Fiddle sticks !!!! Starter on a Hemi and headers.. #1658356
08/12/14 11:45 PM
08/12/14 11:45 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
OK, as some know, I just put a 426 Hemi in the Daytona with TTI headers and power steering.... Well........ I think I have a starter going south and it is freakin' brand new.... It acts like it is too far advanced, but it isn't. Then, it'll work fine.... I will start off with putting another new starter relay... But, in the event that it ISN'T the relay, what is the difficulty with removing the mini-starter with a 426 Hemi with TTI headers in a '69 B-body ( Daytona in this case ).
As the world turns, I just go for the ride..............
Troy
Houston Mopar Connection Club
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: hemi68charger] #1658357
08/13/14 07:40 AM
08/13/14 07:40 AM
More detail on what's going on (when/what/how often/hot or cold) etc
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: RapidRobert] #1658358
08/13/14 08:27 AM
08/13/14 08:27 AM
Houston, Tx
Houston, Tx
Robert,
Hot or cold. Like last night, it was cold start. Turn the key and it is like "click", then do it again then it engages, but barely turns. Do it again then it will rotate. I'll probably make a video, too hard to try and articulate in writing..
Troy
Troy
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: hemi68charger] #1658359
08/13/14 11:18 AM
08/13/14 11:18 AM
Dont articulate. (1) slo charge the batt up & have it load tested if there is any doubt of it's condition or easier yet just drop in another known good batt. (2) clean ALL large cable connections/terminals including the ground path (3) jump from starter relay batt terminal to the nearby brown wire "sol" terminal (4) lastly bite the bullet & pull that starter
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: RapidRobert] #1658360
08/13/14 01:38 PM
08/13/14 01:38 PM
Houston, Tx
Houston, Tx
Robert. All components are new. I purchased new cables, battery and starter. The relay might be foriegn junk, not sure....... But yes, the thought of taking the battery out and doing a load test passed my mind ( had better not, dang battery is brand new )...
Thanks to taking the time to respond....... Not looking forward to the potential of pulling the starter...... But, if I have to, I have to....
Troy
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: hemi68charger] #1658361
08/13/14 03:27 PM
08/13/14 03:27 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Make sure there isn't any paint under the ground cable connection to the block. I have run across this in new engine builds and it will not ground well enough.
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: stumpy] #1658362
08/13/14 03:32 PM
08/13/14 03:32 PM
Houston, Tx
Houston, Tx
This problem has slowly accorded over the last couple of days..... But, to your point. Prior to me detailing the motor, I made sure the block was bare before bolting on the negative battery cable......
Troy
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: hemi68charger] #1658363
08/13/14 03:47 PM
08/13/14 03:47 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I'd say the motor has to come out to put a starter on, the header has to come off and this means the motor has to come out. I have my Hemi on the floor now. Same combo of parts.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: HemiRick] #1658364
08/13/14 04:04 PM
08/13/14 04:04 PM
Houston, Tx
Houston, Tx
Been thinking over lunch... If I remove the driver's side lower control arm and torsion bar, I might be able to create enough "wiggle" room.. It would be a LOT easier to remove one lower control arm and torsion bar than a complete motor......
Troy
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: hemi68charger] #1658365
08/13/14 04:45 PM
08/13/14 04:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It would be easier to drop the trans and the bellhousing than to pull the motor , or for that matter the torsion bar and get it realigned ...
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: hemi68charger] #1658366
08/13/14 06:41 PM
08/13/14 06:41 PM
central il.
second 70 Offline
second 70  Offline
central il.
Troy Try a different battery first it's the easiest. You never know with new parts these days. My hemi wouldn't start after a jet change. It would turn over like crazy. I thought it was flooded but it wasn't and still didn't start. Gave up went back and put old jets back in car. You guessed it it still would turn over great just wouldn't start. Long story short the battery was bad and wouldn't supply enough volts to fire the msd. New battery no more problems other than having to go back and rejet the carbs a third time. LOL Mike
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: hemi68charger] #1658367
08/13/14 11:49 PM
08/13/14 11:49 PM
I've change the starter at the races with Hooker race headers in my old 1970 Hemi Cuda stick shift car, a real pain but I didn't have to remove the torsion bar or any of the steering linkage You can load test the battery by turning on the headlights first with a reflective panel in front of them or have someone watch the headlights and then hit the starter, if the headlights dim like real bad look at the batterey, if they don't dim it is probally the atarter Did you put a new mini starter in it? I've had cranking troubles in the race cars when hot with several different mini starters , it is slow to turn over on the first revolution and then the starter will spin the motor over properly, no problems when cold I think that problem is ground related I have to make sure but I really think it is ground related Two new battery in the trunk in parallel with the ground terminals hook together, engine block is grounded through the front and rear motor plates and one # 2 ground wire jumper accross the mid plate I did have one bad battery cut off switch give similar symptoms I would do a voltage drop check on the main battery lead to the starter before and after engaging it before deciding on what the real problem is, all stock 1969 Mopar cars had wiring issues, didn't they Lots of gremlins out there Good luck, let us know what you find
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: Cab_Burge] #1658368
08/14/14 01:01 AM
08/14/14 01:01 AM
Houston, Tx
Houston, Tx
... You can load test the battery by turning on the headlights first with a reflective panel in front of them or have someone watch the headlights and then hit the starter, if the headlights dim like real bad look at the batterey, if they don't dim it is probally the atarter ...
I have one of those funny cars where you can't see the headlamps with the motor not running......
Seriously, I get your point and will test that theory........ Because inquiring minds wanna know......
Troy
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: hemi68charger] #1658369
08/14/14 02:04 AM
08/14/14 02:04 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Might be time to install a quality Rob Mc starter very nice piece
check this
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: sthemi] #1658370
08/14/14 10:24 PM
08/14/14 10:24 PM
Houston, Tx
Houston, Tx
I put a known good battery and it did the same thing..... Sounds like a dang Chevy starter that's not shimmed correctly..... It occurred when the motor was cold, not warm.... I'll change out the starter relay next, have a NOS one showing up soon, but my gut says starter......
Troy
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: hemi68charger] #1658371
08/14/14 11:05 PM
08/14/14 11:05 PM
You can jump the 2 large/small starter terminals to each other to bypass the starter relay. I was thinking there might be a slight chance the brown wire "solenoid" wire/terminal on the relay was not getting steady voltage when the key is turned to start from a poor connection inside the relay but somewhat unlikely, but it'd sure be better than changing out that captured starter
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: hemi68charger] #1658372
08/14/14 11:13 PM
08/14/14 11:13 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd be surprised if the relay was the ause of the problem, but then again I've been surprised before.
The post "sthemi" references is mine. My DD starter was draggy: starter checked out OK, replaced solenoid, then engagement was occasional and sounded horrible half that time.
As far as accessing the starter - the Hookers on my RR allow basically no room for anything, but I was able to get room by unbolting them from the exhaust & head. Shop rags & towels to protect finish on headers & apron. Very minor bloodletting.
Re: Fiddle sticks !!!! Starter on a Hemi and headers.. [Re: topside] #1658373
08/14/14 11:36 PM
08/14/14 11:36 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
"I hate my Hooker Headers" (spent 10 hours last weekend welding up, grinding and filing the ports so they match the heads) but they do come apart, Troy has TTI though and I think they're one piece. Steering box pretty much hits header tube, header tube pretty much hits starter.
Sheldon
