Oil pressure ports thread size on 383?
#1657588
08/11/14 05:48 PM
08/11/14 05:48 PM
Posts: 84 Norway
cudaerik
Norway
Anybody know the thread sizing on the two oil pressure ports on a 383?
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Oil pressure ports thread size on 383?
[Re: buildanother]
#1657597
08/12/14 12:50 PM
08/12/14 12:50 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
I guess it's possible that the early blocks didn't have both ports, but if it's there, it will be adjacent to the other port you have coming off of the same cast in galley in the back of block. In other words, about 2 inches away from the one you already know of. It's easy to get a brass splitter/adapter if there's just one port too.
They all have both ports, it's pointing toward the passenger side of the car, you just can't see it in that picture above.
