Oil pan rusting on 07 Ram 2500 Hemi? #1659010
08/14/14 04:57 PM
08/14/14 04:57 PM
Penna
70satelliteguy Offline OP
Penna
I bought this 07 truck 2 years ago and the oil pan has surface rust that is flaking off and the edges of the pan are really rusting Is this a common problem with the Hemi Rams? Have anyone had the pan rust thru? How hard is it to change the pan on the Hemi? I have heard horror stories about changing Ram oil pans but I am not sure if they were talking about the Hemi or the CTD.
Thanks Mike
Re: Oil pan rusting on 07 Ram 2500 Hemi? [Re: 70satelliteguy] #1659011
08/14/14 09:45 PM
08/14/14 09:45 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
A Hemi ain't that bad to remove the oil pan. A diesel is the PITA.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Oil pan rusting on 07 Ram 2500 Hemi? [Re: 71yelladustr] #1659012
08/14/14 10:16 PM
08/14/14 10:16 PM
NH
torredcuda Offline
torredcuda  Offline
NH
My `97 rusted thru and now my `04 looks pretty crusty as well. Not sure what type of metal they use for the pans but it`s crap!
Re: Oil pan rusting on 07 Ram 2500 Hemi? [Re: torredcuda] #1659013
08/14/14 10:22 PM
08/14/14 10:22 PM
Penna
Penna
Thanks for the reply's. I was hoping that it was the Diesel pan that was a pita. My 05 CTD pan however looks great!
Mike
Re: Oil pan rusting on 07 Ram 2500 Hemi? [Re: 70satelliteguy] #1659014
08/15/14 12:45 AM
08/15/14 12:45 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The crap they are mixing with the salt they load up the streets with will these days eat anything pretty quickly. I'm guessing it saw a lot of winter duty. Gene
Re: Oil pan rusting on 07 Ram 2500 Hemi? [Re: poorboy] #1659015
08/16/14 04:08 PM
08/16/14 04:08 PM
IN
ahy Offline
ahy  Offline
IN
I believe the pans are laminated "quiet steel". Two thin sheets of steel with a rubber layer bonded in between. The outer layer goes pretty fast when it gets a dose of gravel and salt. The inner layer will hold oil even if the outer is pretty much gone, at least for a while. It sure looks bad though.
Re: Oil pan rusting on 07 Ram 2500 Hemi? [Re: ahy] #1659016
08/22/14 06:14 PM
08/22/14 06:14 PM
Kingston, IL USA!
gts340swinger Offline
Kingston, IL USA!
A co-worker had a similar year Durango that the pan was badly rusted on (as well as the rest of it). It was actually weeping oil when he traded it in. The only other pan I've seen rusted through around here was on a 2.2 in an Omni GLH I had. They do get rusty around here like Gene said. The road "salt" is more like salt/acid.
A hobby of mine is sitting in the living room watching the rockers rust off my old truck.
Mr. Norm's "Fanatic" (idiot)
71 Mr. Norm's Demon GSS
77 Mr. Norm's personal B250 GSS van
76 Mr. Norm's KZ900 Motor Sports Special
69 Mr. Norm's M code Dart GTS
69 D100
68 Barracuda
64 Valiant V200
07 Charger Daytona SST 6 speed test mule.
Re: Oil pan rusting on 07 Ram 2500 Hemi? [Re: gts340swinger] #1659017
08/25/14 10:30 AM
08/25/14 10:30 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
My 05 was decent up until about a year ago. Now it looks like a rust explosion. Both bedsides around the wheelwell, another spot by the tailpipe, the rear bumper, bottoms of the doors at the pinch flanges, and the passenger side rocker is approaching rust-through status too.
9 years was a good run I guess!
Re: Oil pan rusting on 07 Ram 2500 Hemi? [Re: Blusmbl] #1659018
08/25/14 06:55 PM
08/25/14 06:55 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I got alittle more years out of my 96' Ram 2500 up until about 4 years ago. I took real good care of it & washed it regularily. Within those 4-5 years the whole bottom edge of my truck has lost the bottom 4"-6" of metal in all of these area's. Dang Michigan winters.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Oil pan rusting on 07 Ram 2500 Hemi? [Re: 6PKRTSE] #1659019
08/25/14 09:48 PM
08/25/14 09:48 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
My 03 Dakota must have that two layer pan, it was rusting pretty bad and a very small hole in the outer layer but no leaks. I cleaned it off good used rust converter then a couple coats of black paint, came through last winter fine no new rust or anything on the pan. The body on the other hand looks like a explosion of rust in the last 10 months. Can't [Edited by Moparts - Family Friendly Site - Keep it clean] 212k on it and going strong!
