Oil pressure ports thread size on 383? #1657588
08/11/14 05:48 PM
08/11/14 05:48 PM
Norway
cudaerik Offline OP
cudaerik  Offline OP
Norway
Anybody know the thread sizing on the two oil pressure ports on a 383?
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600)
1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600)
1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Oil pressure ports thread size on 383? [Re: cudaerik] #1657589
08/11/14 05:56 PM
08/11/14 05:56 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
1/4 inch NPT.
Re: Oil pressure ports thread size on 383? [Re: cudaerik] #1657590
08/11/14 06:01 PM
08/11/14 06:01 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
1/8" is the smaller of the two.
Re: Oil pressure ports thread size on 383? [Re: buildanother] #1657591
08/11/14 09:08 PM
08/11/14 09:08 PM
IN
ahy Offline
ahy  Offline
IN
One of each (1/8", 1/4") on my '78 400.
Re: Oil pressure ports thread size on 383? [Re: ahy] #1657592
08/11/14 10:55 PM
08/11/14 10:55 PM
VA
dragon slayer Offline
VA
Where are they located on a 1970 383? G
Re: Oil pressure ports thread size on 383? [Re: dragon slayer] #1657593
08/11/14 11:59 PM
08/11/14 11:59 PM
IN
ahy Offline
ahy  Offline
IN
My core is a '78 but I think all B/RB are the same.
At the back of the block, on top and under or almost under the cowl on most models. Typically the 1/8" port is used for the factory sender that looks like a little barrel with wire on top and the 1/4" port is plugged.
Re: Oil pressure ports thread size on 383? [Re: dragon slayer] #1657594
08/12/14 10:14 AM
08/12/14 10:14 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Location on 1970 383. Other B-RB are typical.
...FAFO...
Re: Oil pressure ports thread size on 383? [Re: skicker] #1657595
08/12/14 11:54 AM
08/12/14 11:54 AM
VA
VA
I do know where the sender is, but I have not found the second port. How close to the original sender is the second port. I want to add a mechanical pressure gauge while retaining the electrical. G
Re: Oil pressure ports thread size on 383? [Re: dragon slayer] #1657596
08/12/14 12:13 PM
08/12/14 12:13 PM
chicagoland,usa
chicagoland,usa
I guess it's possible that the early blocks didn't have both ports, but if it's there, it will be adjacent to the other port you have coming off of the same cast in galley in the back of block. In other words, about 2 inches away from the one you already know of. It's easy to get a brass splitter/adapter if there's just one port too.
Re: Oil pressure ports thread size on 383? [Re: buildanother] #1657597
08/12/14 12:50 PM
08/12/14 12:50 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
They all have both ports, it's pointing toward the passenger side of the car, you just can't see it in that picture above.
Re: Oil pressure ports thread size on 383? [Re: JohnRR] #1657598
08/12/14 01:58 PM
08/12/14 01:58 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Maybe a little better in this one...
Not that it matters one way or the other but you can add a factory warning light sensor in the mechanical gauge line by using a T fitting off of the back of the gauge. That's the way many new gauge clusters are formatted when using multiple gauges with warning lights.
...FAFO...
Re: Oil pressure ports thread size on 383? [Re: skicker] #1657599
08/12/14 06:59 PM
08/12/14 06:59 PM
VA
VA
Yep I found it pointing to the passenger side. Square plug. Looks like there is an access hole just above the throttle cable access. Thank you for the pictures and help. G
