what alternator #1659862
08/16/14 08:50 PM
08/16/14 08:50 PM
Hermiston Oregon
mopar_leaner Offline OP
Hermiston Oregon
working on a 1971 cuda with a 431 stroked 383, it has MSD, holley red electric pump, classic air just installed and dual electric fans. The problem is running the air, it drains the battery dead.
Not sure what amp alternator i need, but i know it has to be more than the 60 amp unit thats on it now.
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: what alternator [Re: mopar_leaner] #1659863
08/16/14 09:02 PM
08/16/14 09:02 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
mopar hd 100 amp police car alternator.
Re: what alternator [Re: Golden-Arm] #1659864
08/16/14 09:13 PM
08/16/14 09:13 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Yep...
Leece-Neville...
Re: what alternator [Re: Golden-Arm] #1659865
08/16/14 09:13 PM
08/16/14 09:13 PM
Hermiston Oregon
Hermiston Oregon
um not wanting to use that one, more of a stock looking one
Re: what alternator [Re: mopar_leaner] #1659866
08/16/14 09:15 PM
08/16/14 09:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Power master
Re: what alternator [Re: mopar_leaner] #1659867
08/16/14 09:24 PM
08/16/14 09:24 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
POWERMASTER has a number of high output alternators part #17509 tag shows 62 amp at idle & 99 amp at highway speed
Re: what alternator [Re: 6bblgt] #1659868
08/16/14 09:32 PM
08/16/14 09:32 PM
Hermiston Oregon
Hermiston Oregon
Has anyone else used this powermaster??
Re: what alternator [Re: mopar_leaner] #1659869
08/22/14 03:36 PM
08/22/14 03:36 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I have read good stuff about these:
http://www.qualitypowerauto.com/catalog.php?category=4
and these:
http://www.tuffstuffperformance.com/index.cfm/page/ptype=results/category_id=175/mode=cat/cat175.htm
But you can also find a stock replacement from 80s alternators ( 78 amps ) on the cheap and available at many parts shops
http://www.moparmusclemagazine.com/techa...and_alternator/
Consider wiring upgrades
parallel wiring on stcok gauge system
Re: what alternator [Re: mopar_leaner] #1659870
08/22/14 10:09 PM
08/22/14 10:09 PM
Cab_Burge Online work
Cab_Burge  Online Work
Tuff Stuff makes a really nice OEM replacement black powder coated 100 amp that works real well
Re: what alternator [Re: Cab_Burge] #1659871
08/22/14 11:23 PM
08/22/14 11:23 PM
IN
ahy Offline
ahy  Offline
IN
The dual electric fans + AC are a "game changer". You need an alternator that has very good idle output (~80 amps) and can handle high load factors. None of the stock looking squareback derivatives even those rated 100 amps can do it. Max idle output on those is 50'ish amps.
Alternators I know of that can are the 140 and 200 amp Powermaster Delco based units, The 120 amp Denso and the big 100 amp Chrysler unit mentioned above.
"With AC" has different alternator brackets that make it harder to fit a non standard alternator. The Powermaster Chrysler adapted Delco's will mount in OE brackets but are a tight fit at the back vs the head. I tried one with Ed heads and no go. Maybe it would work with OE heads.
The Denso would take some degree of bracket modification.
For all of the above reasons, I went with the big heavy 100 amp Chrysler unit with brackets from my core '78 Cordoba engine (70E BB).
Good luck!
Re: what alternator [Re: ahy] #1659872
08/22/14 11:30 PM
08/22/14 11:30 PM
IN
ahy Offline
ahy  Offline
IN
Pic
Re: what alternator [Re: NachoRT74] #1659873
08/23/14 10:30 AM
08/23/14 10:30 AM
IN
ahy Offline
ahy  Offline
IN
and these:
That Quality Power alternator looks interesting. Should fit where a squareback goes. Just have to double check depth of the case.
HMMM... Does anybody have experience with that unit?
Re: what alternator [Re: mopar_leaner] #1659874
08/23/14 11:23 AM
08/23/14 11:23 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I have a Tuff Stuff alternator on my car.It's not the Mopar unit,but the quality is excellent and they are made in the USA.
Nautilus Racing-
Re: what alternator [Re: ahy] #1659875
08/25/14 12:56 PM
08/25/14 12:56 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
and these:
I started a post about the Quality Power units ( the billet ones) and someone on here had purchased one but has never reported back on again on how it worked..
What most people on here fail to ever talk about is the VERY low amps output at Idle with the stock Alternators....
Re: what alternator [Re: floridian] #1659876
08/25/14 01:00 PM
08/25/14 01:00 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
not me :P
