1985 diplomat weird heat problem? #166016
12/11/08 09:35 AM
12/11/08 09:35 AM
warmpancakes Offline OP
mmm.... maple syrup.....
Car doe4s the exact opposite of what it should do? when I slow down or stop the heat gets colder, when I speed up or am at hiway speed the heat is fine? any ideas or sugestions? car doesnt run hot coolant level is fine? im stumped
Note: This post may contain misspellings, grammatical errors, disorganized sentence structure, or may entirely lack a coherent theme. These elements are natural to the process of writing, and will only add to the overall beauty of the post.
Re: 1985 diplomat weird heat problem? [Re: warmpancakes] #166017
12/11/08 11:14 AM
12/11/08 11:14 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Pull off both heater hoses at the pump and flush both ways with a garden water hose.
Re: 1985 diplomat weird heat problem? [Re: earlybee] #166018
12/11/08 11:16 AM
12/11/08 11:16 AM
ill do that tonight and report back I might as well replace the hoses while im there
Re: 1985 diplomat weird heat problem? [Re: warmpancakes] #166019
12/11/08 12:12 PM
12/11/08 12:12 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
is you alt charging??
Re: 1985 diplomat weird heat problem? [Re: 340dart4spd ] #166020
12/11/08 01:14 PM
12/11/08 01:14 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
do you have low/lower vacuum at idle? some of the heater controls and actuators in the heater box are vacuum operated. a dry rotted vacuum line under the dash could be causing the issue...
2017 Grand Cherokee Overland
Re: 1985 diplomat weird heat problem? [Re: patrick] #166021
12/11/08 02:02 PM
12/11/08 02:02 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I don't know about the later Dippys, but Dad had a 1980 that developed a strange problem, heater temp would vary as the car was driven. Eventually we noticed that it would happen consistently on turns, turn one way and you'd get heat, turn another way and you'd lose it.
After noticing that, we listened and could hear the heater blend door, which blends the amount of air going past the heater core, closing sometimes when the heat output would change.
End result:
The dealer diagnosed a 'servo'as the problem, which caused me to investigate the vacuum pods (but no avail). Problem persisted, so I got more info from the dealer.
The servo is mounted on top of the heater box and it contains a small electric motor and some electronics to control the blend air door. I presume it is some type of crude stepper-motor setup. The factory had rebuilt ones available, and it seemed like we had to replace them every few years after the original one died.
The top metal of the dash was the easiest way (perhaps the only way?) to access it. Servo was a black plastic box about the size of 2 packs of cigs.
Again, that was a 1980, later years might be different.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: 1985 diplomat weird heat problem? [Re: patrick] #166022
12/11/08 02:20 PM
12/11/08 02:20 PM
very low idle I can sit at a light with my foot off the brakes and not move
