Re: Indy Head/Valley cover question??
[Re: 1974 474 Duster]
#1659712
08/16/14 03:00 PM
08/16/14 03:00 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Yes a bead of silicone is all you need.
[Re: Al_Alguire]
#1659713
08/16/14 05:07 PM
08/16/14 05:07 PM
Posts: 1,443 Maryland
Dads426
Maryland
On some of the valley covers they will only go on with the heads off. Test fit the cover with heads on and trim the sharp edge with a wood joiner, file, etc., until you can slip one side under the head and then drop the other down. Slide it to the center and fill the gaps with silicone (as well as the ends). On one cover I had to just trim the knife edge and on another I had to cut the bevel edge as well.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#1659714
08/16/14 07:15 PM
08/16/14 07:15 PM
Indy "finishes" the edge on a belt sander and to no spec at all--it is common to see one that will hold the head off the block--check fit to make sure that more material does not need to come off the edge--we like a bead of Ultra Grey as it is one of the most oil resistent types of RTV and does not stand out color wise on the aluminum--wipe a finger down through the seam after and it gives a very neat look to the workmanship--don't use too big a bead--keep it neat.
#1659717
08/16/14 10:47 PM
08/16/14 10:47 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
1974 there was a hot dog shop in Rochester that had the best chili dogs.Is it still downtown?My buddy was from Zelipinople and he brought me there a few times.They had a line outside waiting for dogs.Rocky
Chrysler Firepower
[Re: Dads426]
#1659719
08/17/14 12:25 PM
08/17/14 12:25 PM
Posts: 1,030 ohio
67mprfan
ohio
I had to use paper gasket between the head and valley plate and a bead of goop
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
