Build Dates on Fender Tag Versus Vin Number Sequence? #1657389
08/11/14 10:28 AM
08/11/14 10:28 AM
blewbyu Offline OP
blewbyu  Offline OP
I have a 329 date on my fender tag and my last 6 numbers on vin start with 344XXX and I seen a build date on another cars fender tag of 326 and the vin on the car was 240XXX. My question is how could these vins be 100000 numbers apart when the cars had build dates within 3 days? My car was a Y39 car and on the build sheet it also has 17 SPECIAL ORDER. Does this mean it took a lot longer to build my car?
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: blewbyu] #1657390
08/11/14 11:35 AM
08/11/14 11:35 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The VIN is assigned when the order is placed I am pretty sure , not when the car finally hits the assembly line.
Are the 2 build dates you mention for cars built at the same plant ?? Same year ???
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: JohnRR] #1657391
08/11/14 11:58 AM
08/11/14 11:58 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Tree'd. What year and type of car?
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: sunroofgtx] #1657392
08/11/14 02:18 PM
08/11/14 02:18 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
'69 A12 cars (329 & 426), Superbirds (B30), and some other "program" cars have generic "Scheduled Production Dates".
The VIN is assigned when the car is Scheduled to be built.
Like said above you can't compare different plants & years as they varied.
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: JohnRR] #1657393
08/11/14 03:20 PM
08/11/14 03:20 PM
blewbyu Offline OP
blewbyu  Offline OP
Different plants and different model cars but the same year cars, both are 69 models
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: blewbyu] #1657394
08/11/14 04:12 PM
08/11/14 04:12 PM
JohnRR Offline
JohnRR  Offline
You can't compare them then.
You can only compare cars built at the same plant durning the same model year , models of the same platform don't matter , nor does dodge vs. plymouth on the same platform ... ie: a B body
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: blewbyu] #1657395
08/11/14 05:05 PM
08/11/14 05:05 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
1969 a & b-body assembly plants:
"A" - Lynch Rd. Detroit, MI built ~215,000 cars - R & W b-body lines
"B" - Hamtramck, MI built ~355,000 cars - a-bodies & Chargers
"E" - Los Angeles, CA built ~72,000 cars - a-body and R & W b-body lines
"G" - St. Louis, MO built ~310,000 cars - R, W & X b-body lines
"R" - Windsor, ONT built 172,000+ cars - a-body & c-body
St. Louis plant WM2xx9G240xxx w/SPD 326
Hamtramck plant LS23M9B344xxx w/SPD 329 (best guess w/o more info, your car was actually assembled a week later on or about Friday, 4/4/69)
What's the date on your K-frame and/or your engine's EAD? What's the "SEQUENCE #" upper left of your b'cast sheet?
The 1969 A12 & A13 "program" cars had "make believe" SPD dates & their VINs were not assigned until the plant actually scheduled its build. IMO your car didn't take any longer to build.
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: 6bblgt] #1657396
08/11/14 11:01 PM
08/11/14 11:01 PM
blewbyu Offline OP
blewbyu  Offline OP
Hamtramck plant LS23M9A344xxx w/SPD 329 (best guess w/o more info, your car was actually assembled a week later on or about Friday, 4/4/69)
My Engine assy was 3/26 on the top engine pad and on build sheet seq# is 1173150 assy plant B, the other was assy plant G
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: blewbyu] #1657397
08/11/14 11:59 PM
08/11/14 11:59 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
I have a copy of a sheet from:
LS23H9B350342 SPD 411 & SEQUENCE NUMBER 1 171197
LS23M9B344xxx SPD 329 & SEQUENCE NUMBER 1 173150
Based on the b'cast sheet's sequence number your car was started ~2000 cars (only a few days) after the 383 GTS. I just do NOT have enough info to figure if that's later than my 4/4/69 "guesstimate" or the above 383 GTS was a week early.
K-frame date would help if available.
The LS23H9B350342 sheet was in LS23M9B341723 another 329 SPD 440 Dart GTS.
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: 6bblgt] #1657398
08/12/14 12:42 AM
08/12/14 12:42 AM
blewbyu Offline OP
blewbyu  Offline OP
I can get the k frame info tomorrow
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: blewbyu] #1657399
08/12/14 10:32 AM
08/12/14 10:32 AM
blewbyu Offline OP
blewbyu  Offline OP
Best i can see if I'm reading correctly it looks like 0309 1 can get a picture to veryify if this does not seem correct. I assume that is Jan 30th First shift? My engine block casting is 2-26-69, heads are 3-8-69 and 3-10-69 and like i said eng assy is 3-26-69
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: blewbyu] #1657400
08/12/14 01:22 PM
08/12/14 01:22 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
That's correct, 0909 1 would make more sense but it is what it is. Was/is the car pretty unmolested (for a 440 Dart), lots of parts can be changed in 45 years.
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: 6bblgt] #1657401
08/12/14 02:56 PM
08/12/14 02:56 PM
Cab_Burge Online work
Cab_Burge  Online Work
I'm curious as to where to look at my 1969 GTS K member for a date code, it's a H code car. Mine is not numbers matching, way to many owners and way to many years of racing it
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: 6bblgt] #1657402
08/12/14 03:42 PM
08/12/14 03:42 PM
blewbyu Offline OP
blewbyu  Offline OP
car only has 50k and k frame appears to have never been out of the car as all cotter pins and roll pins in strut rods all look original. here is a picture of the date on k frame.
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: Cab_Burge] #1657403
08/12/14 03:46 PM
08/12/14 03:46 PM
blewbyu Offline OP
blewbyu  Offline OP
Look on the front face of the K frame that faces the bumper
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: blewbyu] #1657404
08/12/14 04:11 PM
08/12/14 04:11 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
K frame dates are often VERY difficult to read due to the thin stampings being buried in rust paint and grime. You usually need to strip the area to clean bare metal to make them out
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: ScottSmith_Harms] #1657405
08/12/14 09:06 PM
08/12/14 09:06 PM
Thanks to both of you for the help This car was hit pretty hard on the left front before I took it in trade with no motor or trans. It does have a early A body 383 K member in it still but I'm curious if it is the original one or not I'll look at it tomorrow in the light, it is storming here now and I don't want to push the car out of the garage in the rain and hail
Re: Build Dates on Fender Tag Versus Vin Number Sequence? [Re: Cab_Burge] #1657406
08/14/14 12:45 AM
08/14/14 12:45 AM
blewbyu Offline OP
blewbyu  Offline OP
Here is a perfect case, car has the same 329 date on fender tag and build sheet and is like 4000 vin numbers later. Same car, same motor and same plant?
http://www.ebay.com/itm/Dodge-Dart-M-cod...s#ht_405wt_1304
