Re: 1985 diplomat weird heat problem?
[Re: earlybee]
#166018
12/11/08 11:16 AM
12/11/08 11:16 AM
Posts: 1,324 Michigan
warmpancakes
mmm.... maple syrup.....
ill do that tonight and report back I might as well replace the hoses while im there
Note: This post may contain misspellings, grammatical errors, disorganized sentence structure, or may entirely lack
a coherent theme. These elements are natural to the process of writing, and will only add to the overall beauty of the post.
[Re: warmpancakes]
#166019
12/11/08 12:12 PM
12/11/08 12:12 PM
340dart4spd
Parts Problem
Parts Problem
[Re: 340dart4spd ]
#166020
12/11/08 01:14 PM
12/11/08 01:14 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
do you have low/lower vacuum at idle? some of the heater controls and actuators in the heater box are vacuum operated. a dry rotted vacuum line under the dash could be causing the issue...
[Re: patrick]
#166021
12/11/08 02:02 PM
12/11/08 02:02 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
I don't know about the later Dippys, but Dad had a 1980 that developed a strange problem, heater temp would vary as the car was driven. Eventually we noticed that it would happen consistently on turns, turn one way and you'd get heat, turn another way and you'd lose it.
After noticing that, we listened and could hear the heater blend door, which blends the amount of air going past the heater core, closing sometimes when the heat output would change.
End result: The dealer diagnosed a 'servo'as the problem, which caused me to investigate the vacuum pods (but no avail). Problem persisted, so I got more info from the dealer.
The servo is mounted on top of the heater box and it contains a small electric motor and some electronics to control the blend air door. I presume it is some type of crude stepper-motor setup. The factory had rebuilt ones available, and it seemed like we had to replace them every few years after the original one died.
The top metal of the dash was the easiest way (perhaps the only way?) to access it. Servo was a black plastic box about the size of 2 packs of cigs.
Again, that was a 1980, later years might be different.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
