesonly.com/mopar-forum/forum.php
Re: Novice 68 Fury Question [Re: Andrewh] #1660384
08/19/14 10:43 AM
08/19/14 10:43 AM
Commando1 Offline
Commando1  Offline
no way.
Can't say anything until there are pictures!
Re: Novice 68 Fury Question [Re: Commando1] #1660385
08/19/14 12:48 PM
08/19/14 12:48 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
no way.
I think Andy is going by his experience owning a 68 Sport Fury convertible. It was a highly optioned 383 car but was a bit rough. He was not able to sell the car whole and ended up parting it out.
- Stu Harmon
