Indy Head/Valley cover question?? #1659711
08/16/14 02:51 PM
08/16/14 02:51 PM
Rochester, PA (near Pittsburgh...
1974 474 Duster Offline OP
I know a lot of people are at the Curt George race, but here it goes. Putting new Indy 44-1 heads on my short block. The question is pretty simple and seems obvious. Do you just run a bead of rtv down the valley pan rails to seal to the bottom of each head?? Looks quite simple, just seeing what others have done and/or do here. Let me know please. Want to get some more done today.
Thanks, Ken
Re: Indy Head/Valley cover question?? [Re: 1974 474 Duster] #1659712
08/16/14 03:00 PM
08/16/14 03:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yes a bead of silicone is all you need.
Re: Indy Head/Valley cover question?? [Re: Al_Alguire] #1659713
08/16/14 05:07 PM
08/16/14 05:07 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
On some of the valley covers they will only go on with the heads off. Test fit the cover with heads on and trim the sharp edge with a wood joiner, file, etc., until you can slip one side under the head and then drop the other down. Slide it to the center and fill the gaps with silicone (as well as the ends). On one cover I had to just trim the knife edge and on another I had to cut the bevel edge as well.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Indy Head/Valley cover question?? [Re: Dads426] #1659714
08/16/14 07:15 PM
08/16/14 07:15 PM
Indy "finishes" the edge on a belt sander and to no spec at all--it is common to see one that will hold the head off the block--check fit to make sure that more material does not need to come off the edge--we like a bead of Ultra Grey as it is one of the most oil resistent types of RTV and does not stand out color wise on the aluminum--wipe a finger down through the seam after and it gives a very neat look to the workmanship--don't use too big a bead--keep it neat.
Re: Indy Head/Valley cover question?? [Re: ] #1659715
08/16/14 07:27 PM
08/16/14 07:27 PM
Thanks guys, got a can of "The Right Stuff" & sealed the edges. Worked great! Thanks for the input
Ken
Re: Indy Head/Valley cover question?? [Re: 1974 474 Duster] #1659716
08/16/14 07:51 PM
08/16/14 07:51 PM
Making progress. Finish up the rockers tomorrow. Looking good so far!!
Re: Indy Head/Valley cover question?? [Re: 1974 474 Duster] #1659717
08/16/14 10:47 PM
08/16/14 10:47 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
1974 there was a hot dog shop in Rochester that had the best chili dogs.Is it still downtown?My buddy was from Zelipinople and he brought me there a few times.They had a line outside waiting for dogs.Rocky
Chrysler Firepower
Re: Indy Head/Valley cover question?? [Re: therocks] #1659718
08/17/14 12:07 PM
08/17/14 12:07 PM
Rocky, Yeah Brighton Hot Dog Shop is still here. Made several other locations now as well, franchised out.
See ya, Ken
Re: Indy Head/Valley cover question?? [Re: Dads426] #1659719
08/17/14 12:25 PM
08/17/14 12:25 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I had to use paper gasket between the head and valley plate and a bead of goop
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Indy Head/Valley cover question?? [Re: 67mprfan] #1659720
08/17/14 05:09 PM
08/17/14 05:09 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
The plate is made for 10.72 or an R engine d/h. If you deck surface machining, square decking or any other mods of the sort, then the plate issue would need to be addressed. If you have a factory block and are assuming it is at correct deck height and just assemble and run, your issues can compound and take its toll on final assembly. Just like paper intake gaskets are put in the kits to allow propper height spacing when the heads are decked. Oblonging intake bolt holes can rob power. I have seen some machine shops deck a block and not cut the end rails down to match.
Re: Indy Head/Valley cover question?? [Re: 1974 474 Duster] #1659721
08/17/14 05:33 PM
08/17/14 05:33 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Also I was told that stuff(right stuff) can be tuff when pulling intakes.
Re: Indy Head/Valley cover question?? [Re: racerx] #1659722
08/17/14 05:42 PM
08/17/14 05:42 PM
gregsdart Online content
gregsdart  Online Content
I had to take a small high spot off the front of the Mega block, but I can slide the valley plate out the front if I need to.
